Question about Waterway Champion 1 1/2 Hp 230v Energy Efficient Pump
1.5 hp waterway champion pool pump issue
We bought a 1.5 hp waterway champion pool pump on 7/12 for our 16X32 inground pool at Namco, and it's now turning itself off (3x already) after being on for less than half hour. Why? Am I doing something wrong?
    President:
  • Waterway Master
  • 1,378 Answers
Be sure you have connected the motor to the line leads correctly and that the motor is set for the proper line voltage.
A somewhat common problem is that most motors are dual voltage (can be ran on 115 or 230 volt) and come factory set for 230 volts. If you connect it to a 115 volt circuit it will run for a while and then overheat and shut off.
Posted on Jul 28, 2009
  • tmistydad2 Jun 26, 2011
    So does that mean there is a reset right on the motor?
  • John Prohaska
    John Prohaska Jun 26, 2011
    A better way to say it is there is a reset in the motor...it is internal and operates automatically. If it trips due to overheating it will reset itself once the motor has cooled enough.
Remove motor
remove pump and replace with new
May 19, 2014 | Waterway InGround Pool Pump 1 HP
Water temperature reading way too high
make sure valves are open if ok check temp sensor
Apr 04, 2014 | Waterway Inground Pool Pump Champion No....
Wire for 110
see side of motor it should show low voltage vs high voltage have to move wires
May 31, 2013 | Waterway Inground Pool Pump Champion No....
I have just bought a waterway 3/4 hp. Can you give instructions ( or Diagram ) for changing wiring in motor over to 110 V from 220 V. Thanks, Pat
Is there a coverplate where the wires come out of the pump? If so, remove the plate and there should be a wiring diagram inside for both the 110 or the 220V convertions.
Jun 03, 2011 | Waterway Champion 1 1/2 Hp 230v Energy...
Not self priming itself. when it turns off the water pushes back out of the skimmer and pushes the basket up. it loses water and the pump cant re-prime itself.
PRIME PUMP, OPEN AIR VALVE ON FILTER. OR TAKE THE LID OFF YOUR FILTER AND SEE IF IT STARTS TO PUMP... YOU DO HAVE IT PLUMBED RIGHT? THE PIPE COMING OUT OF THE PUMP GOES TO THE FILTER !! I'M YOUR LOCAL POOL PUMP REPAIR GUY IN LONGWOOD FLORIDA. WHERE THE POOL IS ALWAYS OPEN
Aug 28, 2010 | Waterway Inground Pool Pump Champion No....
Got a waterway 1.5 hp 1 speed 115/230v, wired 115 need 230
Is there a coverplate where the wires come out of the pump? If so, remove the plate and there should be a wiring diagram inside.
Good Luck
Kurt
Mar 18, 2009 | Waterway Champion 1 1/2 Hp 230v Energy...
Waterway Champion 1 1/2 Hp  230v Energy Efficient Pump Logo
326 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Mike
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
