HD52W67YX39 HDTV projection. Convergence appears to be out. Call center tried to walk me through auto convergence but option is not available in Setup menu.
  • 147 Answers
Replace both convergence ics in the tv.
Posted on Jul 28, 2009
My convergence will not line up right
if you press menu then scroll down to setup then enter the setup menu does the auto convergence adjustment option still appear under the setup menu options or has it disappeared?
Feb 11, 2013 | RCA D52W20 52" Rear Projection HDTV-Ready...
52" rca hdtv has a shadow ghost when it plays. It
convergence issue. Press menu and then scroll down to the setup option enter setup and scroll to Autoconvergence and activate the auto convergence feature that will realign the convergence . If that doesnt correct the issue you will need a Convergence power board, If the auto convergence feature is missing from the setup menu then you need the convergence option missing repair kit. Both the board and the repair kit are available from www.tvrepairworld.com
Jun 18, 2011 | RCA D52W23 52" HDTV CRT TV
HDTV monitor 52 in. Model #: D52W26 Serial #: G072CU07E colors are separated, warped screen and cannot find auto convergence
Very easy repair. The ITC222 and ITC222A convergence option missing repair kit available from www.tvrepairworld.com will solve that issue. Its listed under the RCA repair kits and has the parts and the CD with repir instructions.
Mar 31, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Where is the auto convergence button
Hello
From it menu option, suf through and come to automatic convergence display option and press Ok button on the remote control.
The List & Labels part of the setup lets you edit your channel list and choose or create a
personal six-character label for each channel.
Note: Changing List and Labels can be time consuming. You can change these at a later time by accessing the
Setup menu.
1. Press the left or right arrow to scroll through the available channels and choose the
channel you want to edit.
2. Press the down arrow to highlight the In channel list option. Press the left or right arrow
button to add (the box is checked) or remove (the box is unchecked) the channel from the
list.
3. Press the down arrow to highlight the Channel label option. Press the left or right arrow
button to scroll through the available list of 25 most common labels. The last option in
the list allows you to create your own six-character label for the channel (the first letter of
the label is highlighted).
4. Press the 1 or 2 number button to change the first letter of the label.
5. Press the right arrow to highlight the second letter, then press the 1 or 2 number button
to change the second letter, etc...
6. When you are finished creating your label, press OK. For model D34W20, your TV tunes to
the last channel available in your channel list. For models D40W20 and D52W20 only, the
Auto Convergence menu appears next.
Auto Convergence (for models D40W20 and D52W20 only)
Your TV's picture tubes might have been disturbed during delivery or after you moved the TV,
causing the color in your TV to be out of alignment. The colors adjust by starting auto
convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu appears. The
cross in the middle of the screen should be yellow. If it is not, use the arrow buttons to
move the red cross to overlap the green cross. Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle of the screen. If
it is not, use the arrow buttons to move the blue cross to overlap the green cross. Press OK
(the TV tunes to the last available channel in the channel list).
Ok
Mar 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Need to know to set the convergence
Have you tried going to the service menu?
Do this by holding "MENU" on the TV set while it is on, then pressing "Menu" on the remote. You may have to do this a couple times for the menu to appear.
There should be a option on the appearing screen for Convergence, which has more options the the standard menu. To work this under the "9" setting for convergence, each of the + on the screen is the corresponding button the the TV remote (3 if top right, 5 is center). Use your volume or arrow keys then to move the selected + in the desired direction.
Jun 17, 2010 | Zenith R40W46 40" Rear Projection...
AUTO CONVERGENCE DOES NOT SHOW IN SETUP RED BLUE
the repair kit is available from www.tvrepairworld.com its called the ITC222 and ITC222 convergence option missing repair kit. The kit contains the parts and the CD with instructions.
May 10, 2010 | RCA R52WM24 52" HDTV Projection Television
Have a 56" RCA that i had the user manual for and lost it. i used to do the manual and auto converge. its been so long i forgot how to access it. help?
press menu then scroll to setup the auto convergence features are listed there. If they have disappeared you will need the ITC222A convergence option missing repair kit available from www.tvrepairworld.com
Mar 17, 2010 | RCA R52WM24 52" HDTV Projection Television
Convergence menu not available on my RCA HDTV. Model R52WH74YX58 I have installed all 3 new fuses as well as DL231 and CP230 and resoldered the pins on the flyback and IC, but I still have not got an...
The only fuse that will govern the convergence option is FL231 along with the two other components that you mentioned. If that didnt fix the issue the deflection board or the convergence power supply is defective. The deflection board is most suspect.
May 26, 2009 | RCA R52WM24 52" HDTV Projection Television
Convergence problem
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
You can download the manual here. Insrtuctions for auomatic convergence are described. I copied the instructions below.
Automatic Convergence
Your HD Monitor’s picture tubes might have been disturbed during delivery or
after you moved the HD Monitor, causing the color in your HD Monitor to be
out of alignment. The colors adjust by starting auto convergence.
IMPORTANT: Auto convergence works best once the HD Monitor has
warmed up for at least an hour. If you've just unpacked your HD Monitor,
it's a good idea to repeat the Auto convergence function when the
HD Monitor's been running for at least an hour. See page 38 for more
information about Auto convergence.
appears. The cross in the middle of the screen should be yellow. If it is not,
use the arrow buttons to move the red cross to overlap the green cross.
of the screen. If it is not, use the arrow
Sep 23, 2008 | RCA R52WM24 52" HDTV Projection Television
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
Electro Med Services...
