Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
Flow indicator not spinning - Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
    Problem Solver:
  • 9 Answers
If you took it out you might not have put it in right the small round white piece with the little thing sticking out of it needs to facing up and the red thing that spins sits on top of the white pin, if it is in right then
Replace your belts and if that doesn't fix it then the heater block is clogged and you will need to take it down to your local repair shop and have them fix it.
Posted on Jul 28, 2009
Bissell proheat cleanshot 2x won't stop putting out cleaner and water, the little dial won't stop spinning
First clean the Flow Indicator filter. Turn the Flow indicator cap counter-clockwise to remove it. Lift the rotor and the filter under it out. Clean the filter and reinstall in reverse order. Make sure you have unplugged the unit before working on it. Then clean the lint filter on the heat tank cap (it looks like a screen) and reinstall it. There's not much more to these so if that doesn't work call the Bissell Consumer Care at 1-800-237-7691
Oct 11, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell pro heat flow indicator wont spin
Hey Traci! You may want to have one of BISSELL's Authorized Service Centers inspect your machine.
Here's a quick link to assist you in locating one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
Feb 11, 2013 | Bissell Vacuums
Flow indicator not spining
Yes I also had this problem after just one use. There's several things that you should check. 1. pull side panel off where the belt is located and see if the liquid in the clear tubbing is flowing.I there is a bubble in the line the pump has lost it's prime and needs to be turned off for a minute then restarted. 2. make sure the belt is not broken this drives the solution pump and well as the cleaning wheel. 3. the lines that the solution flow though are clogged. always rinse the machine with water when done cleaning. Good luck.
May 31, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Hi. Would you know why the flow indicator on my Bissell Proheat won't spin.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
trwwt
Mar 13, 2010 | Bissell 1699 ProHeat Clear View Upright...
No Spray from Bissell 7920 ProHeat Pro-Tech s/n 01222111
When you put the cover back on, was the piston on the bottom of the smart mix knob? If it was, did you have the smart mix knob in the water only setting? Sometimes the flow indicator cap may be on too tight, loosen it while it is running until fluid starts to leak out, then tighten it until it starts spinning. On the bottom of the tanks, are the seals on the tank and not sitting the the hole. You may have pinched a line when you put the top cover back on. May still have junk in the lines somewhere, try running a mix of vineager and water (not on the carpet), that mix may clean it out.
Sep 08, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Air flow indicator stays activated after filter has been cleaned. Brush spins, but very little suction. Dirt doesn't spin in cup.
Your vacuum is clogged. Check all of the air pathways, hoses, etc. The most common places to check are anywhere there's a joint in the airways, and also directly behind the brushroll.
-R
Aug 12, 2008 | Hoover U5507900 Elite Rewind Bagless...
Dust in drum
well should be some movement this indicates air flow, machine prob has small clogg in it some where of filters are clogged, yes they do have filters, despite dyson claims.
Mar 26, 2008 | Dyson DC14 All floors Bagless Upright...
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
349 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
