Question about Dell XPS 400 PC Desktop
When i put a disk in the cd rom keep getting message please insert disk
  • 59 Answers
1) Try different media
2) go to device manager and make sure device is listed
3) if listed... try removing device, rebooting and letting it reinstall
4) device must have power if you can insert a cd... are you hearing grinding noises from the drive ? If so it may be a bad drive
5) go into bios setup on your computer and make sure it is recognized.
6) you may have to get a qualified person to physically open your machine to see if the device is connected to the appropriate controller.
Hope this helps... (alot of times it is a bad cd/dvd drive.. they will fail over time)
Posted on Jul 28, 2009
    Novelist:
  • 81 Answers
First reboot your OS and If this is a burn CDR I would try a known good disc from a store like a music CD, or an app/game CD. If still does not detect the disc listen very closely to your drive to see if you can hear the disc spinning. If it is not spinning your drive motor could be faulty. Also, if known good disc will not read then your drive could also be dead.
If you find that your drive has failed and your laptops is under warranty call Dell for a replacement. If not I would buy a drive from a reputable eBay seller and replace it yourself. The cdrom is one of the easiest parts to replace a laptop and once released it pulls out like cartridge and slides back in.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 188 Answers
Try known good disk. Other than that the unit has probably failed. Make sure disks can be read on a buddys computer?
  • 184 Answers
You could be having a faulty cd rom lens.
Try inserting a cd with a cleaning brush it will automatically run when inserted. Then try playing a normal CD.
If it fails replace your CD/Rom drive its cheaper than having it repaired.
Bad Locksum BIOS CD_Rom not found when I try to
it's not locksum ,its Check SUM or CRC errors.
what OP, are you running,? windows what. i guess.
the CMOS battery just died.
install a new one.
all puters this old do that, the battery is good for 7-10 years,
and all fail.
DO NOT FLASH your BIOS, fix the real problem first
when the battery dies, all our bios setting were lost
including boot device, and order
fix battery
then go into BIOS and put back boot order.
Mar 22, 2017 | HP Pavilion a815n (PS512AA) PC Desktop
I keep getting the message "the feature you are trying to use is on a CD-ROM or other removable disk that is not available." How to I get rid of this message so it does not keep popping up?
Usually this message comes from office, you need to put the office CD in the CD rom drive, than the system will copy the missing file and the message will stop poping up.
Aug 05, 2011 | HP OfficeJet D135 All-In-One InkJet...
I deleted the administrator my mistake now i cannot login to windows can I reset to the factory settings
hi, hope this helps,
1. Make sure the computer is turned off.
2. If any peripheral devices, except the optional external CD-ROM drive unit
(CE-CD05), are connected to your computer, disconnect them.
3. Turn on the computer.
4. When the message Press <F2> to enter SETUP appears, press F2. The
Setup Utility opens.
5. Insert the Product Recovery CD-ROM disk 1 into the CD-ROM drive.
6. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
7. In Boot Sequence of the Main menu, set CD-ROM Drive to the top of the list;
then, press ESC.
8. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice.
9. Read the message on the screen, and select the operating system which you
had selected for the first time you use the computer; then, press Enter.
You cannot change the operating system from the first choice.
10. Read the message on the screen, and select the way to recover your system;
then, press Enter.
11. Read the message and select Continue; then, press Enter.
12. Read the message and select Continue again; then, press Enter.
13. If you see the message asking you to insert the Product Recovery CD-ROM
disk 2, remove the disk 1 and insert the disk 2; then, press Enter.
14. If you see the message asking you to insert the Product Recovery CD-ROM
disk 3, remove the disk 2 and insert the disk 3; then, press Enter.
15. If you see the message The Operating System has been recovered
successfully, remove the Product Recovery CD-ROM disk 3. The system will
restart automatically.
16. When the message Press <F2> to enter SETUP appears, press F2. The
17. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
18. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice. The system restarts.
19. Set up Windows, following the instructions on the screen. When you finish
the setup, the recovery is completed.
Jun 02, 2011 | Sharp PC UM20 PC Notebook
A blank screen someone pushed something and messed my laptopup.
The computer ask for a botabile DISCK something like recoverry disck or a windows setup, put the recovery disck in the cd-rom/dvd-rom and set bios to boot from DVD/CD-ROM and falow the setup instruction.
Feb 26, 2009 | Acer Computers & Internet
HOW TO INSTALL WINDOWS 98
How to Install Windows 98 loadTOCNode(2, 'moreinformation');
  1. Insert the Windows 98 Startup disk in the floppy disk drive, and then restart your computer.
  2. When the Windows 98 Startup menu is displayed, choose the Start computer with CD-ROM support option, and then press ENTER.
  3. If CD-ROM support is provided by the generic drivers on the Startup disk, you receive one of the following messages, where X is the drive letter that is assigned to your CD-ROM drive: Drive X: = Driver MSCD001
    Drive X: = Driver OEMCD001 NOTE: If your CD-ROM drive is not available after you boot from the Windows 98 Startup disk, install the CD-ROM drivers that are included with your CD-ROM drive. For information about how to obtain and install the most current driver for your CD-ROM drive, view the documentation that is included with your device, or contact your hardware manufacturer.
  4. Insert the Windows 98 CD-ROM in the CD-ROM drive, type the following command at a command prompt, and then press ENTER X:\setup where X is the drive letter that is assigned to your CD-ROM drive.
  5. When you receive the following message, press ENTER, and then follow the instructions on the screen to complete the Setup procedure: Please wait while the Setup initializes. Setup is now going to perform a routine check on your system. To continue press Enter.
Jan 21, 2009 | Microsoft Windows 98 for PC
Toshiba laptop when turned on it freezes as windows is starting
Insert the disk in the cd rom and restart your computer......enter bios and change the boot settings...to boot from cd rom......boot of the cd and look for options such as check disk....repair disk...disk tools.....do a check disk ...or run a repair.....
Once you boot of the cd it will give you step by step details as how to repair the OS....
If you are unable to boot from cd..download a UBCD and created a boot cd this is much easier to use...
keep me posted
Cheers!
Nov 16, 2008 | Toshiba Portege 7100 Notebook
Acer cd rom fasilure
i have acer 4720z laptop i taken that before 4 months now the problem is when i insert a cd in to it. it reject and display message "please insert disk in to G drive please solve my problem
Oct 23, 2008 | Acer (91.47A37.001) CD-ROM Drive
ACER 9410CD/DVD-ROM driver not found.
I am assuming you are using XP,
update the drivers via device manager and select the device with the yellow question mark,right click update,reboot and restart
if nothing then remove the device via add/remove programs
select device and remove,reboot and restart
should auto recognise and install the drivers for you,
dont forget to do SP2 updates
Good luck with that,
Let me know how it goes thanks
Aug 14, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Format disk message evertime i insert a disk (cd or dvd)
sounds like you are driver deficient, eh? go to the HP website(through this printer driver link, if you wish) and give it a go
Mar 16, 2008 | HP (346789-001) CD-RW/DVD-ROM Combo Drive
Insert a disk
How many CDROm drive installed on your PC? The message appear when you burn a CD or just only reading the content?
Mar 02, 2008 | Samsung SM 352 CD-RW/DVD-ROM Burner
Computers & Internet Logo
94 people viewed this question
Alun Cox
