Question about D-Link Computers & Internet
I have a dlink des 1105 and am trying to connect a second computer to the hub. I have a computer alreay connected. I have Road Runner as an ISP if that make a difference.
    Problem Solver:
  • 12 Answers
You must use a router to share an internet connection, not a hub or a switch. A hub or a switch does not have the necessary functionality to share an internet connection in that configuration.
Posted on Jul 31, 2009
  •  Robert
    Robert Jul 31, 2009
    You must use a router, not a hub or switch. Plug the broadband modem into the WAN port of the router and the other two computers into the the LAN ports. A hub or switch does not have the necessary functionality to share an internet connection in that configuration. It does not have NAT (Network Address Translation) to share the internet connection between the computers on the network or DHCP (Dynamic Host Configuration Protocol) to automatically configure the network settings on each of the computers.
How to connect des-1005d
The new model. Just plug it in. No configurations. Any port for any use. The selling point is unmanaged. Look for the problem somewhere else (including the cables) till you are sure it's the switch. Then it needs to be replace.
http://files.dlink.com.au/Products/DES-1005D/Datasheet/DES-1005D_N1_Datasheet_11.pdf
The older model uses standard cabling practices, but still very versatile.
http://www.dlink.com/uk/en/support/product/-/media/Consumer_Products/DES/DES%201005D/Manual/DES%201005D_Manual_v02_EN_UK.pdf
Oct 25, 2012 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
Tip
Trying to connect 3 pc to a dlink switch
I have an internet connection at home which 512 Mbps. I have bought Dlink Switch DES-1005d. I have 3 pc at home. I want to share the internet connection among the three pc. I have tried just by connecting the pc with CAT5 cables. I just have the received packet and then I do not have internet connection at all. Please can someone help me?
Thanks in advance for your help.
Best Regards
Jerman
on Mar 28, 2008 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
Does d link des 1016d provides dynamis addresses to network printers?
DLink DES 1016D is seems to be an Layer 2 unmanaged switch which can not provide IP addresses.
If this switch is connected with a router or a DHCP server then it can pass the IP address to any connected device.
Regards,
Rashish
Aug 06, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
What is the default ip address for dlink 3226?
The Switch's factory default IP address is 10.90.90.90
with a subnet mask of 255.0.0.0 and a default gateway of 0.0.0.0.
Often set up by rs232 connection
See
ftp://files.dlink.com.au/products/DES-3226S/QuickInstallGuide/Generic_QIG_for_Managed_Switches_v1.03.pdf
and
http://support.dlink.com.au/Default.asp
Apr 20, 2010 | D-Link DES 3226 (DES-3226) 24x10/100 Mbps...
At&t broadband router hooked up to DES-1105 to two computers , 1 has windows 7 the other is windows XP and get an error stating 2 computers with the same IP
you should click on the local area network and find the option configure ip chang the ip from there.you can do same work in internet exproler properties
Jan 29, 2010 | D-Link Desktop Switch DES-1105 5-Port
After install of d-link ''DES-1105'',computer shows ''no connection''
go to control panel, network connections, check for available network, if that does'nt do it search for new harware and run th install wizard.
Nov 20, 2009 | D-Link Desktop Switch DES-1105 5-Port
How to connect two 8 port dlink switch?
You have to interconnect the switches with the cable. Connect the computers to the switches. Also connect the internet cable in the switch too.
Aug 27, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
I have a d link DES-1105. cant get more than one computer to work on hub/switch.
Hi!
Unfortunately, hubs or switches cannot be use to share internet access specially if it's connected to a modem. To share internet access, you will need a router. If you prefer not to use a router, you can enable ICS (Internet Connection sharing) on one PC and share internet access to the others. However, the PC that will share internet access will need two ethernet cards (or LAN cards).
Your setup will look like this:
If internet is not a concern, and you just want to connect the computers to share files and resources, you will have to se your computers to static IP. You do not need any additional device - just connect your computers to the hub, setup a static IP on all the computers.
If you need further assistance setting up static IP on the computers, please reply and I'll give you the step by step instruction for that.
For any setup, a router will be the best option.
I hope that helps.
Good luck and have a nice day!
Nov 30, 2008 | Computers & Internet
DLINK SWITCH DES-1008D
other units cant connect to my installed port hub and were having hight mare connecting it
Apr 09, 2008 | D-Link DES-1008D 8-Port Ethernet Switch...
Computers & Internet Logo
838 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
