Question about Dell Studio 17 Laptop
I can't access my documents and settings folder from my hard drive. An error message comes up saying that I don't have access, however I'm the administrator. How do I gain access to all the parts of my laptop? How do I stop this error message from popping up?
    Scholar:
  • 177 Answers
You may need to add yourself to a security group.Sometimes ,even an administrator may be denied access to a group,if she/he is not a member of that group. I had a similar situation myself a few months ago with Windows Vista,and it works the same in all operating systems,Vista, XP,Linux,MAC.
Posted on Jul 28, 2009
Why can't I access any of the files on my WD Elements external hard drive?
If you have not reinstalled a new OS the drive should be seen after starting your unit.
Disconnect the USB drive and reboot your unit.
After the unit comes up, plug in the drive.
If the drive is new to the system, it will locate and load drivers.
Afterwards it should give the opium to view files.
It should also be seen in your device manager, under disk drive.
You should be able to go to prosperity's and see sharing opium's ect. ( Security ) Try to make your changes here
May 20, 2014 | Western Digital 2TB WD ELEMENTS USB...
Fix Error performing inpage operation
did you try unhide/reset attribute? in Windows you can use "attrib" command. Since you familiar with "chkdsk" command, so i assumed you have no problem how to use "attrib" command. Good luck!
Jul 30, 2017 | Seagate FreeAgent® GoFlex? Desk 3TB Hard...
Access Denied Error on external hardrive
You don't have rights to the folder. Right click the folder --> Select Properties --> Security --> Advanced --> Owner and then change the owner to your user. Here are some instructions from Microsoft for taking ownership. Once you own the folder then you can do whatever you want.
http://technet.microsoft.com/en-us/library/cc753659.aspx
Oct 21, 2012 | Transcend StoreJet Computers & Internet
The parameter incorrect
The parameter is incorrect
Symptoms:
- Synching with Outlook.
- Error message: 'The parameter is incorrect'.
Explanation:
Generally, this error message indicates that the configuration process has been cancelled at some point. Typically, this happens due to cancelling the setup process on the Outlook Folders tab. If you are on Exchange folder, this tab can take several minutes to populate.
Fix:
In order to correct the problem you are experiencing, you will need to delete or rename the .ini file and then reconfigure CompanionLink/DoubleLook. This file is typically found in one of two locations:
For CompanionLink:
c:\Program Files\CompanionLink\
c:\Documents and Settings\[Username]\Application Data\CompanionLink\CompanionLink
For DoubleLook:
c:\Program Files\DoubleLook\
c:\Documents and Settings\[Username]\Application Data\CompanionLink\DoubleLook
Please note that Application Data is a hidden folder and that the .ini file extension is hidden by default. Please see http://www.companionlink.com/support/howto/ht0017.html for an explanation of how to display all files.
Hope this helps
Mar 01, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
I just bought an Iomega 1TB Prestige portable hard drive and every time I copy a single document in Word, PDF, etc from one drive and try to paste it onto the Iomega drive I get an "Access...
Can you copy that single document from the drive to a different folder?
Can you copy that copy to the IOMEGA?
Can you copy that original to the IOMEGA?
Nov 17, 2010 | Iomega Prestige 1 TB USB 20 Hard Drive
Western digital my passport 320 file path too deep
The "path" is the full name of a file or a folder, e.g.,
C:\Documents and Settings\User\Local Settings\Temporary Internet Files\Content.IE5
If the path has too many characters, you get the error-message that you reported.
If you can, rename one of the folders, using a shorter name.
Jul 17, 2009 | Western Digital My Book Essential Edition...
Access is denied
Try to scan it with R-Studio or GetDataBack..
Oct 25, 2008 | Samsung (SP0822N) 80 GB Hard Drive
Accessing a folder.
This will sound off the wall, but we had something similar to this happen with my last laptop, where it was "access denied" in lots of areas, and we would have to find little backdoor ways to get into control panel and document files. The problem with our computer was that it had previously crashed, and we had rebooted and reinstalled the xp, but didn't have the registration number, so it would run ok, but to get into all those access denied things (which you eventually need to get into) we had to come up with our registration number.
Did it prompt you to enter the product key when you re-installed it?
Jun 27, 2008 | SmartDisk FireLite USBFLB120 120 GB USB...
Hdd
Because the user settings on your old computer with the hard drive installed as master were password protected, your getting the error.
There may be other work arounds I don't know of, I just do a general search, files and folders, and then direct it to look in E:/
You might try the recommendations in this article
May 14, 2008 | Computers & Internet
Sonic dvd writer for photo story
if you are using xp, you can save your files to all users shared documents folder ,here you can create a folder that everybody can open it.
Oct 30, 2007 | Computers & Internet
Dell Studio 17 Laptop Logo
130 people viewed this question
Alun Cox
