Question about ViewSonic VA712B 17" Flat Panel LCD Monitor
The monitor gets very jumpy, so I can't read what's on it. Sometimes it's okay. It bounces up and down, vertically. Is it the computer or the monitor. The monitor is only about a year old, light use. The computer is an HP Pavilion. Ideas?
  • 748 Answers
Hello
You'll need another monitor or another computer to be sure. Although I suspect that capacitors in the monitor power supply are going bad. If you have another monitor then connect it to the computer. If everythings OK then it is the monitor that's bad. If the same symptoms appear then the HP video card is failing.
Posted on Jul 28, 2009
Computer will not boot to normal and verticle lines on monitor, dell XPS410, windows vista 32 bit
Unplug the monitor video cable from the computer. Power on the monitor and see if you get the same results. If so then your monitor is defective.
Oct 11, 2012 | Dell Computers & Internet
Flashing green light and monitor wont start
There are one or two capacitors that open in the power supply, sometimes it will have a bulge at the top, making it easy to spot.
Apr 05, 2012 | Acer Computers & Internet
I have red vertical stripes, then white dots, then when windows loads, I have wavy red lines. Using Nvidia Geforce 9800 GT with Pavilion Elite m9350f. Is this my video card problem?
Okay you proved it is the monitor, but first sub the video cord from the computer to the monitor if possible, if okay! at this point you are looking at a LCD panel display problem, cheaper to replace than go through expensive repairs.
Mar 19, 2012 | HP w2207 Monitor
Lcd vertical lines
Hook a spare monitor to the computer, if okay! the problem is with the HP monitor "LCD panel defective" not cost effective to repair. But if symptoms are the same for both, the video graphics card on the computer is defective, sub a video cord from the computer to the monitor if possible to cover all angles.
Mar 13, 2012 | HP LP2065 Monitor
I have a Samsung NC10 notebook hooked up to an Acer x193w monitor and up until today it has been working perfectly. Now the display will not fill the monitor's space. Horizontal is fine but vertically the...
Do you have a spare computer to hook up to the monitor to see if the monitor's settings are off vertically?
Can you adjust the vertical size of the image of the monitor?
Are the letters squashed down vertically?
If the letters are squashed down vertically, did the setting for pixel size of the screen get adjusted to another size accidentally in the control panel under display settings?
Can you reset the Acer monitor from the menu?
Jul 29, 2010 | Acer X193W LCD Monitor
Whyisscreen jumpy and jerky
mcdevito75 here, You can try, shut down your computer useing START SHUT OFF COMPUTER, when computer is shut down double check all connections at the computer and Monitor, also check wall socket. Now! restart your computer, check the controls on the monitor, if you have a button auto press it, this will automatically set your monitor. If all this fails, contact Dell, you may have a faukty monitor. Computer does not control monitor screen except for brightness and volume, problem most likely with the monitor itself.
Jul 03, 2010 | Dell Latitude D800 Keyboard
Jumpy monitor
Cheak the montor cable;set up the ups away from the monitor.even the problem is occured then problem with the circuit of the monitor.
Feb 13, 2010 | Proview PL713S 17" Flat Panel LCD Monitor
Monitor
Try another monitor to determine if the trouble is in the monitor or the computer's video circuitry. If it's due to the computer, install a new video card or replace the current one.
If the monitor is at fault, it is possible that bad capacitors in its power supply might be causing the problems, or there may be poor solder connections. Both are typical failures in many products. But given the relatively low cost of monitors today, repair is often uneconomical. Not too many shops will even attempt repairs. There's not a lot you can do except to replace the it.
Yes, it's only a couple of years old, and you have every right to feel "this should not be happening." But the sad fact is that consumer products are very cheaply made these days. Once a product is past its warranty period, the manufacturer doesn't care any more. That's also why stores push you to buy replacement warranties when you purchase a product.
Dec 14, 2008 | Gateway FPD1760 Monitor
SCREEN DISPLAY BOUNCES UP AND DOWN
Check and make sure that the speakers and any power supply (UPS) are not placed very close to the monitor.
Feb 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
Wavy, jumpy picture, ghosts, occasional color loss/change---you name it!
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 12, 2007 | Toshiba 50H81 50" Rear Projection...
Open Questions:
ViewSonic VA712B 17" Flat Panel LCD Monitor Logo
192 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
