Question about Sharp 65DR650 65" Rear Projection Television
FINAL WARNING REPLACE LAMP NOW
I just moved and when i set my TV back up, and turned it on, it read,
" FINAL WARNING! REPLACE LAMP NOW!
Can someone please tell me what is going on/
  • 67 Answers
All rear projection TVs has a lamp thats like a special bulb inside the TV.
The TV is warning you that this is about to go and will need to be replaced.
This is not a serious problem as TV lamps goes after certains hours of use (normally 4,000 hours sometimes more) and the TV manual should have instructions on how to do this and the part you need.
Contact Sharp support if your TV is still in warranty and for further help :
http://www.sharp.co.uk/pcat/support
if this helps please vote ...thanks and good luck!
Posted on Jul 28, 2009
  • 147 Answers
Your lamp is at the end of its life.you need to replace the lamp.
I HAVE SONY SXRD KDS-60A2020 I REPLACE A NEW LAMP I TURN TV ON AND I STELL READ REPLACE THE LAMP ON THE TV SCREEN
we have replaced our optical block twice, we changed out the lamp twice-first time it exploded inside the tv??? now the tv doesn\'t work for cable but we can use the piss poor cloudy optical block again using hd antenna or thru xbox internet - this tv is GARBAGE end of story! I will NEVER purchase a SONY product ever again - they are basically all the same like our Food industry they just slap some other company name on the final product - we were ripped off bad for this tv paid 3,000 piece of garbage!!!
Feb 27, 2014 | Sony Grand WEGA KDF-42WE655 42" Rear...
Tip
Lamp Reset Procedure for Panasonic TVs.
You have replaced your lamp and the set is working fine but the 'replace lamp light' is still on. What do you do?
This is an important procedure because you need to know when it is time to replace the lamp again. If you do not reset the timer you may run the risk of having the lamp explode, because it was not replaced in time. This can be dangerous and could cause a fire.
Manufacturers have lamp timers built in to their TVs so that when it gets close to time to replaced the lamp you are made aware of this and if you heed the warning you may save money by not damaging other components such as the ballast. If you do not heed the warning, you are on your own and deserve whatever happens.
If you have replaced the lamp in your Panasonic DLP TV and are having problems you probably need to reset the lamp counter.
This should solve your problem
1). Turn on the television.
2). Press the down button on the TV display (not the remote)
3). While pressing the volume button, press the "split" or "PIP" button on the remote.
I suggest writing your lamp hours on a piece of masking tape and taping it to the back of the TV for future reference.
This should reset your counter and you will be ready to enjoy your TV for about another 8000 hours.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
hardrocko
on Jan 29, 2011 | Televison & Video
A "final warning to replace
Did you reset timer after replacing lamp?
Aug 23, 2011 | Vivitek Replacement Lamp
We replaced the lamp on our Samsung 50" dlp model HL-S5086W tv about 3 weeks ago. Just recently, the tv started turning off by itself and the red standby/temp light and the green lamp light flash for a few...
    1. Ensure that the TV is off. It may be advisable to unplug the TV as well.
    2. 2 Using a Phillips screwdriver, remove the single screw affixing the lamp cover (the small, grill panel on the back of the set) to the chasis. There is also a grill that is held in place by tension. Just "pinch" the thumb clamp on the bottom of the grill and slide it out. This is the same procedure you would perform to change the lamp, except in this case you will not need to remove the lamp itself.
    3. 3 Inspect the spring-loaded blue safety switch to ensure it is making good contact when the panel is secured. The switch should deflect downward when the panel is replaced. If the contact with the panel is suspect, very gently bend the metal bracket on which the switch is mounted.
    4. 4 Replace the grill cover and the lamp door, and continue to enjoy your TV.
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
  • 5.Check some basics first. Make sure the sleep timer on your TV hasn't been turned on, telling your set to turn off at a certain time. If your DLP TV is acting erratically, Samsung recommends turning the set off and unplugging it for 30 minutes. After 30 minutes plug it back in and turn it back on. Unplugging the set resets it, and that may fix the problem.
  • 6 Check your power supply. Make sure your Samsung DLP is securely plugged into a working outlet. Plug the TV into a different outlet to see if the problem still exists. Make sure that a fuse hasn't blown in your house or a circuit breaker hasn't flipped.
  • 7 Replace the lamp. If your Samsung DLP is shutting off or won't turn on, a bad lamp is the most likely cause. To replace the lamp, remove the lamp cover from the back of the TV by removing the screws with a Phillips screwdriver and slide it out and away from the TV. Remove the screws on the lamp assembly and slide it out of the TV. Disconnect the old lamp and insert a new lamp into the assembly. Slide the assembly back into place and replace the screws. Do the same for the lamp cover.
  • 8 Check for signs of overheating. Samsung DLP TVs generate a sizable amount of heat. If the components inside the TV get to hot, the TV will shut itself off as a protective measure. Make sure your DLP is out 12 inches or so from the wall. Make sure that all of the vents on the set are clear of any obstructions. Allow the TV to cool down for 30 minutes before turning it back on.
  • 9 Contact Samsung. If none of the above tips help, it's time to contact Samsung, as the problem is likely something that should only be fixed by a qualified service technician. More serious problems may include a bad power supply or a bad ballast. Attempting to repair those yourself will void your warranty and may cause more serious damage to your set.
  • The safety switch exists so the user does not accidentally remove the lamp door while the TV is on. Doing so could, theoretically, result in burn or electrocution. This spring loaded switch causes the TV to shut down when the door is opened.
  • Since the TV's chasis is plastic, expansion and contraction can cause the switch to lose firm contact with the lamp door. The TV's behavior could then be such that after being on for a while (getting warm) the plastic expands and the switch loses enough contact to cause the TV to shut down. The frequency with which this phenomenon occurs is not only dependent on the internal temperature of the TV, but also the ambient temperature of the room as well as the relative tension on the switch itself. The user's perception is that the TV starts up fine, but then "randomly" turns itself off after being on for a while.
  • If you have recently moved your TV, it is very common for random shut-downs to occur. This is because the move has shifted the flimsy plastic chasis of the TV, thereby loosening the contact between the lamp door and the switch.
  • Make sure your TV is off and cool when performing this procedure.
  • Jul 31, 2010 | Samsung HL-S5086W 50" HDTV
    Samsung tv turns off on its own model hls4266wx
  • Mar 12, 2010 | Samsung HLS4266 TV
    The person I purchased this t.v from is saying the lamp was just replaced, but the FINAL WARNING REPLACE BULB AND RESET TIMER message pops up every time I power the tv on. She said she forgot to reset the...
    If the timer has not been reset telling the unit it has a new lamp you will get that message. Call a servicer to find out how to reset the timer if you don't have the owners manual. If the message continues after that you will need to purchace a new lamp. There are problems that accur with some aftermarket lamps.
    Sep 21, 2009 | Televison & Video
    Samsung DLP4663W
  • Oct 28, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
    Resetting lamp replacement warning
    Turn the TV on and press recall to clear the warning. Then hold down the volume " - " button on the tv and the PIP (Play) button on the remote for ~ 5 sec
    Apr 03, 2008 | Panasonic PT-45LC12 45" Rear Projection...
    Lamp Hour Meter
    This proceedure should work for your model to reset the lamp meter.
    Lamp Time Reset Procedure:
    Be sure to reset the Lamp time to "0" after replacing the new
    Lamp.
    1. Plug in the AC Cord, and turn on the power by pressing the
    POWER button.
    2. Press and hold the VOLUME DOWN button on the unit and
    the SPLIT key on the remote together for over 5 seconds
    in power on condition.
    When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
    Mar 29, 2008 | Panasonic PT-50LC13 50" Rear Projection...
    Samsung DLP TV HL-R5667W shuts off intermittently
    Afraid there is no simple answer to this. This set has multiple things that could shut it down, one may be the balest needs a upgrade , this could be why it seems to be eating lamps. Another is what sounds like a fan is a color wheel , these have known problems of failing, and when this happens sometimes they shut down the set. And finaly does the set have good ventalation, overheating can cause huge problems with this set
    Feb 13, 2008 | Samsung DLP HL-P5663W 56" TV
    Sharp 65DR650 65" Rear Projection Television Logo
    417 people viewed this question
    Top Sharp Televison & Video Experts
    Jaime Hernandez
    Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
