Question about Amana AEC2000 1100 Watts Microwave Oven
AMANA AEC2000 - WHAT IS THE PART NUMBER FOR THE PAPER GRILL LAMP COVER ATTACHED w/PLASTIC STAND OFFS? THANK YOU.
FOUND Assy, window kit Part Number: AP4315531 made by ACP #21 at AppliancePartsPros.com Thank You AMANA AEC2000 - WHAT IS THE PART NUMBER FOR THE - moz-screenshot-1.jpg
Posted on Jul 29, 2009
How do I change light bulb
Lamp replacement requires removal of the outer cover to gain access. There can be dangerous voltage exposed inside even with power disconnected so extra caution is advised.
Sep 23, 2014 | Microwave Ovens
Amana AMV5206AAQ light on the bottom of the microwave out
This is the replacement: Lamp, halogen
It pulls straight out of the lamp socket and the new can be pushed in.
Go here for more
RepairClinic.com
appliance parts, help & more
May 08, 2009 | Amana AMV5206 Microwave Oven
Looking to buy a top vent grille
Depends on the brand, but you can usually find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If not, Please reply back with your brand and model number so we can help you.
Feb 11, 2009 | Amana ACO1840A Microwave Oven
Trying to replace a light bulb on an amana microwave
The lamp on this model is an assembly - bulb and socket mated together.
It is mounted in an air duct on the right side of the oven near the magnetron.
You'll have to remove the outer cover to get to it.
You can find helpful exploded view diagrams and order the bulb by entering your full model number here.
Dec 09, 2008 | Amana ACM1580AS Microwave Oven
Cannot remove plastic upper exhaust fan grill for cleaning
Here are the steps to take:
1. Unplug it from the outlet.
2. Remove the two screws hidden in the slats of the grille.
3. Jiggle it up and out to remove the grille.
You can download your owner's manual here.
Dec 02, 2008 | GE JVM1850 1000 Watts Microwave Oven
GE JVM1860SF001
Be sure the oven is unplugged.
There are two Phillips head screws on the very top of the outside of the cabinet above the vent.
When they're removed the vent grille just snaps out.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 12, 2008 | GE JVM1860 Microwave Oven
Advantium Turntable On and off
I would suspect the motor is failing, but it's also possible that you have an issue with a door switch or door switch mount, depending on your model number.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the cover off with snips, then use a screw when reassembling it.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Microwave Ovens
Replacing the interior lamp inside the microwave on the top.
Yes, Bobby, it can be done. Before you begin, though, go to Home Depot and look in the tool department. There, ask for a "Husky Pro #66604". It's a 1/4" and 5/16" drive 90 degree ratchet that's about 4 inches long. While you're there, pick up a #2 1/4" drive phillips screwdriver bit. You'll use both of these to do the light. Both for about $12. UNPLUG YOUR MICROWAVE! Stand on a small ladder in front of the Microwave (MW), remove the 2 screws that hold the vent louver in place and remove the louver. You'll now see a black plastic grill (just above the door handle)remove the 2 screws with your new tools and remove the grill and the metal box that covers the relay. Now remove the 2 screws holding the horizontal metal panel that the box was sitting on. Now gently lift that panel up, (don't try to remove it) and you'll see the lamp. It's the one with 2 white wires going to it and a shiny metal cover over it. Place your index finger on the back of the cover of the lamp and gently pull toward you and lift at the same time. This will release the catch and allow you to pull it all the way out to get to the lamp. There ya go! Simple!
Jul 29, 2007 | GE Advantium SCA1000H Convection /...
Is the Advantium Mod: SCA1000HCC03 the same as the SCA1001SS?
They are indeed the same bulb, a 10W halogen. Care must be taken not to touch the lamp, as the oils from the skin will shorten its life. In many recent models, the oven must be removed from the wall (a two-person job due to safety concerns) and the cover must be removed. The manufacturers consider this a "technician-only" type job to lessen their liability. You can find helpful exploded view diagrams of both ovens and order the bulbs here: http://tinyurl.com/gv383
May 03, 2007 | GE Advantium SCA1001SS Convection /...
Oven Halogen Lamp
It's pretty simple to replace the light without having to remove the oven from the wall...as long as you have an offset phillips screwdriver...
Of course, be sure to disconnect power to microwave and be sure not to touch the new halogen bulb with fingers.
STEP-BY-STEP:
First, remove upper vent panel and remove inner filter (same directions for just replacing inner carbon filter):
Then, remove inner plastic grille (2 screws) and final screw on left side of metal "air duct" - here's where you'll need the offset screw driver (and a little patience!):
Then, you can gently lift the sheet metal panel, find the light housing, squeeze and remove/replace :)
That's it...just replace bulb and reverse for reassembly. Be sure to keep track of screw locations there are various sizes/lengths used.
Doug
Aug 04, 2006 | GE Advantium SCA1000H Convection /...
Amana AEC2000 1100 Watts Microwave Oven Logo
Top Amana Microwave Ovens Experts
William Miller
William Miller
Steven Clarke
Steven Clarke
foster_mommy
Level 1 Expert
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
