Question about Whirlpool 24 in. ADP5962 Free-standing Dishwasher
Machine starts to pump out then goes to f4 after 4 minutes
Starting up then goes to f4
  • 82 Answers
Waste pump fault or blocked pipe
Posted on Aug 27, 2009
Got a Samsung Diamond Drum WA80V3 after I put in on quick was and start it goes 22 minutes and when at 15 it goes toe rinse but then the machine just stop doing anything. Water still inside drum. Maks n...
The drain pump is either blocked or failed. Check the filter if it's clear then you are most likely up for a new drain pump. Here is a link to the part you need and a video on how to do it. Samsung DC31 00030E DRAIN PUMP B20 3 120V 60 NEW ORIGINAL
Mar 15, 2015 | Samsung Washing Machines
Fills, goes 4 minutes and fills, pauses, then fills, pauses then fills, over and over
Sounds like its syphoning out the water. If it was overfilling, you would have water everywhere, the machine would eventually flood. Check the drain hose. Make sure the end is higher than the water level in the machine and that there are no extensions running outside which have an end lower than the water level in the machine, it will start syphoning, usually after the first pump out.
Jan 01, 2015 | Washing Machines
At start up the machine goes directly to CLEAN after about 2 minutes
Step 1:
Have the same problem with my dishwasher Bosch SHE4AM12UC. Bosch authorized repaiman has been out 3 times and changed main power board module 3 times, on the manufactures recommendation--he's given up fixing it and Bosch won't help either, just tells me to call somebody else on their list and get a second opinion (of course at my expense for labor). Anyway, steps are listed below that have worked for me to keep it limping along until I can get this figured out hoe to fix it.
Step 2:
When you start machine listen for drain pump to start up. Open door and you will hear sucking noise if it is running drain pump.
Step 3:
While you have door open, hold in start button and close door (this may take several times doing this) . Listen for the water to start to fill and wash pump will start (you will hear water spraying around from was arms). Machine will start and run normal cycle once this happens. If you don't hear this within a couple of seconds of procedure above, repeat the sequence until it works. Remember i said it may take 2-3 times to make it go.
Step 4:
Hope this helps. I'll keep trying to figure this out and come up with a solution. Forget trying to get anything done from Bosch or their "authorized" repair people as neither of them have a clue on how to solve the problem.
Jan 27, 2013 | Bosch Dishwashers
Hotpoint washing machine HVF344 error code F-05 not draining
Sounds like you have debris in your drain pump., You will be surprised at all the things you find in your pump.
http://www.on-timeappliance.com/washingmachinerepair.html
Mar 28, 2012 | Washing Machines
Solis SL70 Espresso Machine: Pump Switch Light Turns Off
Mine has always worked that way; it only seems to have enough power to do a single set of 25 second shots before a short re-heat
Aug 02, 2009 | Solis Crema SL-70 Espresso Machine
Wjs 1397W. The water goes in OK. The
It was a bad joint on the motor control board. It was well burnt on one of the relay connections. I assume that the machine senses when the drive starts and then stops before changing the relays. Of couirse it only wend in one direction and was waiting for it to go in the opposite one before proceeding.
Jul 09, 2009 | Zanussi WJS1397W Front Load Washer / Dryer
Will not pump water properly
check your water pump for any obstructed items. i would need the make of your model to really explain on how the process goes to check the water pump. email me at miamidolphins08@live.com
May 20, 2009 | Kenmore Washing Machines
High pitched screeching noise when in spin cycle
Sounds like the belt is worn and might need to be replaced. Let me know if I can do anything else. thankyou for asking.
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool 24 in. ADP5962 Free-standing Dishwasher Logo
587 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
