Question about Tally Line Matrix T6050 Printer
Tally 6212 - Landscape Documents Printed Vertically
I have a Tally 6212 printer. The issue I am having is that whenever I send a landscape document to print, the printer prints the document vertically - imagine a landscape sheet of paper and then rotate it 90 degrees, that's what is printed.
The problem is that I am using legal size with the tractor field holes on the short side.
How can I get the printer to print a landscape document as landscape and not rotated 90 degrees?Thanks in advance
    Novelist:
  • 169 Answers
You do indeed have problem-- the printer is doing what you are telling it to do changing the print from Portrait to Landscape on a dot matrix printer has the same effect as that on a Laser printer, it rotates the print by 90 degrees.
The correct solution of to define a custom size of paper which is the same size as the paper you are printing on.
If you are using Windows 2000, XP, 2003 etc you can create a Custom Size paper in the following way;
  • Ensure you are logged in with administrtor rights
  • Open the Printers Folder
  • Go to the FILE DROP DOWN MENU
  • Select SERVER PROPERTIES
  • Ensure the FORMS tab is selected
  • Tick the CREATE FORM button
  • Enter a NAME for the form
  • Enter the dimensions (be careful of the units you are using --- best results use inches)
  • Do NOT set margins printable areas etc
  • Click on the SAVE button
One you have created the custom size form you should be able to select this by name in the printer driver properties and the software package you are using.
Posted on Oct 02, 2009
Landscape printing on t2340
printers>properties>general tab>printing preferences change print mode to landscape from portrait..........
Jan 23, 2013 | Tally T2340/24 Matrix Printer
Ricoh Aficio MP C3300
Go into the print driver and the machine settings and make sure the paper size and direction are all in agreement with each out and the paper in the tray itself. If screen icons do not agree with the size and direction of the paper in the tray you will have a lot of weird problems.
Jul 22, 2017 | Ricoh Office Equipment & Supplies
Printed documents have a vertical smudge
if paper goes through the device in portrait or A4, check fuser entry guide. if page travels through the device landscape or A4R look for obstructions that could disturb toner on the surface after drum but before fuser
Mar 29, 2010 | Office Equipment & Supplies
How to print document in landscape
This can be set in the properties of the printer mentioned. you can also request the landscape format in the software you are using. for most printers it is found in the TABS: finishing, paper setup.
Jan 27, 2010 | Canon PIXMA MP600 all-In-One InkJet...
UNABLE TO PRINT LANDSCAPE
To print photos in landscape orientation use Irfanview. Install this software and use it to view photos. Very easy settings are available in print options from its options menu.
To print documents in landscape, choose landscape orientation from page layout.
For all other applications, set the orientation from the printer's properties inside the control panel in Windows.
Note: You cannot adjust it to print in landscape for direct copying from the printer's panel.
Dec 03, 2009 | Canon PIXMA MX310 All-In-One Printer
Copy of documents misaligned vertically on Canon Imagerunner 3045
Hello sir; When you feed originals in portrait, the paper tray have to set by portrait direction too.
Mar 30, 2009 | Canon Office Equipment & Supplies
Do not know how to print two-sided documents in landscape mode.
This one is easy but it will take trial and error before it will work. You need to copy one side then take the same copy and put it back in drawer. Trial and error come from you making the 2nd side to see what side and direction to put paper back into the paper tray to get it correct. Hope I did not confuse you. Let me know if this helped or fixed your issue.
Mar 12, 2009 | Office Equipment & Supplies
Problem printing multiple pages on one sheet!
This is not the fault of the printer but the fault of word.
The way I did it successfully was as follow:
File > Page Setup > Layout = Landscape (sounds like you have already done this)
In the print dialoge, instead of OK, click Properties. On the layout tab, select landscape and below that select pages per sheet = 4 and then click ok... Then click OK to print.
May 22, 2008 | HP LaserJet 2200 Printer
Problem Printing word documents
yes..I agree...that line through the letters sounds like something from the font settings in word...do you have True type fonts selected? The landscape issues sound odd too, but I'm sure it's on the word settings side, not the printer.
check your computers warranty here 4 FREE
Mar 11, 2008 | Dell 922 All-In-One InkJet Printer
Tally Line Matrix T6050 Printer Logo
423 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
