Question about Roper Washing Machines
Washer walks all over when spinning how do we get to the load levelers to fix it
  • Janet Redd
    Janet Redd Jul 28, 2009
    IT DOES IT NO MATTER WHAT SIZE THE LOAD IS. IF IT IS THE STABILIZING LIQUID IN THE UPPER PART OF THE DRUM, HOW DO WE FIX IT? IT IS A ROPER MODEL RAS7133KQ0
  • 133 Answers
Does this happen even if the load on the machine is reduced? i mean less clothes............... usually there is a stabilizing liquid in the upper part of the drum which balances the drum in case of a tilt now this doesn't leak as it is sealed
Posted on Jul 28, 2009
Washer walks across floor on spin cycle and my level says its level
If the level is registering the machine as level, then you probably have an unbalanced load that is causing it to "walk." When it starts walking, lift the lid, wait until the spinning stops and redistribute the articles in the basket. I hope this helps. If you're satisfied with my solution, please rate my solution on Fixya.
Nov 19, 2010 | Amana Washing Machines
Washer walks on spin cycle, leveled unit and put carpet under it and it still walks on spin cycle only. I have had this washer for 7 years, just started recently doing this.
This is a sign of machine out of balance. If it has been OK for some time, until now, I would look at the balance springs (usually three of four holding to bowl to the outside of the machine, and see if one has come off, or is rusted through. Either fix or replace.
Does the machine spin just fine with no washing in?
2TRP
Jan 13, 2010 | Maytag PAV2300 Top Load Washer
Model MAH9700 - Washer travels across floor in the spin cycle
I suppose that the repairmen would know than I would, but I do know that any washing machine that is not level will walk and vibrate and really shutter on the spin cycle. I would try to level (using a level on the top part of the machine that is flat, if there is such a portion) the machine so that all four feet (pads) are secure with their locking nuts up against the body so that they can't turn and cause the machine to go out of level.
Sorry I can't be of more help.
Oct 12, 2009 | Maytag Neptune MAH9700 Front Load Washer
WHEN IT SPINS IT WILL WALK ACROSS THE FLOOR
the washer is not getting a balanced load need to adjust the clothes inside so it wont jog
Jun 02, 2009 | Washing Machines
Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Apr 03, 2009 | Washing Machines
Spins so harder washer walks across the room. the washer is level. the load is balanced. is it the tub inside the washer that is not level
Engage your lid switch so that washer will spin in spin cycle and watch it spin. At end of cycle when washer shuts down the tub should come to a fairly sudden stop if it doesn't then you need to have the brake worked on. If it does post your model number and i'll advise further.
Mar 11, 2009 | Roper RAS8445KQ Top Load Washer
Whirpool Duet "walking"
Hi, most of the time this can be a simple as a overload that will dramatically shake this type of washer. due to its front load design, it is recommeded to load accordingly to specs. overloading this type of washer will induce walking/excessive vibration during the spin cycle.
Mar 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer is "walking" during the spin cycle
I have the same Duet that vibrates heavily during spin cycle. Leveled the unit with no success (our unit is mounted on the high base). Long story short, I went to Lowes and purchased a package of 4"X5" self stick foam rubber pads called Grippers by Wasman Consumer Group and paid a low price of $3.50. Since the washer walked forward, I cut one of the two Pads in the package in half, removed the sticky side paper protector and centered a half, sticky side to washer pad, to each front washer pad. The problem was solved.
I made sure the round floor pads of the washer were tight and the unit was level before attaching the Grippers. Hope this helps.
Jan 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Walking during the spin cycle
Try placing it on a rubber mat or carpet that has a rubber backing. The floor may be too smooth and allows it to walk.
Oct 12, 2007 | GE WSXH208A Front Load Washer
LG1812CW Walks During Spin Cycle
The rear 2 legs are fixed. The front 2 are adjustable. There are lock nuts to prevent the adjustment from coming loose. The front legs are to be adjusted to the minimum. While not running if the machine rocks, continue the adjustment. For few clothes there is a half load switch; best the read the manual well before anything. Well if the walking continues, check the rear for any shocks or springs that may hv fallen off during transport. Plug off the wall socket first.
May 28, 2007 | LG WM1812C Front Load Washer
Washing Machines Logo
55 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
