Dell 1710n Laser Printer Logo
Posted on Jul 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to reset to factory default Dell 1720 network printer
I use a lot of dell laserjet 1710 and 1720 network printers.One was configured to static IP-Address and connect to the network.I have no problems to PINg from any my Lan, but I cannot Telnet, HTTP, dell printer utility do not recognize printer. Help me how in this situation can I reset printer to factory default.
2000 times thank you
Alex
  • Anonymous Mar 14, 2014
    reset dell 2130cn to factory defaults
Anonymous
Level 2:
  • Expert 320 Answers
  • Posted on Aug 28, 2009
Anonymous
Expert
Level 2:
Answers
320
Questions
0
Helped
144281
Points
596
1. Turn off the printer
2. Open the front cover.
3. While the Continue and Cancel buttons are depressed, turn the printer on.
4. When the error LED on the control panel is lit solid, close the cover.
5mm vertical gap dell 1720dn
Any time an imaging drum is replaced on a 1700, 1710, or 1720 model dell laser printer, you must reset
the photoconductor count. The following procedure illustrates how this is done:
1. Open the front access cover
2. Press and HOLD the Cancel Button (Red X)
3. When you see the LED's 'Chase' turn the printer off
4. Close the access cover, and turn the printer back on
5. Press the Continue Button (Green Triangle) to print a settings report
6. Under the section 'Cartridge Information', locate the item 'PHOTOCONDUCTOR COUNT=0K' indicating 'Zero Thousands'.
s now been reset, and you should now be able to print now ok
How to re configure ip adress
Go to the "Resets" menu and select the "RESTORE FACTORY SETTINGS" selection. This will revert your machine to the condition that it was in when it came from the factory. Remember, the default for networking is DHCP, so once reset and online, you could use the web interface to configure it further.
2helpful
How do i perform a cold reset on a laserjet 2600n printer
Via the Control Panel: The Resets menu makes it possible to reset factory settings, disable and enable Powersave, and update the printer after new supplies are installed. Configure device menu The Configure device menu makes it possible to change the printer's default print settings, adjust the print quality, change the system's configuration and I/O options, and reset the printer's default settings RESTORE FACTORY SETTINGS :Makes it possible to clear the page buffer, remove all perishable personality data, reset the printing environment, and return all default settings to factory defaults. Press Menu or (Select) to enter the MENUS.
  1. Press (Down Arrow) to highlight Configure device menu .
  2. Press (Select) to select Configure device menu
  3. Press (down arrow) to System setup menu
  4. Press (select) System setup menu
  5. Press (select) Resets menu
  6. Select RESTORE FACTORY SETTINGS.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
1720dn Laser Printer: printer offline. unable to set online....
I Open my browser....I signed in to my router as administrator ....
Mine is 192.168.1.1 ....
I went to status in my router ....
Then to local network ....
Then to DHCP Clients Table ....
This is how I found what printer address the was.... Then I typed the printer ip address into my browser
Mine happened to be 192.168.1.105 ....
Yours will probably be different....That got me to the 1720dn printer menu ....I clicked on Configuration ....
I clicked on Print Server Settings
I clicked on TCP/IP
I clicked on Set static IP address.
I changed IP address from 192.168.1.105 To 192.168.1.125
and Submit....Now you can get to the printer menu at 192.168.1.125
Go to run....
Printers & Faxes
Right click on Dell laser printer 1720dn
Properties. Ports ....
Add port ....
Double click on Dell Enhanced TCP/IP ....
I named the port My dell laser 1720 dn....Where it said enter a single IP address or host name I entered the new address 192.168.1.125
the clicked OK ....
Properties....Ports
Choose your new port ....
1helpful
Dell color laserjet 5110cn will not print any color documents.
This could be a hardware problem, but likely it is a driver or default configuration problem.
If this printer is hooked up to the network and you print to it through a print server, the default print setup or driver could be incorrect or misconfigured.
Whether it is hooked to a network or not, check to be sure the driver is correct under the printer's properties.
Also check to see if it's default settings are set for it to print only in black and white. Both can be done through the printer's properites.
Where can i find a installation disk for the dell 1720 laserjet printer tryed to download them but no luck
click here
click on above link then select your operating system and download driver then install.
Let me know if you need more assistance.
Thanks.
Dell Laserjet 1710 - won't take the paper from the tray
clean the paper pick up roller and check any paper pieces is there
82helpful
3answers
Dell 1720 flashinf replace drum- error.
The second link was the helpful information. Also, to cut through all of that --
If you need to reset the counter:
1. Remove drum kit with toner
2. Make sure all print jobs are flushed otherwise whatever has been sent and not printed will come spewing out.
3. Hold down CANCEL Button until all lights flash through.
4. Slide the drum kit and toner properly into the Printer.
done.
2answers
Dell 1700/1710 Ready/Data light only indicators, can't reset
hmmm..that's a bit odd...can you do a system reset from menu, to defaults?
3answers
Dell 1710
it's in the menu, under settings. reset to default and then power cycle it again...sounds like your memory is a bit corrupted(comes from power glitches)
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
