Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
Where is the fuse located? I have the pocket steamer
I have no light or power when plugged in. I opened the unit up but could not find the fuse location. Is it inside the aluminum tank?
    New Friend:
The fuse is up against the tank wrapped in transparent yellow plastic with clear heat-shrink under that. It is hooked to the bottom of the aluminum tank.
Posted on Mar 22, 2016
  • Euro-Pro Master
  • 43,501 Answers
Nope, no fuse...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Sep 24, 2010
Steamer problems
The light is connected to the heater if it is not working but the unit still gets hot the light may be faulty
If the unit does not get hot then there is a problem with the power getting to the heater element.
The fault may be in the switch
Aug 08, 2014 | Eureka 313A Stick Steam Cleaner
Where is located the fuse in a vacuum claner Kirby ultimate G?
There's no internal fuse, it is in the plug (UK version anyway). Not sure on US version.
If the unit is dead it could be several things. Bag and brush roller not fitted correctly you can check this yourself, motor brushes worn out, broken power cord etc.
Jul 24, 2014 | Kirby Ultimate G Bagged Upright Vacuum
Cuisanart 10 c programmable coffeemaker won't work; no light comes on & it is plugged in. It has been working fine.
Check it's fuse inside, a blown or open fuse will cause won't work. Similar also happened if the cord wire is already open. Same goes also if the power switch is already defective. Either of those I mentioned will cause the unit not to work.
Thanks for asking.
Jun 25, 2011 | Vacuums
Cleaned inside of microwave with all purpose cleaner, now it runs but does not heat up food.
Remove the plug from the power point and make sure that you completely dry the inside of the microwave with a clean dry cloth , keep the door open for drying. If by any chance the liquid or the water has seeped into the magnetron port then it might have clogged and damaged the unit.
Please check this section inside the chamber and dry this soft spot fully before you can try to switch on the microwave.
If this wont work then check the fuse inside the unit and the thermal cut off switch if this has tripped.
Mar 16, 2011 | Vacuums
I have a shark steamer, light is on but no steam. ...
Nope...no cleaning to it...
heatman101
May 20, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark Euro pro mop the ligt wont turn on anymore.
my husband fixed my shark steamer by taking it apart and testing it wire by wire .the problem ?a fuse hidden inside the unit..unscrew the screws and get inside the steamer .at the bottom of the steamer there is a gold orange foil looking piece .under that is a small fuse .unless you can find another fuse just cut that one off and rewire the wires together .shark now comes on
Sep 27, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My steam vac deluxe does not have enough suction to pick up water
For the brushes:
The power wire may have slipped off. take apart the unit at the top (Behind the cleaning fluid container) Inside there is a wire coming up from the motor at the bottom of the unit. This can come unlpugged no longer powering the scrub brushes. Simply slip the wire back on the plug.
To open: remove all visible screws from top half of machine. Remove the rubber mode dial by pulling off, and remove screw behind that. Pull the front off, and the power plugs are located right on the inside of the machine by the mode dial.
for the suction, check the intake hose the comes out from behind the floor assembly. it tends to split over time
Aug 04, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
581 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
