locky1620 Posted on Sep 13, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am getting a blank page in between each copy everytime i print ????
robert
Level 2:
  • Expert 33 Answers
  • Posted on Sep 13, 2017
robert
Expert
Level 2:
Answers
33
Questions
Helped
10495
Points
109
I'm assuming your printing from a computer. try making your header and footer smaller. look at your print preview and adjust your text font if it runs into the next page. You can also select to just print a single page instead of ALL to see if everything fits on the page.
5 Related Answers
Anonymous
  • 1665 Answers
  • Posted on Apr 21, 2008
SOURCE: canon imageclass MF 6550
See troubleshooting at service manual . Jets may be clogged
Anonymous
  • 142 Answers
  • Posted on Jan 27, 2009
SOURCE: Printer sends out extra page everytime I print
either your paper size settings need to be adjusted in the software, or your setup has included a seperator page.
Joed911
JDTec
  • 4338 Answers
  • Posted on Apr 08, 2009
SOURCE: printer goes through motions to copy doument but pages are blank
From Kodak's website: Question : Why are prints from my all-in-one printer blank? Answer : There may be multiple reasons why your prints are blank. To resolve this problem, we have an easy Step-by-Step Solutions and Repair tool.
Within the tool, select Print quality, then Blank prints.
Start @ this link:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=10355
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Anonymous
  • Posted on May 18, 2009
SOURCE: Blank copies
Thanks Guest with Best Solultion! OMG! I have had my machine printing blank for over a month now and reading stuff and trying to find a solution. Until finally today I found this page. I read your solution and hit the front like u said for several times and nothing. Finally, after the third try WALA...IT WORKED!!! Thanks again. If anyone has this same problem try this because it really works! Eventhough this is such a strange problem for such an expensive machine.
Anonymous
  • 3153 Answers
  • Posted on Aug 19, 2009
SOURCE: Everytime I try to print , all i get is a a blank page
If you are using it on a MAC there are known issues.
If however it is a pc then maybe you should check your ink levels using the software that you installed with the printer.
Have you recently replaced the ink cartridges and if so did you use original HP cartridges ?
If you didn't use original cartridges then there is quite a good chance that they may be faulty and should be returned to where you purchased them for replacement.
If you did use original cartridges did you remove the tape on it before installing ?
Check by doing the cartridge replacement steps and take out any cartridge you may have replaced recently and check that the pull off tape tags are removed.
3answers
Why am I getting only half page of a copied email. Plus I always get a blank sheet of page at the same time.
Are you talking about a page printed from a printer or something on your screen? I need some more information before I can help you. It does sound like you are describing a printer problem and if it is, does this happen when you try to print anything else?
Copy Machine is printing copy and then an additional blank page. How do I get this fixed?
The margin and headers and footers are to big. Select do not print hraders and footers.
HP CM2320 MFP blank pages come out with printout
Hi my hp cm2320 nf prints normally and prints when you press the color copy button. But it will printout only blank page swhen you copy black&white. You press the black&white copy button only blank pages come out. Any help
Lang Dibba, Gambia
I am getting a blank stripe top to bottom on every printed page
You write "I am getting a blank stripe top to bottom on every printed page". You didn't say copy or scanned pages. Change the toner cartridge.
I have an HP C7280 AIO printer. Everytime I print, it always form feeds a blank page bewteen each printed page (print page 1, form feed a blank page, print page 2, form feed a blank page, and so on).
Generally, there are printer set up programs that will let you chose to put a blank sheet or to not do that. If you have a disk or manual, look for the set up utility and go thru the tabs to find paper handling or something similar to that. There should be a check box you can clear to stop the blank page.
I hope that this information was helpful. Have a great day.
Brian
2helpful
Printer won't print
Printing on stand alone has a big difference when printing from pc.... try using the kodak website for this issue www.kodak.com/go/itg and use "image quality and blank page" for subclass
3answers
Copy Problem
is scaning working properly? check the scanner section.
Top In Office Equipment & Supplies Experts
Paul Carew
vince
Are you an In Office Equipment and Supply Expert? Answer questions, earn points and help others
