Question about HTC Touch P3450 Smartphone
My storage card is not opening ...why - HTC Touch P3450 Smartphone
  • 74 Answers
Check to see if the card is locked, there should be a small slide switch on the side of the card if not try to format it in the phone (if there is a program to do that) or put it into a card reader on your pc and format it that way WARNING you will lose all data on the card
Posted on Jul 28, 2009
How to down load films to a 32 GB card Hudle2.Thanks
OK, to accomplish this you need 2 hings:
1. A micro sd card. (Which I gather you already have one)
2. File manager installed in your tablet.
Now, if the tablet support micro sd card, you are all set. Download the file manager, it could be Astro, ES File Explorer, etc...
Once installed, open the file manager. The tablet storage, which is known as internal storage, it is display as sdcard/storage (or sometimes as internal storage). Once you tap the internal storage, everything that is installed in your tablet will be display; (Android, DCIM, etc...) Now you need to look where are the pictures or films saved at. It is usually DCIM/Camera. Once you have found the pictures that you want to move or copy, long tap the films, depending on the file manager app, you must tap copy or move (NOTE: Since every file manager is different, some takes a little bit of extra steps, others requires for you to open a menu). Once you had chose to copy or to move it, look for the external sd card location, which will also be located at sd card/storage/ (32gb external storage) and choose this location to paste your films or pictures.
Another way is by using a computer. Make sure that you have all the drivers needed for the computer to recognize your tablet, you also need the usb charge cable. Once the computer recognize it when the tablet is plug in to the computer, open it by double clicking, there should be 2 storage display under the tablet folder: Internal storage and 32gb. external storage. Open the internal storage, look for where the films are saved (just like I explained with the file manager), choose the films that are to be move or copy, and jus drag and drop or press ctrl and C to copy, go to the external storage, open it and press ctrl and V to paste.
Jul 10, 2016 | Tablets & eReaders
How can I download music to my fusion2 phone
First you:
2.9.1 Using the microSD Card as USB Mass Storage
To transfer all your favorite music and pictures from your PC to your mobile phone's microSD card, set the microSD card as USB mass storage.
1. Connect your mobile phone to your PC with the USB cable provided. Your PC will detect the microSD card as a removable storage device.
2. Open the notification bar, and then touch USB connected.
3. Touch Turn on USB storage in the dialog box that opens to confirm that you want to transfer files You can now transfer files from your PC to your mobile phone's microSD card. When your microSD card acts as USB mass storage, your mobile phone will not use this memory space. Ensure that you follow the correct procedures to disconnect the USB mass storage device (your mobile phone) from the PC when you have finished transferring files.
Then:
8.3.1 Copying Music to the microSD Card
1. Connect the phone to your computer with a USB cable and mount the microSD card.
2. On the PC, navigate to the USB drive and open it.
3. Create a folder in the root directory of the microSD card (for example, Music).
4. Copy the music from your computer to the folder you have created.
5. After copying music, unmount or eject the drive as required by your PC's operating system to safely remove the mobile phone.
6. Disconnect the mobile phone from the PC.
Once done open music player and play music.
Ref: http://www.att.com/support_static_files/manuals/ATT_Fusion2.pdf
Dec 13, 2012 | Computers & Internet
How do i go about accessing my images,music on galsxy s2 via pc
When you connect your cell phone with the supplied USB cable and then connect it to your computer's USB port the computer should detect the cell phone as an USB storage device which you can then open to download to your computer.It this does not work then -
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB mass storage device oran external storage device, you can then open the folder on the memory card andcopy the photos to your computer.
Jan 01, 2012 | Acer Computers & Internet
How to format my phone
hi
Remove the storage card from your device, insert your storage card to card reader and plug it in your PC, open my computer, right click on the storage card drive icon, select format.
This the best way to format card and if you want to format entire cell then you have to do it just manually deleting files and contacts.
or
i suppose, by formatting, you mean to reset the phone to the factory settings.. you can do it by start > settings > system > clear storage or else you can do it by pinning the reset hole with the help of the stylus
hope it helps
Feb 19, 2011 | HTC Touch P3450 Smartphone
I dont know how to open mobile net
u using this network sim card. send the mes and give the ur mobile save it .and help line the sim card and tell the mobile net open.
Apr 11, 2010 | Chi Storage Solutions NAS 2000...
Storage Card problem in HTC p3400i
my storage is not viewing files it have now...its a 2gb sd memory card.storage space will show when we check the properties but cant see those files when we open..
Aug 13, 2009 | Cell Phones
I CANNOT VIEW MENC FORMAT
The .menc extension is the indicator that tells whether a file is encrypted. The purpose of the extension is to indicate that you can't open those files. A Lock icon is also associated with the encrypted files.
When you insert the storage card back to your device where the files were encrypted, the [GUID] will match with the decryption key on your device and the [GUID].menc extension will not be displayed. Encrypted files will appear just like normal files and they can be opened.
Decrypting files:
To decrypt files that are encrypted, the current solution is to transfer them from the storage card to a computer via ActiveSync or Windows Mobile Device Center, and then copy them back to the storage card after the Storage Card Encryption has been disabled on the device.
  1. To disable Storage Card Encryption:
  2. Go to Start>Settings>System Tab>Encryption.
  3. Uncheck the box that says “Encrypt files placed on the storage card.”
  4. Tap OK.
Jul 02, 2009 | HTC Touch Viva Cell Phone
"Not found Storage Card."
there is a loose part inside it is usually a ribbon.. connected to your device storage and its reader if you can open and return your device try to do so, if not cpntact your device vendor.
Jun 25, 2009 | Samsung Blackjack SGH-I607 Smartphone
Failure to recognize storage card
Do you have somewhere else that you could format the card - camera, PC ??? Also you could try Pocket Mechanic which has a free 7 day trial... http://www.pocketgear.com/software_detail.asp?id=12178&associateid=373.
Sep 07, 2005 | HP FA162A for iPAQ 2215/4155 Keyboard
HTC Touch P3450 Smartphone Logo
51 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
