Question about Locks & Locksmithing
I have two PFK electronic touchpad locks. Installed both about 1 year ago. They worked perfectly until 1 month ago and both started beeping and then emitting a long shrill beep. Then it would just start beeping short beeps until the long shrill beep once again occurs. I have replaced batteries with new alkaline batteries. I have attempted to reset the passcodes for position one and two. I have gotten them to work for one or two openings then the beeping starts over. Is there a way to clear the memory entirely and start fresh. It appears that the lock thinks an errant passcode has been entered more than once and this is its way of telling me that.
    Brigadier General:
  • 8,619 Answers
Hi
Try and reset the lock by Logging in (as admin), then press the down key 5 times using the arrows. Now input the letters “aaaa”, then hit the check button to reset. Also check that timed modes(if supported by the model) are not currently turned on.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 28, 2009
Key pad doesn't work
Here is the link to the troubleshooting procedure:
The Weiser brand and Kwikset brand Powerbolt are identical (Black & Decker), so these instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Notice that the above is a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Now for Weiser Support:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Troubleshooting Tips
If Electronics Are Not Working - Check the Following:
Are your batteries good? Is the power strip plugged in properly? (See step 4.6)
Are the batteries installed correctly and making full contact? (See step 4.8) You should hear a series of quick beeps when batteries are installed correctly and making full contact.
Handing of Your Door
If the bolt does not extend when lock button is pressed, check the handing of your door (See Step 4.9)
Preset Factory Codes
This lock will maintain two different codes.
Two random codes are preset by the factory for testing. It is recommended that you enter
two new security codes to cancel out the preset codes. (See step 5).
Problems with Setting your Security Codes - Check the Following:
You will hear a 2 second beep when your codes are accepted. (See step 5.1-3).
If the unit does not beep - too much time has elapsed between steps 1 & 2. Repeat these steps faster.
Note: You have approximately 3 seconds between step 1 & 2 for your codes to be accepted. Please note the next statement.
Unauthorized Code Warning:
For your added security, a warning tone will sound for 15 seconds if an incorrect security code is entered three times consecutively. The Touchpad will not operate for 1 minute.
Note: If several attempts were needed to set your security codes - you may have activated the warning sound. Wait 1 minute for the unit to be operational again.
For assistance call
1-800-343-9652 USA
1-800-501-9471 CANADA or visit www.powerbolt.com
After all this, it will probably come down to replacing the keypad assembly. If your lock is less thatn one year old, it will be covered by warranty.
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem. You will want confirm that you need the part before you go through the expense, and that it's worth it. You will need to know the "finish" of your lock. Try to talk them into warrantying the part, in spite of the age (one year warranty on electronics), as a matter of good customer relations. They will help you get the correct part on order.
I will strongly urge you to consider the cost of the replacement part versus the expense of a new lock. Look into a Schlage if you do. I've seen more problems with the Powerbolt than any other electronic lock.
Sep 11, 2012 | Weiser Lock GED1460X26D Satin Chrome...
Rona keyless touchpad keeps beeping
Mark,
Thank you for the feedback. I've never been able to find any information on RONA keyless locks. This is one for the files!
Apr 09, 2012 | Locks & Locksmithing
Began to beep in intervals. Changed batteries and it worked a couple of times then beeped twice then touchpad will not work, Five minutes later it beeped steadily for 10 seconds than stopped. Will not...
Why is my Powerbolt 1000 unit beeping?
This is the relevant excerpt from the Powerbolt programming and troubleshooting instructions:
"To determine why your lock is beeping abnormally, please follow these steps:
Take out batteries and unplug powerstrip.
Let it sit for 1 minute, then put the batteries back in and wait another minute.
If it does not beep, the keypad needs to be replaced (17733-1).
If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish)."
Since you've already gone through the battery change, try the battery remove-reinstall recommended above. If that doesn't work for you it suggests that you need to replace the appropriate Powerboard for your lock.
So this is the link to Weiser Customer Support Page, where you will find the appropriate number of your location:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
Good luck--and please provide feedback if this helps!
Sep 22, 2011 | Weiser Lock Powerbolt 1000 Lock
System will not retain a code.
Dear Kwikset User 1sharpmc - we're very sorry to hear about the difficulties you've had with our product. Please contact our Customer Support team so they can help get your product working properly.
Kwikset Consumer Service
1-800-327-LOCK (5625)
Jul 21, 2010 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Hi dear i have lngersoll deatbolt rim lock front of my door. i wanted to replace the only rim cylinder but i dont khow how to remove old rim cylinder. also can i use other company,s rim for my old...
The lock is removed after you undo the bolts on the inside The whole cenre should slip out. I doubt you can use another brand in the rim that will mate up with the equipment inside the house side of the door But you can completely replace it in the alreaqdy made hole
Aug 30, 2009 | Deadbolt PFK Touchpad Electronic Lockset
Dear Sirs: I have a Weiser keyless locke
  • Take out batteries and unplug powerstrip.
  • Let it sit for 1 minute, then put the batteries back in and wait another minute.
I contacted customer support... they tell me the FAQ information on their own website is incorrect. The opposite is true, therefore the following is correct:
  • If it does not beep, the powerboard needs to be replaced
  • If the unit continues to beep, the keypad needs to be replaced
Here in Canada, they will send you a new one within 3-5 days free of charge. Call customer support:
Canada: 800-501-9471
US: 800-677-LOCK
-=dån=-
Jul 15, 2009 | Weiser Lock Powerbolt 1000 Lock
Intermittent beeping
US: 800-677-LOCK
The woman was very friendly. Great customer support!
-=dån=-
Dec 09, 2008 | Kwikset UltraMax Powerbolt 1000
Kwikset smart code touchpad electronic deadbolt
I have the same problem, electronic locking system went dead but still beeps, stuck using keys now...according to the kwikset website though it says "Warranties cover the original residential user of Kwikset Products against defects in material and workmanship as long as the original user occupies the residential premises upon which the product was originally installed." so hopefully they will fix the problem
Oct 12, 2008 | Deadbolt PFK Touchpad Electronic Lockset
Kenmore HE 2 Dryer
sounds like the problem is in the user interface(pushbuttons and knobs)check your warranty some models came with 2 yr warranty on electronics
Aug 25, 2008 | Kenmore Elite HE4 Electric Dryer
Touchpad doesn't work, F1 code
Most likley you have a bad touchpad. Most times its a key that is stuck and there is nothing much you can do except replace the touchpad control. It is a common problem with all electronic ranges. If the range is 13 years old I would thik about replaceing it. Good luck
Jul 15, 2007 | GE JBP90 Electric Kitchen Range
Locks & Locksmithing Logo
43 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
