download the nokia calculator in your computer, input the IMEI code which you can find behind the battery. Then after you input the code, it will generate the unlock code that you can use.
SIM or phone lock code? If it's the phone lock code... Power off phone.
Press and hold Green, * and 3 and keep them held whilst powering on and
for a few seconds after, if kept pressed this formats without asking
for Security Code confirmation.
thanks for wanting help. if u don't ur default security code then ur default code 12345. but changed it and then its way to reinstall ur phone application. thanks
hi
find the PUK 16 digit code from your service provider and try the lock code in a couple of combinations once it asks for the PUK code unlock using the PUK code and the lock also will be reset
hope this helped
cheers
if this has been aby bit useful pls rate it, thanks
I need the IMEI (International Mobile Equipment Identity) number. Type this code in your phone to get it: *#06# you can also find it beneath the battery. I also need to know the network that the phone is locked on, and the country the network is from. Then I will give you the codes.
Hi if your phone is asking for securtiy code when you switch it on then i can give you the master code to reset the securtiy code to what it was when new but if you can acess the phone and just forgot your security code and want to change it to do this you will need a flash lead and unlocking software if as i said the phone is asking for scurity code when you switch it on then if you give me your imei number its on back of phone under battery and looks like 123456/12/1234567. it should be 15 numbers long give me this code then i can get you the master code ok let me know and i can assist you further ok
