Question about Dual XDVD8181 Car Video Player
Tuner wont save settings
Every time i turn off my car. and turn i back on my tuner setting will go back to the first stations programed from factory. i try-ed to switch my ignition and batter ie wire but did not work.
  • 709 Answers
Re: tuner wont save settings
Hi Matt1983,
You must have Battery + power on both the Yellow wire at all times. To get the Radio to operate, you need power on the red and yellow wire. Battery neg(-) is also imprtant, Besure your Black wire is definitly connected to the frame of the care and you can read voltage from the supply power to the black wire. Sometimes you have to remove paint from the area you connect the Black wire.
Posted on Nov 23, 2007
0 characters
3 Points
Avh-p3200bt no data provided on FM tuner
That's an RDS issue...Radio Data System. Check the settings on your device to see if this service/feature is even available with this unit.
Feb 09, 2013 | Pioneer Car Video Players
How to reset map update message on jvc nx7000
Here's the solution from the JVC Customer Service. BE WARNED: this will wipe out all your customizations, including but not limited to favorite addresses and radio station names.
"As for turning off the message about the maps on the radio, please follow the next steps.- Please follow this procedure to perform a factory reset and remove the message.
1. Turn ON the radio
2. Set the Source to "Tuner" mode
3. Simultaneously press and hold the [Disp], [Map] and [Down] buttons for more than 2 seconds
- You must press the buttons in that order
4. When the "Service Menu" Screen appears you may release the buttons
5. Touch the UP/DOWN arrows to highlight "Initialize All"
6. Touch [Enter] to initialize the unit
7. The unit will be initialized and the unit will reset on its own.
Apr 20, 2012 | JVC KW-NX7000 Car DVD Player
Clarion NZ500 installed - will not retain any settings each time it is turned off and on (i.e., radio station settings, volume, etc.)..
Check if the yellow wire is connected to a 12 volt direct source,because this wire feed the memory back up of the stereo good luck
Aug 19, 2011 | Clarion NX500 Car Video Player
I just bought a car which has a Planet Audio P9725B, so i would like to save/change new radio stations on the memory, how can I do it??
To set your station preset, change to the desired station and hold the numbered preset for a few seconds and it will stay there
May 07, 2011 | Planet Audio P9725B / P9720 Car Video...
How to get the dvd player to play threw my truck speakers?
if you dvd play came with a wireless fm modulator read the owner manual and set up the fm station to get it to work . if it does not have a built in fm modulator you need to buy one.
the pull out your radio and run power to the fm modulator and then connect the factory anntenna to one side of modulator and the other side goes back to your factory antenna location at radio . then set the fm station you set for the fm modulator run a set of rca cables from the fm modulator to the dvd flip screen and it should work . i would think your flip screen dvd play would have a built in fm modulator that is wireless .
Oct 28, 2010 | Insignia Mobile DVD Player with 9.5"...
PXA-H700 optimum set up...
The way the EQ is hooked up is correct.
You set the factory radio to a set level, then use the volume on the EQ for everyday adjustments.
I believe your problem lies in the amplification.
Your BOSE amplifier was made to run a 4 channel 8ohm stero load.
Low powered - high in sound quality.
You have swapped the factory 8 ohm speakers (15W) for 4 ohm power hungry ones.
Now the amplifier is working harder to produce the same output.
You would be best served eliminating the factory amplifier and getting 1 good 4 or 5 channel amp to power your speakers.
a 4 channel amplifier could be used stereo (left and right) on channels 1 and 2, (2ohm stereo load)
and bridge channels 3 and 4 for your subwoofer.
For a true surround sound - a 5 channel amplifier could run each speaker individually, and the 5th channel is reserved for the subwoofer.
a small dedicated 75wx4 channel amplifier with built in crossover, and level gain controls - would blow your socks off. It is 200x better than the factory 12Watt amplifier. Your ears will love you for it :D
If you need more help - just let me know.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 23, 2009 | Alpine PXA-H700 Car Video Player
How to set the clock on Pioneer car stereo Super Tuner 3D
ok what u do is turn radio off hit clock so that it displays the time then hold audio button in until clock starts flashing then use your arrow ****. not your vol. ****.
Mar 04, 2009 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
Preset radio
The best way to do this is to be very patient. find the station you want to preset and simply touch and hold the number you want to save it at on the touch screen. the station will pause for a split second and then you will see it on the display of the presets
Feb 05, 2009 | Clarion VRX485VD Car DVD Player
Region problem
Try this for the tuner fix. Turn unit on.Hold down (volume down and SRC )buttons and unit will power off.Keeping them in also press and then release the reset button(bottom right hand side) .Release the other 2 buttons and unit should now restart with 50khz fm spacing and 9khz am spacing.If you find out how to change region code,Post It
Jun 09, 2008 | Kenwood DNX7100 Car Video Player
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Nov 26, 2007 | Kenwood KVT-617DVD Car DVD Player
Dual XDVD8181 Car Video Player Logo
74 people viewed this question
Top Dual Car Video Players Experts
Sudeep Chatterjee
Sudeep Chatterjee
Brian Hogue
Level 1 Expert
Are you a Dual Car Video Player Expert? Answer questions, earn points and help others
