Question about Garden
FORWARD AND REVERSE GEAR SELECTION BACKWARD
I HAD JUST CHANGED THE DRIVE BELT AND PUT EVERYTHING BACK THE WAY I TOOK IT OFF BUT NOW THE FORWARD AND REVERSE GEAR SELECTOR IS BACKWARD. I PUT IT IN FORWARD AND GO BACKWARD AND VISE VERSA. THIS IS AN MTD/TROYBUILT 42'' HYDROSTATIC DRIVE.
  • 1 more comment
  • jerome_noel Jul 28, 2009
    There is a PTO, to change the drive belt I had to pull engine up off the frame as the manufacturer put permanent tabs to hold the drive belt in place around the fly wheel that drives the trans. belt
    do I need to pull it off again? How would I correct the reversal of the gears?
    Thank you for your help and your time today
    President:
  • 986 Answers
Recheck your belts, does your engine have a pto
Posted on Jul 28, 2009
  • 1 more comment
  • Donnie Wilson
    Donnie Wilson Jul 28, 2009
    since it has a pto tha is how you get you reverse,the camshaft is what drives the reverse,it rotates the oppisate direction of the crankshaft,
  • Donnie Wilson
    I am just wondering if some linkage moved on ya,could have something triped over
  • Donnie Wilson
    I dont think would have take it off a again just look at the linkage and see what cold have moved
Craftsman yt3000 model no. 917.288517 changed v-belt drive when put in gear to go forward it go's backwards put in reverse it go's forward ?
You've obviously performed the v belt replacement bass-ackwards. Recheck the belt routing scheme in your manual.
Jul 16, 2017 | Craftsman Garden
The tines are not moving forward on my Rotavator. The engine is Tecumsah Vantage 50. The tines move backwards and the engine seems fine. The rotavator will not move forward
I have seen a number of domestic rotavators but haven't yet seen one with a reverse gear. You didn't make it clear in your description whether yours has a reverse gear and that is all that is working or whether it usually only moves forward but is moving backwards?
While it is theoretically possible for a 2-stroke engine to run backwards, your engine is a 4-stroke that is incapable of running backwards and so it would seem the gear selector is stuck if it has one or someone has carried out repair work and made a mistake or something else is broken.
The only thing that comes to mind is some of the older designs used an over-long drive belt that crossed in the middle like a figure eight in order to reverse the driven pulley and replaced the belt with one that seemed the right size would cause the machine to run backwards.
More information needed, perhaps...
Jul 24, 2016 | Garden
2001 hyundai elantra goes in2 reverse but won't go backwards all other gears r perfect
Most automatic transmissions have a separate belt for reverse and all forward gears, The reverse belt is commonly lighter duty that the forward belt (some Chryslers were affected so much it was advised to not shift into reverse until the engine had warmed up and the automatic choke idled down) Thus your car would be in "reverse" but with no motion getting to the gears.
Jun 04, 2016 | 2001 Hyundai Elantra
In turbo hydro 700 why would forward gears make the rear wheels go in reverse
Your differential is upside down. Ford model T's had the same problem. It was possible to mount the rear axle upside down which made the car go forward in reverse and backward in forward gears.
Mar 07, 2015 | Cars & Trucks
I have Troy-Bilt storm 7524 snow blower which normally works fine, however, it has started to have problems shifting back into forward gear after being reversed. I'll put the snow-blower into reverse gear...
Try lubing the linkage where it shifts from forward and to reverse the linkage is most likely freezing up or has snow or ice build up causing it not to shift, My thought is your shoving it hard enough that it finally engages when you get the snow or ice to break off.
Jan 05, 2010 | Garden
Ichanged the rear drive belt on my 17 hp
Ok, I see it's and MTD product. Did you replace both belts? The front belt is #954-0280 and the rear belt is # 954-0370. What I would suggest is remove the cover plate between your legs. You'll have to remove the shift knob and two screws. Start the engine, put the gearshift in nuetral and let out on the clutch pedal and observe what's happening. Everything will be working the same as if you were in gear. You should be able to see if there is a problem with one of the belts or the vari-speed pulley. Put the speed selector in 7th (or 6th) gear and push the clutch down then back up, and watch what going on. That's the best I can do without seeing it myself. Hope this helps.
Jun 21, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
428 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
