Question about Samsung SyncMaster 2233BW 22" LCD Monitor
I need to open the back of the Samsung TD220 LCD TV
I need to know how to open the back of the Samsung TD220 LCD monitor to clean small insects that have gotten inside of the LCD screen? i have found 4 small screws along the back bottom of the unit but after removing them there unit does not come apart. Can anyone help me?
  • chrisparf Jul 28, 2009
    Hi tommya300 thanks for getting back to me I am unsure exactly what you mean by "between the grove of the mated panels" After I remove the 4 screws from the bottom I can gently pull the rose perspex frame away from the back but it seems as though it is held by something halfway up each of the sides but no sign of screws
  • 724 Answers
Care is to be taken? these cases are engineered sometimes with interlocking panels see if you can wedge a a single edge razor blade between the grove of the mated panels and wiggle it see if it moves a little.
If so work it around using danty steps to find the interlocking area the rest is the tought part which one is the release side.
Posted on Jul 28, 2009
  • 1 more comment
  • tommya300
    tommya300 Jul 28, 2009
    You found what I tried to describe this spot you say is holding is the interlocking design someting like cupping your fingers partly of both hand and handshaking them .
    It is all in the plastic molding. This is the area youy need to really visualize as you move them apart.
  • tommya300
    Try tools, internet options, advanced,
    Reset
  • tommya300
    OH wrong help windo sorry
PROBLEM WITH LCD MONITOR SAMSUNG SYNCMASTER 540 N, SOMETIMES BE THE SAME WITHOUT BLANK SIGN, AFTER 20 MINUTES OF OFF AGAIN FOR A SMOOTH RUNNING TIME UNCERTAIN.
It more likely to have bad caps with domed tops in the power supply section, very common problem in all LCD TV and monitors.
See examples here: http://s807.photobucket.com/albums/yy352/budm/SAMSUNG/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 09, 2011 | Samsung SyncMaster 540N 15" LCD Monitor
My samsung 223bw lcd 22"
Look for bad caps with domed tops as shown here:
http://s807.photobucket.com/albums/yy352/budm/SAMSUNG/Samsung%20223bw/
May 17, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
I have a problem on my LCD samsung type 743 nx, LCD did't work until several minutes,, i have tried to unplug cable LCD,, VGA card,, still save problem.. MY LCD up until several minutes,, please give a...
Look for bad caps first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
Feb 16, 2011 | Samsung SyncMaster 2220WM 22" LCD Monitor
This is my 2nd monitor. Same brand. Samsung Syncmaster 731b. Both of them has issues when the turn on button. Can it be fixed?
What is it not doing?
Most common problem in LCD monitors are due to bad caps a syou can see in my SAMSUNG albums here:
Feb 04, 2011 | Samsung SyncMaster 731B 17" LCD Monitor
I have dell E170S lcd monitor. there are some kind of dust look like pixel some are small some are much bigger and it is so irritating for viewing. i want to clean those dust from my lcd. those dust are...
They are probally attracted to the light inside, do not smash them while they are inside. I hope they are not roaches (im not saying that they are). Try putting a another light outside of the monitor (turn off your monitor) and hopefully they will follow that light and leave. I'm sorry but that's the only thing I can think of, because you don't want to go messing around insite that monitor. I hope this helps Khalid.
Dec 06, 2010 | Computers & Internet
Samsung 170 MP LCD Monitor Disassembly
The plastic case also has latches along the sides, top and bottom. Take a small flat blade screwdriver and go between the 2 halves of the case. The 2 pieces should open just a bit, now move the screwdrivers along the seam between the 2 halves. about every 2-4 inches there is a clip that needs to be released. You can release it by applying a small amount of pressure by each clip and moving down to the next one while pulling the case apart.
Buddy
Corporate Compuer
over 21 years repairing PCs and printers
Jun 17, 2009 | Samsung SyncMaster 17" TFT LCD Monitor
How to start disassemble LG flatron W2242TT
Taken from the LG Service Manual for the Flatron 2243/2343:327a726.jpg
The trick is to do this all without cracking any of the small tabs inside. I used this method to remove the case to my Samsung monitor, too, so it may be useful for many different makes and models of monitor. Good luck :D
Apr 11, 2009 | LG Computers & Internet
How do I open a samsung 740N LCD Monitor
Lift the front frame. You must try to lift it from the inner side using your fingers (no tools , you may scratch the lcd panel). A little force is necessary especially at the corners. Once you lift the panel from all four sides then the corners will come out.
Note: A common problem with this monitor is the psu. A small number of capacitors fails. You will notice 3 electrolytic capacitors have been deformed and if there is no power you will find a small 3A fuse (looks like a resistor) blown.
Sep 30, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
HOW TO OPEN COVER OF OVERSIDE?
first remove back side lock then take small pin like tuser insert into small hole & Push it up side it will open
Nov 14, 2007 | SAMTRON 55V 15" CRT Monitor
Samsung SyncMaster 2233BW 22" LCD Monitor Logo
743 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
