Question about Lexmark X2600 InkJet Printer
Actually i don't have a problem, i just can't seem to get the computer to print to the printer
  • 724 Answers
Not a problem?
What did you do was it working at all is it new
Suggest reinstall the drivers make sure the print Que is pointing to it.
Posted on Jul 28, 2009
Printer doesn't respond via USB only WiFi
As my helper partner states, I quite agree but I would also use a different USB which the one you're using might be damaged, use another USB station cause maybe its also damaged. But if it states that the printer is offline...it will never print because its not selected as your active Printer. Actually you are sending the printing jobs to that printer wich is not active or recognized.
Apr 06, 2014 | Office Equipment & Supplies
Hello I have a challenge with printing. When i send to print across the network my document does not print but freeze the print queue for a HP Printer 1018
This could be a number of things. First thing to test is, does it happens with all documents. Suggest trying a Windows Test Print (assuming your using windows)
  • Go to Control Panel-->Printers
  • Locate the relevant printer
  • Right click on the printer and select Properties from the menu
  • Click on 'Print Test Page'
Does this cause the same problem. If not, then it may be a problem with the actual document you are trying to print so check if it is a large file. If it is a large file, then perhaps the 'stall' is actually just the printer taking time to process the file (how long have you left it?)
  • Try printing the same file from a different computer (if possible)
  • Check the system log on event viewer of your machine (Start-->Run, type eventvwr.msc click ok) for any error messages that may indicate the problem.
  • Try uninstalling the printer from your computer and re-installing.
Failing all that then please provide further information, such as how the printer is connected to the network, what OS you're using and what troubleshooting you may already have done.
hope this helps, good luck.
Please take the time to rate this answer. Many Thanks Don.
Sep 05, 2011 | Computers & Internet
I have a big problem with my HP Photosmart C3100. Whenever I try to print, either nothing or very little is actually printed. I've checked the ink, and it's almost full. I've tried printing a...
Connect the printer to a different computer (laptop? desktop?)
and install the HP device-driver software, and try to print.
If it works correctly, then it's your computer that has a problem.
Jul 30, 2010 | Office Equipment & Supplies
I just installed a Canon mx300 on my Mac (runs 10.4.x) and all seemed to go well. I can print but the black letters don't print black (actually, the same happens if I have colored text mixed in). It's...
If the colors in your document don’t look right, you can change whether colors are managed by ColorSync or your printer.
To change color management options for printing:
Open the document you want to print.
Choose File > Print.
If the Print dialog contains only two pop-up menus and some buttons across the bottom, click the disclosure triangle beside the Printer pop-up menu.
Choose Color Matching from the print options pop-up menu.
Select one of the following options:
Select ColorSync if you want the application you’re using to control the color management of the printed output.
Select “In printer” if you want the printer you’re using to control the color management of the printed output.
If you select ColorSync and don’t believe the correct profile is selected for your printer, you may be able to change it. If you see a Profile pop-up menu, choose Other Profiles from the pop-up menu, and select a new one.
I hope this info will help to sort out your problem..Regards
Jan 08, 2010 | Canon MX300 Office All-In-One Printer
I have a Brother MFC 440 CN and it's telling my computers that it's offline, so I can't print. I've had other problems with it in the past, including 'Unable to Print' errors and an alignment issue with...
Try going to your control panel then to printers and reset the printer. After you reset the printer reboot the computer and it should work. if not you may have to delet and reinstall the printer on your computer.
Sep 26, 2009 | Brother MFC-440CN InkJet Printer
Unable to stop printer from printing documents
The actual folder in Windows where spooled documents are stored just before printing is: C:\WINDOWS\System32\spool\PRINTERS. I?ve never had print jobs hanging around after the print queue has been deleted but if you clear out anything in this folder that should take care of it. Let us know how things work out and please don?t forget to rate this posting.
Mar 17, 2007 | Samsung ML 2010 Laser Printer
Why wont my printer pirnt?
hi im Jules_09,check you connection to your computer r your cannon has to be reset because of the driver you installed
Dec 20, 2006 | Canon CLC 1180 Copier
Lexmark X2600 InkJet Printer Logo
56 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
