Question about Sony KP-61S65 61" Rear Projection Television
We have two of these projection TVs. One of them
We have two of these projection TVs. One of them does not have as clear a picture as the other. Is this time to replace the bulb(s)?
  • 147 Answers
Clean the mirror,lens and screen.if the tv is losing brightness then it time to change the lamp.cleaning is required on all dlps and vacuum out the vents ,filter and chassis which
reqires the back to be removed.
Posted on Jul 28, 2009
2 Suggested Answers
techman007
  • 1112 Answers
SOURCE: I have a PT-47WX53.
Hi:
You do not have to worry about lamps in this unit as it does not use one. This perticular uses CRT's like the ones you look at with a standard Tube set. There are three picture tubes RED GRN BLUE, There is no parts needed for your television that are consumer replaceable. The only required maintence need is cleaning and Convergence Alignment, Conv alignment is the line up of the all there screens for picture clarity. you may find this alignment in customer mode in your menu.
\A more percise is in service mode in which technicians use for fine alignment.
Posted on Nov 28, 2010
I have a hitachi rear projection tv. Model #51f510. Picture is bright and clear but goes to distorted when you change the channel. If you turn the tv off then on its worse. Then again turn the tv off then...
Try tapping/knocking on various parts of the TV to see it a bad solder joint is responsible. It could also be some component getting too hot or aged to the point of malfunction.
Don't waste any money trying to fix this, rear projection TVs are dinosaurs.
Jun 21, 2012 | Televison & Video
Hello, I have a 2005 Sony KP-51WS520 Rear Projection TV. Recently, the green colors all become a yellowish/orangish color. When you are watching a baseball game the grass is a orangish color. ...
DLP tvs have a design weakness,the problems it is call a convergence problems,it is dead.This convergence problems,will have happen many times through out the tv live.The tv have a colors R,G,B lines misalignments,have colors shadow pictures or 3D pictures look alike?Yes,than the tv board,that call the tv convergence board it is dead.The tv convergence board,must require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv colors picture convergencce problems.The tvs shops will cost u like $300-350 for parts and labors.
May 24, 2011 | Sony KP-51WS520 51" Rear Projection...
My 42H82 picture works but fuzzy...Letters in menu are clear though..need help
hi,
ur tvs crt sockets have some problem. change the three crt sockets at the same time . also check for screen voltages of crt's. increase it slightly. there will be three independent screen voltage adjustments for each gun.
ok
Dec 23, 2010 | Toshiba 42H82 42" Rear Projection...
I have model #115298-0001 Series #12333264. I need to find replacement screen if available. Also if you have te protective covering.
Sorry,this is not possible,tvs pictures screens panels are 90% important to the tvs itself.If it still available,tvs pictures screens panels replacement,will cost u the same as a new tvs.Because tvs pictures screens panels are limited in productions buy the tvs corporations.But these tvs technologies are opsolete and no longer in the tvs markets by the tvs corporations have stop these tvs productions.
Nov 22, 2010 | Philips Magnavox 9P6034C 60" Rear...
I NEED TO REPLACE THE SCREEN ON MY SD532HD5. DOES ANYONE STILL PRODUCE THEM OR IS THIS A LOST CAUSE? THE PROTECTIVE SCREEN WAS CRACKED BY MY CHILD AND NOW I MUST REPLACE IT.
Sorry it a lost cause these DLP tvs are no longer in productions.If even it still in productions,the tvs picture screens panels are 90% important to the tvs and most of the cost of the tvs.The only place u can buy a tvs picture screens panels are the tvs industries themselves.They'll sell it to u,but they'll charges u the same prices as a new tvs.The tvs Techs.policies are tvs that have bad picture screens panels or a broken picture screens panels are those tvs are now,only can be used as salvages tvs for it tvs electronic boards for spare parts,that it.The tvs now are not worth as a whole tvs anymore.
Nov 08, 2010 | Pioneer SD-532HD5 53" Rear Projection...
Sony projection tv picture real bright and not clear
This sounds like your flyback on the D-Board of your tv is going out (The part is around $70.00) and available at www.Sears.com the parts dept have make and model ready ( This is a very common problem with this model of sony tvs) Have a pro do it HIGH VOLTAGE! Please rate in order to keep this site free
Thank you!
Dec 14, 2008 | Sony KP-53HS20 TV
Magnavox 55" projection Television. Picture not as sharp as used to be. Lenses and screen have been cleaned picture still not clear...
You need to change the coolant in the CRTs. Its a common problem with phillips/magnavox TVs. You can get the coolant replacement kit at the following link with all the coolant and the step by step instructions with pictures on CD. Its listed under the repair kits. magnavox and phillips are the same TVs. here is the link.
http://servicemanuals.vstore.ca/
Aug 06, 2008 | Televison & Video
THE COLORS ARE SEPARATED (RED, YELLOW & BLUE ETC.)AND THE PICTURE IS NOT CLEAR. THE PICTURE IS BOWING AT THE TOP AND BOTTOM OF SCREEN. PLEASE ADVISE.
You need new convergence ICs this is a common problem on all projection TVs. Please post the model number of your set and I will post a link where you can order the new ICs and recieve free step by step instructions with pictures on how to do the repair yourself.
Mar 31, 2008 | Televison & Video
Picture not perfectly clear
your convergance ampliers have gone bad and need to be replaced along with some resistors and/or pico fuses. the repair my cost you about $350.00. this is the most common failure in rear projection tvs
Feb 20, 2008 | Samsung HCM5525W 55" Rear Projection...
To many colors in tv double pictures red blue yellow
You have a convergence problem. It is a very common problem with projection TVs. It will have to be serviced by a technician.
C-Dog
Feb 10, 2008 | JVC AV-48WP30 48" Rear Projection...
Sony KP-61S65 61" Rear Projection Television Logo
242 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
