Question about Sony Ericsson K850i Mobile Phone
It keeps restarting
Any time am making important call and then my sonnyerickson J120i will turn black for some few seconds and then it will come back to normal and it means i have to make the call again and keeps on doing that, thus you will talk for one to two minus and is gone again
    Sergeant:
    Champion:
  • 212 Answers
Please reset the factory settings
Posted on Jul 28, 2009
93 toyota pickup 4x4 it will stay running after I turn it on to start it up, it starts up then after a few seconds it kills
if I'm reading this right...
... the engine starts and dies within a few seconds.
... you jumpered the fuel pump test connector and it will keep running.
... you smell fuel after trying to re-start when it dies.
Disconnect the plug to the cold start injector. Even if you have an issue with the engine running then dying after a few seconds after doing this, if you don't smell fuel after disconnecting the cold start injector and try to restart it, the cold start time injector time switch may be failing.
Buy a can of starting fluid and have someone start the engine then spray short bursts of the fluid around all the intake fittings. If spraying the fluid in any particular area keeps the engine running, I'd start looking for leaks around that area.
It does sound like an AFM or COR issue considering it dies after a few seconds, but the fuel smell when trying to restart the engine may be a separate issue that needs corrected / isolated first.it will keep running.
Mar 30, 2013 | Cars & Trucks
Galaxy always restarting
Try turning off your phone. Hold down Volume up, menu and start buttons at the same time till your phone vibrates or say 5 seconds. This should reset your phone. Make sure you back up your contacts and important data. I saved mine to my external SD card and backed it up (to be on the safe side) then removed it before i reset my phone
Feb 01, 2013 | Samsung Galaxy Y Gt-s5360 - Black unlocked...
My Acer AL2216W monitor this morning went blank. I woke up, turned on pc and went to sleep like an hour more, when I woke up, the screen was black and light orange, as usual, when pc is not used for a...
Go to Control Panel, (top right View Small Icons). Then look for Power Options. On this page, you'll have the option to leave the monitor on. You should also check "Advanced Power Options". Don't be afraid of the word, "Advanced." It only means "customizeable"
If your mouse isn't waking your monitor, try the keyboard's space bar. I found it works better than the mouse at waking a sleeping computer
Apr 04, 2017 | Acer AL2216W LCD Monitor
How do you turn it off?
Just press and hold the Power / Menu button on the right hand side, I believe the top, of the player. Hold it in a few seconds and it should turn off. Also if it is not turning off just take off the battery door on the back of the unit and take out the batteries for a few seconds. Then just go ahead and replace them and this will restart the unit.
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks
Tim
Oct 12, 2010 | SanDisk Sansa m230 MP3 Player
Printer screen reads "ink system has failed. unable to print. refer to printer documentation. error: 0xc18a0301. turn power off and then on again." i have tried turning it off and on repeatedly and every...
jusr solved this off an article. the *,#,123 thing only gets you a r0046 support answer no sytem configuration menu, so.........hit cancel the hold down canel, ok black and color buttons at teh same time, error message continues, keep holding all 4 and the power off with on botton, let sit for a few seconds, my have to restart a few times but maintenaince is done and volla-fit it. up your hp-let keep em honest. andy fecteau
Aug 26, 2010 | Office Equipment & Supplies
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
I can't turn on my iphone
did you try restarting it(hold the home n lock button for 10 sec)
Sep 30, 2009 | Apple iPhone Smartphone
Not turning on
  1. Press the home button (the big circle below the screen) and the sleep wake button (the button on top of the iPhone) simultaneously.
  2. Hold both buttons simultaneously for a few seconds, Ignore the "Slide to power off" and keep holding
  3. The iPhone should now shutdown automatically - (fade to black)
  4. Turn the iPhone back on by hitting the sleep/wake button.
  5. You should now see the Apple logo, your iPhone is restarting and thus booting up.
  6. You have completed a hard reset successfully
Jul 30, 2009 | Apple iPhone Smartphone
Monitor show picture for a few seconds, then turns black
It sounds like the power supply board on your monitor is failing. If it's still under warranty you might be able to get a replacement from the manufacturer - if not, you might be able to have it repaired at a computer or TV repair shop.
May 14, 2008 | E-Machines E17T4 LCD Monitor
Sony Ericsson K850i  Mobile Phone Logo
118 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
