Question about Furuno Navnet 1834C/NT vx2 Radar C Map Nt
My tracker ball gets sticky
My tracker ball on my boat siezes up and gets difficult to operate, I thought at first it was salt and washed it, but after a while it just doesnt respond. Is there anything that will help, or is this a common problem.
    Scholar:
  • 111 Answers
I've seen this problem before and normally you will have to replace your trackball assembly. Give a call to 410-228-7335. The guys at Mid-shore electronics may be able to help you out.
Posted on Feb 01, 2010
Where can I get a wiring diagram of a fishing boat?
If this is a Tracker boat then contact Tracker with the hull identification number and they will provide the diagram. I have no experience with other manufactures.
Mar 12, 2016 | Boating
Topped up with salt,used all the salt in one wash and dishes come out still sticky ?
never heard soap called salt we usually use cascade dish washing detergent .
Mar 07, 2015 | Hotpoint Dishwashers
Tracker 215 Tahoe Deck Boat 2009
check near the fuel tnks at the rear and bottom of hull.
Jul 13, 2014 | Boating
What problems or benefits will I get with an aluminium boat hull
Aluminum boats are easier to maintain, will last longer than fiberglass, and are easier to repair. You can also bump into things without causing damage like you would to a fiberglass hull.
The only real advantages to fiberglass are that it looks better due to the gelcoat finish, providing that it is maintained, they also feel more solid in the water due to the extra weight, and they tend to ride better and are quieter than an aluminum hull.
One other consideration is whether you will operate it in fresh water or salt water. Salt water can lead to corrosion problems on an aluminum hull if you leave it in the water. Fiberglass doesn't have that problem, but you can have a problem with blistering if you leave a fiberglass boat in the water for long periods, especially if you don't use a bottom coat of some sort.
If you do opt for an aluminum boat in salt water, just make sure that you spray it down with fresh water and wipe it down with a soft towel whenever you take it out of the water. This is actually a good practice for any boat, aluminum or fiberglass.
Mar 28, 2013 | Boating
Wasflashing f21 my huband took the pump filter out and it was full of stuff he then took a clamp off of a bigger hose and found a ball in the...is it supposed to be there....now he cant get the clamp back...
Hi, the ball is a "check valve" device that is necessary. It is a type of one way valve. Getting the clamp back on is difficult but it can be done. If he is having difficulty improvising my hat is off to him.
Those clamps are difficult to work with. There is a Specific tool for removing and installing clamps on a washing machine. It is called a "hose clamp pliers"
Here is a link
http://www.google.com/products/catalog?num=100&hl=en&lr=&newwindow=1&safe=off&q=hose+clamp+pliers&um=1&ie=UTF-8&cid=1315315859135749155&ei=lPAjTeDHEYOBlAevp8S3DA&sa=X&oi=product_catalog_result&ct=result&resnum=2&ved=0CCwQ8wIwAQ#
Hope this helps,
Mark
Jan 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I will press the button "a" and it types "ou", my buttons are just all mixed up also my send button types out "jk"
This problem is caused by contamination UNDER the trackball. Its picked up from sticky/oily fingers operating the tracker ball. Fix:- 1. Checkout web for videos on dismantling the case (easy, but you WLL need a T4 (or is it T5?) multi-point screwdriver (ebay))
2. After accessing the PCB, unclip the tracker ball (magnifying glass and small screw driver). This lifts out as a single assembly.
3 .The area of the PCB reviled under TB now needs cleaning with a cotton wool swab, soaked in a de-greasing solution. DONT use water (even soapy), as this is slow to dry. Use - IPA (Isopropyl alcohol) - safeclens - surgical spirit etc. These will not harm circuit board or components, but MAY affect some plastics. Test small area if unsure The underside of TB assy and ball should also be cleaned. A clean swab damped in mild soap solution can be used to do general cleanup of dirt on white keyboard membrane, case edge grooves etc. allow to evaporate
DONT touch degreased areas with fingers as this will re-contaminate
4. Allow solution to evaporate (around 1 Min.)
5. Re-assemble tracker ball (clicks into position) Re-assemble case using on-line video (step 1)
Apr 06, 2010 | RIM BlackBerry Bold 9000 Smartphone
How do you convert a 1997 760 Yamaha Waverunner from fresh water to salt water
There is nothing to convert. After running it in salt water, you need to flush the engine out either on a garden hose or by running it in a fresh water lake or river prior to storing. Salt water is very corrosive and you need to flush your engine just as soon as possible after removing it from salt water. DO NOT let it sit overnight, it will start corroding internally and doing damage.
Aug 24, 2009 | Hayward Sand Filter System & Tank 21" 1...
Furuno Navnet 1834C/NT vx2 Radar C Map Nt Logo
167 people viewed this question
Top Furuno Boating Experts
Daniel Dollive
Daniel Dollive
David Burbee
David Burbee
Colin Stickland
Colin Stickland
Are you a Furuno Boating Expert? Answer questions, earn points and help others
