Question about Gaggenau Dishwashers
Motor won't stop running
Motor/pump won't stop running on gaggenau GI 230-160 DISHWASHER.
There was a piece of glass stuck in pump but that has been removed. The motor runs when door open or closed and I can not set any programmes. I have tried cancelling programme to reset but this hasn't worked.
  • 123 Answers
SOURCE: Beko Freestanding Dishwasher
Hi there ....this condition is ususally caused by a water leak into the sump of the dishwasher which activates a safety switch to run the drain pump..preventing the appliance from being used....Remedy...tip the dishwasher back in the head allowing excess water to exit from the sump...then with the door open check that the air vent lock ring is secure, thet the salt unit retaining ring is secure..and finally that the filter unit to base screws are secure...this done re-start and you should b fine
Posted on Jan 05, 2007
  • 1462 Answers
SOURCE: Dishwasher stuck on "drain"
not easy to fix - it has a leak. the tray at the base is full of water which ooperates a float which switches drain pump on. remove front panel at bottom front and mop out water or tilt backwards 45deg and water will run out. leak is usually main pump
Posted on Mar 20, 2007
wbwill
  • 68 Answers
SOURCE: NEFF DISHWASHER S5443 STUCK IN TEST MODE
First try disconnecting the unit, completely from any power, for an hour or more, look in any control doors or access points for a small battery mounted to a board or in a holder, if you find one, take it out also, noting the positive and negative orientation.
If that doesn't do it, there are reset buttons under the tops or lids of some NEFF models, if there is an obvious lid after trying the no power trick, take off the top and look for a stand alone reset button.
If all that fails, write me back
Will
Posted on Nov 05, 2008
vickygomar
  • 460 Answers
SOURCE: Hotpoint BF1620 Integrated dishwasher not working
Lets try the following hope this works
1.- unplug the appliance, isolate it from the electric supply.
2.- Remove the kitchen unit plinth and check inside the inspection panels below the door to see if there is water in the base.
If there is, sponge it out and then try the machine again.
Was this helpful?
Posted on May 15, 2009
This is a on going problem with asko and they keep jerking everyone around with this defect. I had a repair person come over and used a turkey baster with a 7" rubber hose attached to the end of the baster. He took off the kick plate and inserted the hose end in the overflow tray and pull about of 12 onces of water from the tray. He is a asko repair facility and says it is a comon problem and has made the repair solution on his own as it is easier then taking the hole dishwaser out and tip it on the side just to drain the water. This has been on going for 3 years and each time i called asko it was like i was the only person having such a problem. I now do this every 3 months and the problem is on going. What a piece of junk. Purchased at Marcellas appliances in Schenectady,NY. They also know how to avoid the problem in fact there repair person left out most of the screws so the next time it would take less time to drain the water. DDDDDont buy ASKO. Michael Foote
Posted on May 19, 2009
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
Dishwasher fills but does not wash. Dishwasher will drain if program cancelled.
Do you hear a humming sound, like the motor trying to run, then stopping for a minute or two before trying again?
Usually, dishwashers run the motor one direction to wash, and the opposite direction to drain, but some use a valve to switch. If you see wires going to a bulky flapper looking part sticking off the side of the pump/motor, you might have a bad valve actuator.
Otherwise, you might have a motor refusing to turn in one direction. You can usually access the shaft from inside the tub by removing the washer arm to get access to the pump impeller. Do not remove the impeller unless necessary, but see if it will turn both directions. Broken glass or pieces of bones or other debris might be interfering with the rotation. If it turns freely both ways, but still won't wash, it is likely you have a bad starter coil on the motor, and will need to replace the motor/pump assembly. These usually have a longer warranty than the rest of the unit, so if yours is less than 5 years old or so, it would be worth checking with factory service.
May 18, 2011 | KitchenAid KUDK03ITBK Built-in Dishwasher
Dishwasher not draining
you need to remove the drain pump motor and see what is obstructing the impellar.(small shreds of glass:small popcorn pieces etc. Doesnt take much to stop the drain pump.Try and get to drain pump from the front. Miele very compact.
May 28, 2010 | Miele Incognito G818SCVi Built-in...
Water is not draining from my dishwasher.and when i turn it on its making a strange humming sound.,
I have attached a breakdown of the pump and motor area of the dishwasher. You may have gotten something stuck in around the impeller area, a piece of broken glass or bread tag etc. If nothing is visibly caught in there and the hum continues, you may need a new pump and motor assembly. You would need a service technician to verify this.250
Nov 08, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Template for GI 936-760 wood panel
My husband ended up measuring and drawing his own template.
May 13, 2009 | Gaggenau GI936-760 Dishwasher
Gaggenau dishwasher model GM- 915-710
i suspect you are hearing the drain pump working due to the antoflood being actuated.
remove the bottom front panel and bottom tray is exposed and it is probably full of water. mop water out and machine will work. if fault reoccurs, then you have a leak
Oct 01, 2008 | Gaggenau GI936-760 Dishwasher
Gaggenau dishwasher keeps running
press the intensive and crystal buttons @ the same time, the display will change to 0. Close the door the pump will run for a while when the pump stops the dishwasher is reset.
May 26, 2008 | Gaggenau GI936-760 Dishwasher
F message n Gaggenau 936-760
Prime the dishwasher by pouring a large glass of water into the filters on the floor of the dishwasher. Then close and run the dishwasher as usual.
Nov 23, 2007 | Gaggenau GI936-760 Dishwasher
Gaggenau GI 936-760 dishwasher
Buy a new one and sell me the door. I have been looking for this model's door for a long time!
williamduck@comcast.net
Aug 02, 2007 | Gaggenau GI936-760 Dishwasher
Dishwashers Logo
60 people viewed this question
Top Gaggenau Dishwashers Experts
Are you a Gaggenau Dishwasher Expert? Answer questions, earn points and help others
