Question about HP PSC 2410 All-In-One InkJet Printer
We have one phone line for our house and want to get a fax but do not know how to set the printer for that
    President:
  • HP Master
  • 1,996 Answers
Please see this link and this link for setup instructions for faxing with the PSC 2410 printer. Then go here for detailed instructions on how to use the fax capability of your machine.
If you have any further questions, the online support page for your model here may be helpful.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 28, 2009
Do not know how to turn on "receive faxes". can only send faxes. How do I turn on receive faxes?
if you are able to send faxes it means you are set up correctly, meaning that you have connected your printer/fax machine up correctly to the phone lines. all you need to do is make sure the printer/fax is on while you are receiving the fax, there is no "fax receive mode" however, you need to know that if you use the same line for your phone and for your fax that your phone will ring when receiving a fax, if you answer it will ruin the fax, there is a special configuration you can access which will let your printer work more effectively, such as to intercept faxes and immediately process them before letting your phone ring, or waiting a certain amount of time or such. you can consult the specifications of your device to know the exact settings you have available.
Apr 15, 2011 | Canon PIXMA MX870 Wireless Office...
Can't use fax on HP C7280
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 17, 2010 | HP Photosmart C7280 Laser Printer
Setting up fax feature
get a separate telephone cable and attach it to your fax, switch line over from phone to fax manually at the phone line input on the wall, it's the ONLY way I can manage that same problem. If you forget to "switch" your lines over, unplug the fax from the wall & answer your other house phone that's plugged into the wall. Works every time. It takes a little effort, but why pay for more phone lines when all you have to do is plug/unplug an extra phone line?
May 16, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Connecting fax to phone line kills my house phones
Fax machines are analog devices. It sounds like you have a DSL phone line.
Mar 02, 2009 | HP PSC 2510 All-In-One InkJet Printer
I own a Lexmark X5150 printer/copier/fax and would like to use the fax option. I do not know how to set it up. Does a phone cable need to be connected to the printer at one end and a phone jack at the...
On the back of your printer you have 2 two jacks:
One says PHONE LINE and the other PHONE
On the jack "phone line" connect the cable that it is coming from the jack of your house
On jack "Phone" connect your regular Phone
Oct 06, 2008 | Office Equipment & Supplies
Fax network not working
Is your phone line plugged into the proper receptical on the fax? It should be plugged into the LINE slot, not the PHONE slot. The PHONE SLOT IS TO CONNECT A TELEPHONE TO THE FAX. IT IS NOT FOR THE INCOMING PHONE LINE. If your phone connection is correct, try calling your fax machine from a cell phone while you are at the fax machine. Listen on the cell to see if the fax machine picks up the line. If it does not, go into your fax machine's settings, either INITIAL SETUP FAX SETUP, or PHONE SETTINGS. You may have to try several settings to find one that works, depending on your fax machine. Try going to RECEIVE SETUP on your fax machines setup menu. Scroll through the settings, writing each down on paper. Try RING DELAY, RING TIME, NUMBER OF RINGS TO ANSWER , or any other settings relating to how your fax answers the phone line. Try changing each setting, one at a time, and try calling your fax to see if it answers. There may also be settings on your fax to set it up if an answering machine or telephone is on the same line.
Jul 17, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Can't fax
1) Make sure you cave connected the phone lines in correctly and firmly.
2) Do you have DSL? Make sure you have a filter on the line.
3) Check with your phone company to see if the line is up to standard.
Jan 09, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Stop the Samsung CLX 316FN from answering the house chat line
Make sure that the unit is hooked to the fax line only. Many people often merge both lines when connecting answering machines and more than one wireless phone. Also make sure that the unit is the FIRST equipment connected from the wall outlet. Finally, enter the program mode and make sure the fax setting is turned to FAX or TEL. The first setting makes the unit answer after the amount of rings programmed, while the other setting is for manual reception only. One final notice: if you are using the phone line for talking and someone hits START for a copy, the unit will assume a fax and iterrupt the communication. To avoid this, press NO. COPIES first before making copies. Even if it is for one copy only.
Oct 04, 2007 | Samsung CLX 3160fn All-In-One Printer
How to fax
You would need to connect a phone line from the appropriate port on the all-in-one to an open phone jack in order to make faxing work. If that's a problem, you can use the scan feature and send docs by email as a workaround. If you want to get incoming fax service, though, you will need the phone line connected to the unit.
Aug 14, 2007 | HP OfficeJet 4215 All-In-One InkJet...
Cannot figure how to set up Canon MP830 All in One Fax machine with remote answering machine
Cannot figure how to hook up Canon MP830 all in one fax with remote answering machine. I can plug in phone line to send faxes fine but when hooked up in same hole and the phone rings it goes immediately to fax and can't receive phone calls. Maybe i have phone line hooked up in wrong place on my machine. The answering machine is in our master bedroom on the other side of the house. With my last a canon also i had it hooked up to go to fax after a certain amount of rings and it worked fine. That machine got fried by lightening and i replaced it with this machine. If anyone knows what i am doing wrong i really need this fax hooked up all the time for my business.
May 01, 2007 | Canon PIXMA MP830 All-In-One InkJet...
HP PSC 2410 All-In-One InkJet Printer Logo
65 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
