Question about Seagate Barracuda 7200.9 300 GB SATA Hard Drive
Need Help Seagate Barracuda 7200.9 300 GB SATA HD when powering up it makes a low volume beeping sound like it's stuck and at boot and won't initialize.
  • vlady1974 May 22, 2009
    Same problem. It was a maxtor one touch. I took it out and placed it in an external SATA enclosure... same result. the original incident happened after I acccidentally kicked the power board it was connected to and pulled it out of the socket.. causing temp power outage. on top of that, i had just downloaded a big file that took 24+ hours so the drive would have been hot. beeps started, couldn't get it back.
    after i moved house, plugged it in and it worked! twice. then beeps started again. numerous googles point to a power shortage or lack of power.... i doubt the drives/content is damaged... just need the disks to turn and stop beeping!!! any clues anyone??
  • 25 Answers
Usually the beeping sound when powering up the drive is an indication that the drive is damaged.
Posted on Nov 25, 2007
  • Mort Lebow
    Mort Lebow Nov 25, 2007
    Or there is an improper configuration within the setup of the drive. Check all cables and also go into the system setup at bootup and check your configuration there.
Recover data from seagate barracuda 7200.10
External hard drive case, which comes with its own PSU AC/DC power pack.
They come in IDE and SATA flavours, some with extra cables to convert IDE<>SATA.
Take HDD with to computer retailer so physical dimension can be matched.
Sep 07, 2012 | Seagate Barracuda 7200.10 ST3160215AS -...
Seagate Barracuda 7200.10 250 GB SATA Hard Drive
If you have the SATA power and SATA data cable connected and the drive still isn't working, the drive is bad. Get a replacement.
May 08, 2011 | Seagate Barracuda 7200.10 250 GB SATA Hard...
My seagate barracuda 80 gb sata was unable to format completely how to solve this problem? pls helm me
Press either delete or f2 during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
this process should enable a complete format
hope this helps good luck
Sep 18, 2010 | Seagate Barracuda 7200.10 ST380815AS 80 GB...
My hard disk makes a beep sound
If all the conectors are fitted correctly and you still get problems then i would just return it under warranty.
If you have, or can get a spare sata cable it may be worth a try.
Jul 10, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate ST3500630AS SATA 500 GB hard Drive
You will have to send it to a data recovery company in order to retrive the data sounds like the circuit board failed therefore the drive is not receiving power.Usually if this board is good you would hear the drive spin up.
Good luck
Oct 04, 2009 | Seagate Computers & Internet
Seagate SATA 80GB Master Drive and Seagate IDE 80GB Salve Drive
Dear,
You have to make IDE drive as slave. For this put the jumper to slave in IDE drive. Possibility of CMOS battery is rare, but you can confirm it by checking your system time in BIOS. If system time is ok then there is no problem in CMOS battery and you need not to replace it.
Thanks,
Rakesh Kumar
Jul 23, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate 7200.9 usb hard drive
If the system goes upto Boot option.. then please try to run it in Command Prompt. Then runthe Checkdisk command by entering the following:
chkdsk /f/r
this will check and fix any error occurs on your Harddisk.
Apr 27, 2009 | Seagate Barracuda 7200.9 (ST3250624AS) 250...
I have a barracuda 7200.7 80 Gbytes. The dirve spins but stopped booting. Started making clicking noises. I smacked it a bit a few times. Now, the system doesn't recognize the drive in BIOS at all. I...
this hard drive is toast and sadly you are half the reason as you never, ever ever open or hit a hard drive.  There are data recovery firms however, they are very expensive.
Nov 27, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
SECOND HARD DRIVE NOT RECOGNIZED
Change the settings of you IDE drives in your BIOS. Set your secondary boot device to HDD1. Also make sure that your primary HDD is set to master and the secondary HDD is slave. The jumper is found at the back of the hard drive where you connect the power and IDE cables. Try this and post back as to how it went..
Nov 11, 2008 | Seagate 250GB Barracuda 7200.10 ATA-100...
SATA HDD make SLAVE
IDE Cable with 3 connectors (you have 1 or need to buy 1) :
- blue: conn to motherboard
- black: conn to master HD
- grey: conn to slave HD
Cable (select:) cable will auto detect with most modern HD's from same type (SATA it was i think) and you need to go to you're BIOS, set up cable select for the HD's. Maybe best to set up master first, not both at same time. If you have a SATA and ATA set up the master first, then other. So if SATA is slafe but it in grey connector, otherwise black. For an ATA you might need a converter cable for the power, most motherboards don't have 1.
Oct 25, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate Barracuda 7200.9 300 GB SATA Hard Drive Logo
656 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
