Question about A & A Manufacturing Ramsond 40D Plasma Cutter Inverter
Lotos cut 40 plasma cutter, not firing
I've used my plasma cutter twice, the o.c. light came on, so I cut of power let it reset cut it back on everything looked ok, but the moment I triggered the switch the o.c. light came back on. I have air pressure and the fan comes on, but no fire. The green LED on the top board comes on, ther is a smaller board that is piggy back on the top board that has a smaller green, and red LED they are not coming on at all, I am assuming that this is the pulse modulating board. All components look good, have no plans to go by, and the operators manual dont say much. Would like to get this back online soon. THANKS IF YOU CAN HELP!!!
  • 25 Answers
Test all the mosfets, good chance one or more are failed.
Posted on Nov 01, 2009
How do I wire the plug to a Lotos plasma cutter for 220 volt ?
There are three wires on the machine, RED BLUE and YELLOW GREEN. In a standard US 220 VAC connection there is red, black and white. RED is connected to red, BLUE is connected to black and YELLOW GREEN is connected to white.
Sep 12, 2014 | Lotos LT5000D 50-Amp Plasma Cutter
Where can I get consumables for a lotos LT5000D plasma cutter, and is there something else compatible.
You can order them through Lotus Technologies,
http://www.lotostechnology.com/product_p/ltp5000d.htm
Or if you see a name on any of the components like Airco, Tweco, etc, you cold get through your current supplier or you could take them to a local welding supply and see if they can identify them. Chances are very good they simply used something readily available.
Jan 14, 2012 | Welding Tools
I have a cheap chinese plasmam cutter a giant cut
Internal componet failure, return the machine for repair. Who did you purchase it from?
Jun 06, 2010 | Inverter Welding Tools
My plasma cutter just flashes fault everytime you try and use it. could it be the ground or would it be the electrod
check the main lead to the torch,if there is a cut or any hole in the rubber coating it will show fault,the unit uses high frequencey so if the lead has a cut it wont fire up.
Jan 22, 2010 | RTO Esab Plasma Electrode 0558001969 PKG/2
No Arc on a Cut 40 Plasma cutter
Check your consumbales to be sure they are tight in the torch head. Check your ground be sure it's good and connected to the pc you are cutting. Make sure you are running air at 65 to 70 psi as it exits the torch. Email me if you have any other questions.
Jul 14, 2009 | A & A Manufacturing Ramsond 40D Plasma...
Safety light
check the gun lead all the way back to unit,if there is a nic or cut in that lead (main power lead)the unit will not fire,sadly you cannot fix the lead ,it has to be replace with new one,
Jun 06, 2009 | Lincoln Electric Plasma Cutter, Pro - Cut...
No full arc
the spark that you see when you touch work peice is high frequency,recheck connections like good ground (tight and clean)on the unit and work peice.no ground no fire.
Jun 03, 2009 | Welding Tools
A & A Manufacturing Ramsond 40D Plasma Cutter Inverter Logo
1,023 people viewed this question
Top A & A Manufacturing Electronics - Others Experts
Are you an A & A Manufacturing Electronics - Other Expert? Answer questions, earn points and help others
