I did a Yahoo search for "set heating timer on Ferroli Modena 32c HE boiler" and got this -
http://www.ferroli.co.uk/brochures/Timer-HE-013001X0-Instructions.pdf
If you can get to that site, it will let you download a PDF which seems to answer your question.
I copy/pasted the hyperlink, but you may have to enter is yourself. My last hyperlinks did not work.
SOURCE: ferroli optimax 31c
Here is a link to the manual.It shows fault codes.
http://www.ferroli.co.uk/Product_Documentation/Domestic/Optimax_HE_31_C_Manual.pdf
Please rate this solution.
SOURCE: vaillant 831 combi boiler timer help
check to see the time clock is set with the clock symbol. there are three settings on analog clocks I , O and clock the I setting is constant running, the O setting is off and the clock setting is timer.
also try setting the thermostat up higher to see if the boiler fires.
SOURCE: missing instructions for setting timer on boiler
if the timer is built into the boiler there is a small switch on the right hand side. this can be moved up and down to bring the timer on and off.
if you log onto the ideal web site you should be able to download a copy of the programing instructions.
SOURCE: ferroli optimax HE 31C boiler
Setting time is not in manual that we received, however, we did get a separate sheet:
Buttons top left-right are
A - Clock adjustment
B - Operating Mode selecting
C - Override
Buttons bottom left-right are:
D - -
E - Programmes
F - +
To set clock:
1 - Push A
2 - When the DAY and the CLOCK icons on the LCD are flashing use + and - (D and F). You should set the day of the week (1 = Monday, 7 = Sunday). To confirm the day press A.
3 - The HOUR and CLOCK are flashing use + and -. Confirm with A.
4 - MINUTES and CLOCK are flashing use + and -. Confirm with A.
My LCD is not working correctly, so I have to press the screen gently to see what icons are displaying. Annoying.
SOURCE: fault code ( nocn ) on a ferroli boiler
if nocn is on the time clock then check the wiring to time clock and if all good then it is the time clock at fault and will need repleacing
