Question about Salton WM8BEL Belgian Waffle Maker
I need a manual for a salton waffle maker wm4
Someone gave me this waffle maker but couldn't find the manual for it. I need one.
There is a site that posts PDF files of manuals for all manner of things..manualsonline.com.
Here's the link for the Salton Waffle maker, they have several versions:
http://kitchen.manualsonline.com/search.html?q=+salton+salton+waffle+maker
Posted on Aug 05, 2009
    Habit-Forming:
    New Friend:
  • 136 Answers
It would be use the social portal sites that may more good for you as know how much time it will take through manual, if you need to check the whole process or beneficial which can more home helpful for you use waffle maker review site.
Posted on Aug 06, 2015
Purchase manual
Appears to be the same thing with a different model number.
http://www.salton.com/files/documents/WM-1075%20Booklet%20EN.pdf
Jul 25, 2014 | Salton WM8BEL Belgian Waffle Maker
I have a pre owned wm-4. No owner's manual. Can the plates be removed for cleaning?
These instructions are taken from a WM14 waffle maker, maybe they will work for you. It doesn't say anything about removing the plates:
"Wipe Cooking Plates with absorbent paper
towel or a soft cloth. Although the Cooking Plates are coated
with a non-stick coating, some batter or ingredients may still adhere
to the Waffle Maker. To remove, simply pour a little cooking oil onto
the baked-on food. Allow to stand for 5 to 10 minutes. This should
soften the food and make it easy to remove with absorbent paper
towel or a soft cloth. If the preceding measure fails to remove the
food residue, we suggest wiping the Cooking Plates with a slightly
dampened cloth and a little non-abrasive detergent."
Mar 28, 2011 | Salton WM4 Waffle Maker
Does this waffle makes come apart to wash? If so, how?
The manual for this waffle maker is on the www.salton.com site
Feb 28, 2011 | Salton WM4 Waffle Maker
Manuel for a wm-4 belgian waffle maker
http://www.salton.com/en/service.asp
The unit has an automatic thermostat and is very simple to use. Honestly instructions aren't even really needed. You can use the link above to contact Salton to receive the information your inquiring about.
Thank you,
Lee
Feb 04, 2010 | Salton Kitchen Appliances - Others
How do you remove the plates for cleaning?
I looked for you model by using Salton WM4 and found nothing. Is there a better model number?
Closest match was Russell Hobbs
RHBW4 and RHBW4CAN
This unit is also made by Salton
I checked several Salton user manuals and none of them had removable plates. They all stated this in the use and care guide:
Cleaning
To keep your Waffle Maker operating properly, clean regularly.
1. Unplug the Waffle Maker and allow it to cool completely before cleaning.
2. Never immerse the waffle maker in water or any other liquid.
3. Wipe the exterior with a soft, damp cloth. Dry thoroughly.
4. To remove any remaining batter on the Cooking Plates, wipe with a soft, damp cloth or absorbent paper towel. Dry thoroughly.
5. Do not use steel wool, scouring pads, or abrasive cleaners, as they will damage the finish.
Jan 26, 2010 | Salton WM4 Waffle Maker
Waffles sticking in a Salton wm-4.
Salton wm-4! one of the oldest waffle maker. The waffle is generally known to be difficult to clean. I would only advice you should always grease the plate before use. This helps make cleaning easy. You can also check our post on The Best Waffle Maker in 2017 The best waffle maker 2017 Easy buying guide Kitchenutilitypro
Sep 24, 2017 | Salton WM4 Waffle Maker
Does the salton waffle maker have teflon in it?
It very well may, did the box or manual say? If not and even if it did you will still need to either spay or brush with butter to keep waffles from sticking, that many surfaces with all those corners and ditches something will stick everytime unless you lightly coat with non stick something. let me know if this helps goofballlovers
May 10, 2009 | Salton WM8BEL Belgian Waffle Maker
NEED OWNERS MANUAL
Plug it in, and wait for light to go off..
When light is off, pour (aprox) 1/4 cup batter on each of the 2 (of the 4) waffle panels on the bottom surface. Close lid; then, per manual, wait about 90 seconds. The light may flicker on/off while baking but disregard. You may experiment with different times by observing "steam" from coming out of baking area.
Remove waffles with a plastic spatula (as knives may scratch the non stick coating)
When cleaning, power unit off.. Do not immerse unit in water. Wipe down with a soapy/damp cloth.
I tried using non stick spray and it seemed to make them "soggy"; it also required up to 2 mins (used a "sand timer") then flipped waffles, then another 2mins..
Dec 17, 2008 | Salton WM4 Waffle Maker
Cleaning
Believe it or not but if it is a non-stick surface it can simply be brushed with cold water while the surface is still very hot. As long as you do this immediately after you remove the food. Try it with a pastry brush or similar.
Sep 25, 2008 | Salton WM8BEL Belgian Waffle Maker
Salton WM8BEL Belgian Waffle Maker Logo
1,733 people viewed this question
Top Salton Kitchen Appliances - Others Experts
fixzum
Level 1 Expert
Robert Plante
Kolbrun...
Are you a Salton Kitchen Appliances - Other Expert? Answer questions, earn points and help others
