Question about Canon Digital Rebel XT / EOS 350D Digital Camera with EF-S 17-85mm IS Lens
Error 5 If you get Error 5 meaning that the built-in flash is obstructed how can you fix it?
  • 3 more comments
  • dandylion Dec 04, 2007
    I have the same camera. I bought this camera in august brand new.
  • Anonymous Oct 28, 2008
    I get an error 5?
  • lka064 Nov 11, 2008
    error 5. click click click but the flash wont open
  • kcsmania Dec 20, 2008
    I have the same problem Mine is Canon Rebel Eos Rebel XTI... Error 5, something to do with built in flasher. It's still a new camera. I got it last May. I hope you can help me. Thank you.
  • Anonymous Jan 20, 2009
    I also have this problem. I think my camera got some water inside of it, but just a few drops, it was with me when was raining
Posted on Sep 22, 2008
How do I fix an error 5 on a canon eos 60d
Look onto the camera's hotshoe, one the right side (metal ground rail, one lcd panel).
Look closer with a bright light, under the Silver Spring Rail lies a Black Micro Switch. It's stuck in the down positions.
Gently pry the Silver Spring Rail up and the Black Micro Switch will pop up.
Or you can clean the Black Micro Switch and then pry it up.
Seen many cameras coming in to visit me with this problem.
Hope that's helpful.
Mar 06, 2012 | Canon Cameras
My flash stopped working on my nikon coolpix L110..
The Nikon Coolpix is a compact digital camera that is well-suited for amateur to semi-professional photographers. Occasionally, some issues with the built-in flash can occur. If the hardware is damaged, the camera must be taken in for repairs. More often, problems occur because of obstructions or issues with the camera's settings and are easily repairable. Follow the troubleshooting guide to fix the built-in flash.
1.Ensure the Nikon Coolpix digital camera battery is fully charged.
2.Wait several seconds before pressing the shutter-release button if the "Flash Ready" indicator light is flashing red. Press the "Flash Mode" button once or twice to change the flash settings from "Off" to "On" or "Auto" if the "Flash Ready" indicator light is off.
3.Ensure there are no obstructions, like your finger or the camera strap, that are preventing the flash from firing if an error message appears on the display screen and the flash is not firing when the flash mode is set to automatic.
4.Press the flash back into the camera after every photo to ensure the flash always fires in "Auto" mode instead of just in low illumination settings. Press the flash back into the camera to turn off the flash in "Manual" mode; otherwise the flash will continually fire.
5.Change the auto focus setting from "Infinity" to "Auto," "Macro Closeup" or "Self-Timer" by pressing the "Focus Mode" button once, twice or three times to automatically turn the flash back on.
6.Use only Nikon external flash accessories to avoid damage to the built-in flash and camera circuits.
I hope you find it very helpful. Thanks.
Aug 25, 2011 | Nikon COOLPIX L4 Digital Camera
When I try to take a flash photo I hear a repeated click followed by an 05 error code saying 'the built-in flash's auto pop-up was obstructed.' As as I can see, nothing is obstructing it. I opened the...
This is a mechanical problem probably due to some sand or such material preventing the smooth opening. Try cleaning the open flash hinges with a cloth or brush. Apply a compressed-air can spray and/or a vacuum cleaner nozzle to the area. This happened to me with the Canon Rebel model. Google for the problem specific to your camera model for other solution.
Please rate Fixya answers.
Apr 26, 2011 | Cameras
When taking pic an "err 05" (the built in flash was obstructed). On this camera eos Digital Rebel xti 400D. How do fix this?
The obstruction is often caused by the interior latch which refuses to move. If the flash cover ever opens, move the latch back and forward a few times which "sort of" re-engages it to its normal position.
Jul 03, 2010 | Cameras
I have a Canon EOS400D. Every time I try to take a flash photo there is a repeated clicking sound with error message 5 saying, "the built-in flash's auto pop-up was obstructed" yet I don't see anything...
The flash up switch is not working properly. It probably just needs to be disassembled and cleaned. About a $125 repair at most shops.
Hope this helps.
Wes Kauffman
Jan 05, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Camera Rebel XTi reads error 05 and the flash will not pop up
Err 05 means: Something obstructed the built-in flash's pop-up operation. Turn off the main switch and turn it on again.
Prepare to press the flash request button with your left hand. With your right hand, position your thumb and finger to gently pry up the flash head, perhaps using fingernails. Push the button and pry. With that help, it should pop up.
Dec 20, 2008 | Cameras
Mp160 printer
5100 is a carriage error, check the timing strip for contamination (plastic strip about 1/4" in width). This error means that there is something obstructing the printing process. (the side to side motion) Check inside your printer through the gears that you can see under the lid. There should be something obstructing the gears such as dirt or maybe built up crud. Once there was even some paper caught underneath the rollers that I had to jiggle around to even see. Check VERY thoroughly. A dab of alcohol on a qtip works great to remove built up ink, dirt, etc.
Feb 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Built-in flash auto pop-up problem
Does the 'pop up' pop up? If it does and still says obstructed- closes it and pop it again If it still persists Canon customer support will advise the next move. If a repair price seems high you could perhaps get a separate flash if the camera accepts them.
May 09, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Built in flash not popping up
Error 05 means - Something is obstructing the built-in flash.... Try to reclean it. Good luck!
May 07, 2007 | Canon Digital Rebel / EOS-300D Digital...
Error Message
Error 5 indicates - Something is obstructing the built-in flash....
Jan 03, 2007 | Canon Digital Rebel XT / EOS 350D Digital...
Canon Digital Rebel XT / EOS 350D Digital Camera with EF-S 17-85mm IS Lens Logo
486 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
