Question about Grilling
I don't know who to talk to but my gas grill which is a Weber+ the paint on the inside on the lid is starting to curl up and fall on our food who would I call
    Top Expert:
  • 16,281 Answers
Go to webers site and notify customer service
Posted on Sep 12, 2017
  • 2976 Answers
SOURCE: paint on top inside of lid is peeling off.
Remove the paint. The heat will dry the metal and grease from cooking will keep it from rusting, if it's iron. If it's aluminum it's not a problem.
Posted on Mar 14, 2009
  • 10 Answers
SOURCE: On the inside of the lid the paint or enamel
Most of the time what appears to be paint pealing, on the inside of your grill lid, is actually soot from your LP gas and bad combustion. May need someone to provide a thorough clean of your burners and check that your orifice sizes are correct and clean(holes on back of valves).   If you can, convert your grill to NG.. that will almost always solve a sooting issue(it burns much cleaner than LP)!  Hope this gives you some answers?
Posted on Mar 29, 2009
SOURCE: paint inside lid peeling off when I cook
From Weber.com Don’t worry, it’s not paint. The inside surfaces of our grill lids are not painted, they are coated with baked-on porcelain enamel which cannot peel. What you are noticing is a deposit of grease and smoke that collects during normal use. During use, the grease and smoke vapors slowly oxidize into carbon and collect on the inside of your lid. This deposit will eventually peel, and looks very similar to paint. The peeling normally starts in the center of the lid and spreads outward. It may come off in sheets or flakes, and is shiny on one side and dull on the other. These carbon deposits are non-toxic. But you might want to regularly remove the build-up. Fortunately, the peeling is easy to remove. Simply brush off all loose particles with a brass brush before you start grilling. To prevent future build-up, after every grilling session, while the grill lid is warm—not hot—wipe it with paper towels or a mild soap-and-water solution.
Posted on May 10, 2009
onyxvu
  • 74 Answers
SOURCE: weber gas grill will not ignite
you will probably have to get a new igniter or try to adjust the one you have. there is a little electrode on the igniter that needs to be clean and a certain distance away to work properly.
Posted on May 26, 2009
  • 512 Answers
SOURCE: The lid to my Weber Genesis Silver Gas Grill is
Go to weber.com you can order a new lid. They may replace for free if due to a defect.
Posted on Jun 13, 2010
How do u put together the weber 1520?
If you have the instructions, that is generally the best way. Manufacturers typically have non-experts follow the draft instructions and then try to improve them based on comments. If you don't have the instructions, then the next best option is to go to the weber site to see if they are posted there and then download them. If you can't find the instructions, and you're sure you have all the parts, its probably best to start with the base, then attach the grill housing without the lid, then install the burners and gas pipes inside, then outside, then finish with the lid and other outside details. I'm not specifically familiar with that model but the sequence should generally work.
Jul 22, 2011 | Weber Grilling
How do I get best results with the weber BBQ as far as heat efficiency
You can actually get some good cooking tips at the weber on-line site. That said, you really don't want to concentrate on efficiency but rather on the type of food you are cooking. I always used to stack the brickets in the beginning to get them lit and graying and then spread them for an even heat to enable cooking on all of the grill surface. If you need more concentrated heat from below then leave them stacked or in a bricket rack.
Jul 22, 2011 | Weber One Touch Silver Charcoal Grill
My weber genesis silver starts up, but doesn't get hot enough to cook the food. Seems like not enough flame out of either front or back burners. I tried Outting in a full propane tank, but that didn't...
Try these steps in order.
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
  10. Your grill should now heat normally
Sep 06, 2010 | Weber Genesis Silver B Grill
My Weber 3 burner gas grill is about 15 years old and still working well. It has wooden slats that I've replaced and wooden handle which I've restained with redwood stain. The one thing that I'm not...
Many places (K-Mart/Target) sell a high temp black paint specifically made for grills. You might try wire brushing it and repainting it.
May 13, 2010 | Weber Q Grill
My weber grill leaks grease from lid when it gets hot
This is common as grease condenses on the inside of the lid, especially on cooler days or when cooking very greasy foods like skin-on chicken. The only solution is to wipe down the inside of the lid after every use, especially along the bottom edges.
Jul 05, 2009 | Weber GENESIS E-310
How to Clean Weber Gas Grill Lid
you can only use oven cleaner on enameled hood not on the cast painted parts like the body and sides of the hood those you can scrape and vaccum or brush
Jun 28, 2009 | Weber Genesis Silver C Grill
Paint inside lid peeling off when I cook
Apr 25, 2009 | Weber Genesis Silver C Grill
On the inside of the lid the paint or enamel coating is pealing off on to the food. Weber rep. said they don't paint the inside of the lid, and is probaly residue from cooking. But I used the word (paint)...
Mar 28, 2009 | Weber Genesis Silver B Grill
Paint on top inside of lid is peeling off.
Mar 14, 2009 | Weber Genesis Silver B Grill
Grilling Logo
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Marvin
Marvin
Are you a Grilling Expert? Answer questions, earn points and help others
