Question about Garden
Engine runs but not at full speed
Can,t get engine to run at full speed and get white smoke sometimes
    Scholar:
  • 173 Answers
If it's an old engine, and has worked hard, all it's life, then chances are, that it's dropped a valve onto the piston.
Now the piston has a hole in it, the motor has dropped oil pressure, and won't be long until 'completely' dead.
What you need to do now, is to strip the motor down, and replace all the bits that need replacing.
Just make sure that you keep your eye on all the nuts/bolts etc,, and how they go back together.
Or, alternatively, get a mechanic/repair shop, to do it.
But get a quote for the work before though, because it may well be cheaper just to get another motor.
Good luck with that.
Posted on Jul 28, 2009
What is the problem with white smoke emission on my diesel engine?
It is burning engine oil, if it is turbo charged the turbo has most likely broken the shaft.
Jan 17, 2015 | Cars & Trucks
Engine running bad at idle
There are several causes for this, including the above.
Check the spark plugs and coils/wires. Lose or worn parts can cause this. If the spark plugs have thick black residue, you have an oil leak. A flat black powdery residue is too much air. A thick crusty white/yellowish residue would be a coolant leak.
If it is blowing blue or white smoke when running, the you have an oil (blue) coolant (white) leak that needs to be fixed. Normal smoke is grayish in color.
Check all the vacuum lines as a leak may be the problem.
Mar 28, 2014 | 1997 Dodge Stratus
New Toyota Etios, VD,KM 1100, observed thick white smoke from exaust pipe for @ 1 Min, while running engine on ideal.
the white smoke occurrence is due to unique Vehicle usageconditions like slow speed & Short trips drivingthe catalytic convertor is not able reach its optimum reactiontemperature. As a result, the Hydrocarbon accumulates in the Catalytic Converter.After sometime, once the saturation limit is attained, the accumulated Hydrocarbon
starts burning inside the Catalytic Converter. During this Chemical Reaction,Momentarily the white smoke is seen in the exhaust and is normal
Jan 20, 2013 | Cars & Trucks
1996 nissan navara diesel startred running rough and smokeing and can only rev to about 2 000 rpm
IF ENGINE SMOKING WHITE INCORRECT INJECTION TIMING TIMING RETARDED FUEL FULL OF AIR BUBBLES. IF YOU SEE BLACK SMOKE TIMING IS ADVANCED. IF YOU SEE LOT OF HEAVY BLUE SMOKE LOW COMPRESSION ENGINE BURNING OIL.
Jul 26, 2011 | Nissan Pickup Cars & Trucks
Drove thru ditch with water very deep on exit saw white smoke and running rough now on new start it productes white smoke untill engine gets up to speed and then runs good but an engine light comes on....
go through it with a new tune up. when exhaust is under water it turns into a suction and sucks water into the motor fauling out lots of stuff
Feb 06, 2011 | 1994 Isuzu Trooper
White smoke blowing out of exhaust?
black smoke is fuel white smoke is oil. change your spark plugs to a hotter plug and run with some hpr 50 engine oil or somrthing nice and thick
Oct 11, 2009 | 1996 Ford Thunderbird LX
PEUGEOT 1.9 D ENGINE LOSS OF POWER THEN WHITE SMOKE
Have your head gasket checked you may have a small tear or hole in it allowing coolant/water into your engine internals. This smoke and power loss probably also happens at highway speeds yet is not noticed due to cars momentum
Jul 09, 2009 | Peugeot Liberte Cars & Trucks
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
