SOURCE: half flush doesn't stop running
Yes, If I remember correctly you need to replace the flush valves. I cant remember if there is just one or two valves but they need to be replaced. go to your nearest plumbing supply house (a home improvement store will not carry it) and get a new valve. This will fix your problem.
SOURCE: Water flows unneccessary from the cistern in the
All you need to do is replace the tank flapper.
Testimonial: "Thanks for the tip.Flapper was fine,than I noticed that the round rubber seal was getting stuck.Cheapest solution - petroleum jelly...as good as new!"
SOURCE: hi, i have a caroma duel flush toilet possibly 10
First make sure it is not overfilling. The water level must stop before it reaches the overflow pipe. If it continues to run it will overflow into the bowl and continue to run. Adjust the fill level to the mark inside the tank. Make sure nothing is getting under the flapper and holding it open. You replaced the flapper so we know that is not the problem. Just make sure the flapper is centered on the drain hole.
SOURCE: even after filling up, water from the cistern keep...
That is the cistern overflow running.You need to adjust the fill level in the cistern by adjusting the plastic screw on the ballfloat or adjust the height of the float if its the silent fill tpe
SOURCE: I have an old Caroma Dual flush ( 15-20 years) and
Well luckly the velve can be replaced by a modern 1. iets not exspensive and dosent take long to do, u will get a step by step apon perches.
Plz rate my advice
