Need the make and model of the phone
the problem is more prevalent since the nbn roll out
on a uniden dect 6.0 the fix is found in the manual under resetting the voice message indicator
press the menu > answer set up
press the down arrow until Vmwi comes up
press menu
press the down arrow to get yes
save by pressing menu again then the end button
SOURCE: out of range shows on main handset of cordless phone
Unplug the battery. Hold down The * (star) and the #(hash) keys simultaneously. Re-connect the battery, phone will beep and screen will be blank. Press the voicemail (righthand silver key under the lcd screen). As above EEPROM/RAM message will appear. Place handset on base and your problem is solved.
SOURCE: deleting messages from handset
Not usually. I recently purchased a new (refurbished) base station and cannot get it to talk to the handsets
SOURCE: Registering a new cordless handset
It doesn't exactly "register" but you turn it on via phone programming.
Just plug it into the headset jack, then select a button to program and press PROG (the button) and dial 67 enter.
When you press the button, the light will turn on and the display will say HEADSET ON. Pressing it again will turn it off.
Carl
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
SOURCE: I need to deregister a
Called the manufactuer.... To do this enter on the handset you want to deregister:
*331734# and press (Menu Key# 1 - top uppermost left button that is unmarked).
This will put the handset back into the register mode.
Hope this helps,
James Pavicic Jr
