Question about Grilling
I need help to reattach two car badges to car - they are awkward as they are on the grill
    Top Expert:
  • 78,010 Answers
They make a special super sticky two sided tape for this purpose, contact a local automotive paint and body shop supply store to buy it.
Posted on Sep 11, 2017
Where's the safety rerelease in The grill rover 75. Year 2000
Once you have pulled the main release inside the car. (The small black lever in the right foot well). The safety release will then stick out of the front grill to one side of the front badge.
Mar 01, 2018 | Rover Cars & Trucks
How do i remove the bonnet badge on a 2001 s type jaguar
hi .. if you mean bonnet badge and not grill badge .. I'm more than 90% certain it is fixed with a self adhesive pad on the back of the badge as I've never seen holes in the bonnet for the badge, have a careful look around the edge of the badge for signs of the adhesive pad.
Jun 15, 2014 | 2000 Jaguar S-Type
Bonnet not open in side ford galaxy
not an expert but have you checked the ford badge on the front grill to see if it flips open with key access under badge
Dec 30, 2011 | Ford Cars & Trucks
Need instructions to replace the passenger side mirror and the driver side tail light on a 1999 Ford Taurus 4-door sedan. Thank you, Gary S.
Section 01-09: Mirrors, Rear View 1999 Taurus/Sable Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 06/25/1998 Mirror, Power-Outside Rear View Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942). Refer to Section 01-05.
  1. Remove radio speaker grille from cover assembly by squeezing or pinching between thumb and index finger.
  1. Remove two screws from cover assembly.
  1. Disconnect outside rearview mirror wiring connector (C515-LH; C615-RH). Remove wiring guides as necessary.
  1. Remove three outside rear view mirror retaining nuts. Remove outside rear view mirror (17682) while guiding wiring and connector through hole in door.
Item Part Number Description 1 17682 Outside Rear View Mirror 2 N621906-S36 Nut (3 Req'd) 3 F8DB-17D699-
AAW Cover Assembly Rear Substrate-LH 3 F8DB-17D698-
AAW Cover Assembly Rear Substrate-RH 4 N808968 Screw 5 F8DB-18B984-
AAW Speaker Grille-Standard (No Badge)-LH 5 F8DB-18985-
AAW Speaker Grille-Standard (No Badge)-RH 5 F8DB-18K901-
BAW Speaker Grille-Mach-LH 5 F8DB-18978-
BAW Speaker Grille-Mach-RH 5 F8DB-238A35-
AAW Speaker Grille-Blank (No Speaker)-LH 5 F8DB-238A34-
AAW Speaker Grille-Blank (No Speaker)-RH A - Tighten to 6-8 Nm (54-70 lb-in) ------------------
Trim Panel, Door Front
  1. Remove cover behind inside door handle.
  1. Remove screw from bottom of pull cup retaining front door trim panel to front door (20124).
  1. Remove three screws retaining front door trim panel to front door.
  1. NOTE: Do not attempt to remove more than one pushpin at a time.
    Using Rotunda Windshield and Molding Trim Removal Kit 107-R0401 or equivalent, remove the door trim panel by pulling one door trim panel pushpin at a time from the inner door skin.
  1. Disconnect electrical connectors as necessary. Refer to Section 01-14A.
  1. Follow removal procedure in reverse order.
  1. Replace all pushpins with new pushpins (N808994-S).
Front Door Trim Panel
Jan 14, 2011 | 1999 Ford Taurus
I am trying to replace the front badge on my Ford focus (it got snapped off), but I can't get the grill off since the screws (plastic screws on top of the grill) just keep turning but don't come out?
I would suggest that you while screwing them put pressure on the top as if pulling a nail out. If still nothing pull them right out. I went to my dealer and got 12 for 7$ good luck
Mar 22, 2010 | 2001 Ford Focus
The location of the bonnet catch on a ford focus
Behind ford badge on front grill
Flip badge insert key one way unlocks other way releases.
Dec 20, 2009 | 2008 Ford Focus
How do I open my bonnet on a ford fiesta 2000 model?? Cannot find any lever inside the car
Oct 18, 2009 | 2000 Ford Focus
2004 Mondeo bonnet not releasing on key position No.2. I have drilled out the two shear bolts behind Ford badge after making 2 holes in grill. The lock is now free to swivel, so will it come out if I make...
put a screwdriver into the keyhole and turn it,if it wont turn cut out a large hole directly behind the ford badge and pull out the lock a little way and then turn it.You dont have to take it all the way out.Idid this to mine its very easy,also check your key because it may be worn.
Apr 06, 2009 | 2001 Ford Focus
Ford Focus front badge
lift bonnet and remove the grill this model has the bonnet opening with the key when you lift the badge.then replace the whole unit,or visit a nocturnal spares place ie car park late at night.with just a badge drill a small hole and a nice chrome screw in
Jul 05, 2008 | 2001 Ford Focus
Grilling Logo
63 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
