Air conditioner keeps triping breaker - Heating & Cooling
    President:
  • 1,922 Answers
Has it always done this, if so sounds like you need a higher amperage sub panel to supply the unit,otherwise maybe the contactor or compressor is going bad
Posted on Jul 30, 2009
5 Suggested Answers
  • 5 Answers
SOURCE: keeps triping breaker in air con unit
I am not an a/c person, but am offerring up this one thing that I've heard.....
there are capacitors that are in the A/C unit's outside (compressors) and in the heating units (typically in the attic). If these get bad they can cause the compressors to have to work super extra hard and that can be what is causing it to get overheated - I'd be very very cautious at this point and spend the buck to have someone come out. If that is the case the compressor may already being in failure mode. We were fortunate. We caught it before ours went totally out, but for years it has been bad and has caused the compressor to work doubletime - call someone on this!
Sorry! :(
Posted on Nov 22, 2008
FunnyPlumber
  • 43 Answers
SOURCE: AC main Breaker
There are many things that would cause this problem. It would be best to have a qualified technician test your system to find the cause.
Posted on Jun 30, 2009
james3751
  • 614 Answers
SOURCE: amana air conditioner keeps popping its cord breaker
This a ground fault breaker. They do go bad. Is it kicking it all the time or when you plug it in. I replaced a lot of the ground fault plugs. You have to go to the Appliance Parts store to get a new power cord. If you have a problem with thisyour warranty should cover the power cord check your warranty. Rus
Posted on Jul 11, 2009
  • 66 Answers
SOURCE: Air conditioner will not keep running
Any one with a window; these units must be cleaned at least yearly.First off,there is a filter in the front below where the cold air comes out,inside the intake grill(where the room air goes back into the unit.) it should slide out. Second the unit has another coil at the rear of the unit.The rear coil is hard to clean, but is possible.Check if warm air is going out at the rear.If not unit housing must come off to clean rear coil properly.After a year ,or two this problem will very probably blow the compressor.You should be able to call a few A.C. companies and see if they clean windows A.C. units.
Posted on Feb 18, 2010
WHEN TO USE A KICKSTART CAPAITOR
Be sure the breaker is the right size for your unit. An under sized breaker will trip at the start. A bad compressor usually wont try to start.
Aug 28, 2014 | Heating & Cooling
Keeps triping my fuse box
Your circuit breaker is bad,can't tell by looking,remove and take to lowes and match up and install and see if it trips again.
Oct 10, 2012 | Hotpoint Aquarius WD63 Front Load...
Unit triping braker when compressor turns on
the breaker is underrated the power that it takes to start the compressor is really big but only for a few seconds. That is called the inrush and the breaker should be rated for HVAC wich allows for this.
Mar 15, 2011 | Fedders 9,000 BTU Electronic Portable Air...
WILL NOT TURN ON
ckeck for a reset on the cord where it plugs into the wall push reset if so..check the breaker box the breaker could be off or triped ..good luck/joe/
Aug 25, 2010 | LG Heating & Cooling
My air conditioner keep triping my generator breaker.
Sounds like you have bad compressor that is pulling too much current when it tries to start...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 17, 2010 | Dometic Rooftop RV Air Conditioner
Ac keeps triping breaker
I take it this is a rooftop unit on an RV? Please confirm with a few more details like was it o.k. recently, etc.
Aug 06, 2009 | Dometic Heating & Cooling
AC main Breaker
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
Keeps on triping braker
Unit should be tested, You have a "ground fault" condition.
May 26, 2009 | Whirlwind FH-778 Air Conditioner
Ruud Problems
compressor is probably bad. disconnect it tape the wires off and start unit. if breaker doesnt trip it is the compressor.
Aug 17, 2008 | Ruud UAKA030 Air Conditioner
Heating & Cooling Logo
95 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
