Question about Logitech Cordless Mouse
Wont connect to computer though the reciever appears to be working fine, and the mouse appears to be switched on too. It has new batteries and i have repeatdly tried to connect them - it wont work!
    President:
  • 1,383 Answers
Uninstall driver then reinstall your mouse driver again it should be working fine.
Posted on Jul 28, 2009
Logitech wireless mouse (m305) isn't working
Does this mouse need to sync with the reciever plugged into the computer?
Somewhere on the mouse and posssibly on the reciever plugged into the USB
port on the computer it should have a connect button. Usually to connect/sync
a mouse or keyboard press the button on the reciever first then press the connect
button on the mouse. Or if th mouse has a button just press the mouse button,
often the mouses lazer will blink until the mouse connects with the reciever then
just stay lit at this point it sould work. Another Question, how are the batteries in
the mouse?
May 19, 2011 | Logitech Cordless Mouse
The key board has lost its connection, please help. we hve tryed new batterys. the mouse still works.
mcdevito75 here, Sounds like you"ve lost the connection between your keyboard and reciever, that little angled piece with a button you press and lights up. First double check connection on your computer for this reciever, Then double check intsatlation of batteries in keyboard. NOW, press button on reciever, now press button under mouse and wait 20 seconds now press button on reciever then press button under keyboard. This should do it.
Jul 27, 2010 | Logitech Cordless Desktop MX 3000...
Arc mouse wont turn on, it was working fine until it started to get unresponsive and the red light started flashing so i replaced the batteries but now it wont turn on. I even tried connecting the reciever...
In extensive use the USB-device overheats. Removing it when not in use helps, but it is allready permanently damaged and only real solution is to switch the mouse to new one.
Guarantee is 3 years. Wich is a good thing because these tend to fail in 6 months to 2 years.
May 27, 2010 | Microsoft ARC Mouse
Mouse won't work
To fix the problem,
please press the connect connect button on the bottom of the mouse and the connect button on the reciever and relaese both the buttons together. this would rest the wireless connection and then the mouse should work fine.
also try a new set of batteries
regards.
Jan 28, 2010 | Logitech Cordless Mouse
Keyboard wont connect
Hello
I've had the same problem with the Keytronic stuff. Most of the time new batteries solve the issue. Once, though, batteries didn't help. I discovered that if I wiggled the batteries it would work. I tried an old trick. Using a straw, put a drop of Coke on the connections. Scrub the area with an old toothbrush. If there's residue use rubbing alcohol to remove it.
Good Luck
Sep 24, 2009 | Logitech Computers & Internet
Microsoft Notebook Optical Mouse 3000 is not working, reciever??
Your mouse is not sending any signal to receiver. Both items are working.
First look for a tiny thin button that protrudes from one of the sides where the receiver is placed in mouse, it might be stuck, push it gently down a couple of times, it has to be out for as long as the receiver is in the USB port.
If it still doesn't work, take the battery off, while holding down said button insert a new and fresh battery and then simultaneously release the button also considering that the battery terminals are clean. Hope you can solve your problem. Good luck!!! Chawah.
Jul 12, 2009 | Microsoft Wireless Notebook Optical Mouse...
Wireless mouse doesn't work
This problem was happening on my system but i managed to fix it easily! What has happened is your itouch software has become corrupt so it will only recognise your keyboard thus the usb connection. You will need to download/install off disc onto your computer again but do NOT go to uninstall program manager on windows as it will not appear there because even though you can access the itouch configuration panel, the database is corrupt and the administrative system will not recognise this. Just download/install via disc and it will just install with no alerts unlike most programs which will recognise the program is already installed onto the system. Once the setup is 92% it will freeze for a second then the found new hardware window will appear on screen go through that process and your mouse is back to normal and your keyboard will work via itouch software.
(Please note that this will only work on windows)
Nov 26, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
Microsoft wireless notebook optical mouse 3000 Doesnt seem to work?
Okay, a coworker had this problem and it was a fairly easy fix, first, plug the USB reciever into a direct USB port, then pess the connect button on the underside of the mouse, when the red light starts blinking let go and then press it and hold, and at the SAME TIME press and hold the connect button on the receiver until both the receiver light and the mouse light turn on steadily, and voila!
Aug 04, 2008 | Microsoft Wireless Notebook Optical Mouse...
New wireless keyboard and mouse problems
Okay, it was as simple; hold the button on the reciever dongle for a couple of seconds, and the the same with the keyboard or mouse.
Why can't they just make the instructions clearer
many thanks Saigua
Aug 03, 2008 | Computers & Internet
GE Wireless Optical mouse 97990 Rev. 4
You need to plug in the USB reciever load windows till desktop appears, hold down the reciever button until it flashs then quickly turn over mouse and press connect button in. and you should see the reciever flicker, and it should start working. if it dont try swapping the batterys as they dont last long...and repeating the same process Hope this helps John
Feb 22, 2007 | GE Wireless Optical Mouse
Logitech Cordless Mouse Logo
163 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
