Question about Konica Office Equipment & Supplies
I need to reboot a Konica Minolta 8050 printer copier with error code SC27-04
  • 1 more comment
  • peacock146 Jul 28, 2009
    turning on or off, unplugging does not solve the problem. you can unplug it, plug it back in, start from scratch, and the error code constantly stops and interfers with the boot process. the printer will not go past that error code
  • peacock146 Jul 30, 2009
    nobody was able to fix this problem
    we added- changed the black toner
  • 2,200 Answers
Hi
This error is as follows
SC27-4:
Output of toner density sensor cannot be controlled.
If someone has removed the lid of the developer tank then you will get this fault. It is possible you will have to replace the developer tank in order to get this fault to resolve.
You should check the connnector to the toner sensor on the developer tank to make sure it is not disturbed.
Disconnect printer from mains altogether and then power up again. If problem does not resolve - replace developer tank.
Hope this helps. Please remember to rate my answer. Many Thanks.
Posted on Jul 31, 2009
    Genius:
  • 1,689 Answers
Normal printer resents if you unplug the device without turning it off and leave it like that for at least an hour, better if over night.
what was the last thing you tried to do before the error occurred?
Posted on Jul 28, 2009
  • 601 Answers
Hi...
Error Code : SC27-4:
Output of toner density sensor/K (TDS K) cannot be controlled.
Unplug the power cord that should reboot the copter.
Let me know
Thanks
Smith
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
Konica minolta c280 showing error codes 3423, 3334 and 2451 How can I clear the codes
2451 replace the cyan (Blue ) Image unit
3423 replace the fuser unit
3334 No such code
Jan 09, 2017 | Konica Minolta Bizhub C280 Color Copier /...
Error c-0200
konica minolta bizhub malfunction detected error code c-0200
Sep 01, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
I have fetal error code 08H,14H &15H in KONICA MINOLTA Magicolor 2430DL. pl help to resolve the problem
 When fatal error codes are displayed call tech support at Konica Minolta:
http://kmbs.konicaminolta.us/content/salesservicelocator/findservice/findservice.html
FATAL ERRORCODE:XX
An error has been detected with the item indicated "XX" in the service message.
Reboot the printer. This often clears the service message, and printer operation can resume.
If the problem persists, contact Technical Support
Jul 14, 2010 | Konica Minolta magicolor 2430 DL Laser...
Error code c2152
good to
Imax Konica Minolta C451 Bizhub
I have a problem is the cod C2151 what to do Thanks
Sep 24, 2009 | Konica Minolta bizhub C450P Laser Printer
Problem with my Konica Minolta bizhub 350
The code is for fusing warm up failure. Turn the machine on, wait for the error, then open the front door - you will see a cover on the right hand side which you need to unscrew and remove, behind that is a board (PWB-S1- Tech. Rep. Setting Switches Board) press the trouble button then reinstall the cover and shut the door. Your printer should now reboot - if the error comes back you will need to have the fuser either repaired or replaced.
Sep 01, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta biz hub c350 malfunction code c-0b4c
C0B4C Finishing option Exit Motor malfunction
Try reboot holding utility key down and do trouble reset, if it doesn't help then there is something wrong with exit motor, call for service
Dec 06, 2007 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta Bizhub 350 Error code c0211
It means Bypass Lifting Motion Failure, check pick-up solenoid and lift up sensor.
Reboot machine holding down utility button, then do trouble reset, if nessesary reboot again.
If this error occurs again, you have to call for service
Aug 06, 2007 | Konica Minolta bizhub 350 All-In-One Laser...
247 people viewed this question
Top Konica Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Andrew Taylor
Andrew Taylor
richie46
Are you a Konica Office Equipment and Supply Expert? Answer questions, earn points and help others
