Question about Grinders
I have just received a new switch and have 4 wires that go to it the switch number is ht6481934 please help
  • 90 Answers
Its simple. get a multy meter put it on continuity,
that the setting when u touch the two leads u get a buzzing sound, then put the switch in the on setting, and test the terminal till u here the sound.
next step.
the current cable has two colors. connect them apposite to the buzzer terminals then same for the other two wires.
before u plug it in check it over with a the meter. if the hook up is correct, one line from the cable and one from the machine should be on one line..
Posted on Jul 31, 2009
My s5 I can send text to all numbers and they can receive my text but there is 1 one number that I can send but they never receive my text can you help me please
if its just one number, might be their network provider. or if you came from Iphone and switching to Android, turn off imessages before switching to new phone.
Apr 08, 2017 | Samsung Galaxy Cell Phones
I have a Kenwood stereo receiver model k2 3600 , the left speaker keeps going out , the right speaker works fine. I've tried adjusting the speaker wire for the left speaker, and I always end up having...
HI,
BASED ON THE INFO YOU GAVE I HAVE SOME SUGGESTIONS BELOW..
1, switch the working right speakers cable to left output and problem left to right (from the back of receiver -not from the speakers it self..) to see if problem continues..
2.After switching them ,if it (old left new right one ) still stops left speaker cable may have short ( a tiny cable inner pieces may touching to other side ) at either at the back of receiver output or at the end ,at speaker input .
make sure you control it carefully...if the problem persist please contact to me..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Thanks
Jun 17, 2011 | Kenwood Audio Players & Recorders
Hi! Please help me. I am having trouble connecting the wires from my dead 220v T104 pool pump timer to a new 220v T104 timer. The old timer had posts marked G 1 2 3 4. The new one has posts marked L 1 X...
Open following link for T104 wiring diagram:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Your new timer is L 1 X 2, so that is not Intermatic T104.
You might have GE/Tork 15061 that fits into Intermatic box.
http://waterheatertimer.org/GE-timers-and-manuals.html#GE-replacement
First thing to check is if new timer is 240Volts to match old T104.
If new timer is 240V, then here is crossover:
"Old 1" goes to new L >> and notice that L and 1 are connected by brass bridge. If bridge is missing, add a jumper wire between L and 1 on new timer
"Old 2" goes to new 2
"Old 3" goes to new X
"Old 4" goes to new X
T104 Intermatic timer is SPDT single pull double throw, so it turns off both wires going to Load.
New L1X2 timer is SPST single pull single throw, so it turns off one wire going to Load, and that's why old 3 and old 4 both connect to terminal X.
If this is too complex, then add a comment or buy new trippers and a new WG1573 clock motor and repair T104 for $20.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
Apr 22, 2011 | Intermatic T104 24h 208-277v Mechanical...
Receiver 85112-04 need a replacement for hunter fan remote receiver which is housed in the based of the fan in ceiling.
I realize that this is an old post. However, the best solution is to replace the receiver with 3 or 4 speed wire harness, which includes the capacitor, fan speed switch, forward/reverse switch and female plug for $15 as of today's writing. While you may be able to find a 85112-04 replacement receiver, I found them to be an expensive solution at $80. In addition, there is no telling how long the replacement receiver would last. To purchase a 4 speed wire harness for this Hunter fan, they can be ordered from
Casablanca. Casablanca you say? Yes! Casablanca is a subsidiary of Hunter Fans. This 4 speed wire harness, part number K016501H01, is standard in many Hunter and Casablanca fans. Hopefully this will help someone looking for a low-cost solution to replacing the fan. Link below:
http://www.casablancafanco.com/Parts-Manuals/Part-Manual-Detail?ModelNumber=54019
Apr 11, 2010 | Hunter Ceiling Fan Remote Receiver...
We have an older home, there are to light switch plates with 4 on/off swithches on each. The switch plates we would like to put in are just 3 on/off switches, as some of the old ones shared light sources...
I can help, but I need a lot more specific info. Please use these naming conventions to describe what you have:
G1, G2 -- the two gangs of 4 switches each G1S1 - the first switch in gang 1 L1 - light, appliance or outlet number 1
Describe how each light is controlled as follows: L1 - G1S1 & G2S1 (one light controlled by a pair of 3-way switches) L2,L3 - G1S2 (assumes a normal switch controlling two lights) etc. for all of the L's presently controlled by all 8 switches
Then describe what you want the 6 new switches to operate.
Mar 18, 2010 | Leviton 003-1755-W Three Rocker Switches
I need a wiring diagram for this stereo
FOR 16-PIN HARNESS
Pin Number Wire Color Function 1 White Left Front (+) 2 Green Left Rear (+) 3 Violet Right Rear (+) 4 Grey Right Front (+) 5 Blue/White Amplifier Remote 6 Blue Antenna Remote 7 Red Accessory 12 Volts 8 Black Ground 9 White/Black Left Front (-) 10 Green/Black Left Rear (-) 11 Violet/Black Right Rear (-) 12 Grey/Black Right Front (-) 13 Sky Blue Telephone Mute 14 Orange/White Illumination 15 Not Used Not Used 16 Yellow Constant 12 Volts
FOR 9-PIN HARNESS
Pin Number Wire Color Function 1 Not Used Not Used 2 Black Ground 3 Grey Right Positive 4 Grey/Black Right Negative 5 Blue/White Amplifier Remote 6 Red 12 Volt Switched 7 Yellow 12 Volt Constant 8 White Left Positive 9 White/Black Left Negative
MAY THIS HELP YOU
Jul 04, 2009 | Sony CDX-GT210 CD Player
Hunter speed control problem
I have the exact same problem. Called Hunter's tech support and they confirmed the capacitor must be bad. This is the black box that has 4 wires going to the switch. They are sending me a new one for under $12. I haven't received it yet, but the wires from it going to the switch can be removed from the switch by shoving a paper clip along side the wire, this'll release the spring clip holding the wire in. Not sure, but I may have to cut and wire nut any wires that go elsewhere.
I recommend you call them too and as long as you have the 5 digit model number (usually on top of fan) they should be able to get you what you need.
P.S. it is highly unlikely that it is in the switch. I tried replacing it with one from Home Depot and I actually got Low-Off-High, which is worse. The Hunter tech support guy said you can't use after market switches with their fans.
Jun 10, 2009 | Hunter Ceiling Fan Control Switch
Wht wire gauge 2 choose?
You can run anywhere from 12 to 16 guage speaker wire. The higher the number the thinner the wire. If you found this solution helpful please rate it.
Thanks - Tech101
Jun 24, 2008 | Audio Players & Recorders
GE Stove
I'll need a model number to determine what's going on and whether the part is really a generic. They should have given you some kind of installation instructions.
Dec 24, 2007 | Kitchen Ranges
Grinders Logo
90 people viewed this question
Top Grinders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you a Grinder Expert? Answer questions, earn points and help others
