I use the D-Link DI-704p router for an ethernet Lan with 8 Macs. Fast
in the morning, horribly slow up/downloads in afternoon. Output runs at
half speed of input from provider when tested in afternoon.
type user name as "admin" and password as "admin" or blank or "password"
then go to wi fi advanced then check signal channel type 4 , 6, 11 are working fine try 1 by 1 theses channel then check. Set channel which give most high speed. When you set channel always save settings then restart computer and router both after save settings then check. Thanks for using fixya.
D-Link DI-704P Router was used only as a switch (DHCP turned off) and worked fine while connected to...
(More)
D-Link DI-704P Router was used only as a switch (DHCP turned off) and worked fine while connected to the LAN via LAN (not WAN) input and provided connection to the (home) network for not wireless PC and Laser Printer (using router's printer port) for a few years. All over a sudden it stopped responding, I can not reset it to the facory settings (followed all published procedures). If this is a known issue please help to resolve. Hellooooooooo experts, need your help. Appreciate .............. Alex.
Hi everyone! I got a problem with my D-Link DSL-604T ADSL modem router. Suddenly, after a climate...
(More)
Hi everyone! I got a problem with my D-Link DSL-604T ADSL modem router. Suddenly, after a climate storm the device enter in a LED flashing light which wasn´t occurring before. This is the second time I got this. That happened wiht other Dlink modem Router before. This one still working with WIRELESS COMMUNICATION, B U T no more wired PCs can access the Internet. The PC says "... Lan cable not connected. Please verify your cables... I powered off the routers many times and for long time period, That still happen. I switched the cables from different RJ45 router ports and I also removed the DLink switch box in the middle I had. Seems that everythink stays the same. Can ANYONE HELP ME PLEASE. Any clues or suggestions what this may be..... Regards LUIS
im trying to view tv from internet but modem is in seperate room i tried to use the d link i think i...
(More)
im trying to view tv from internet but modem is in seperate room i tried to use the d link i think i am not conecting them corectly can you advise
