It just clicks several times when I try to start it
    President:
  • 1,776 Answers
If the washer is just clicking and not filling with water, I would look at faulty inlet valve solenoid(s). You can test them for continuity with an ohm meter or multimeter to see if they are faulty. If the resistance is zero ohms, the solenoid is stuck open and is defective. Here is what the valve assembly looks like. Hope this helped and best wishes.
Posted on Jul 28, 2009
I have a very hard time starting my 1998 mazda . The only way that it seems to start if I hold the gas down and try several times. Do you have any idea what it could be
TONS of things, but several questions come up? Does it spin over or just CLICK? Does it stutter and stammer like t wants to start but can't "catch"? When was your last tune up? (plugs, wires, filter changes, etc.) There are many, many things that prevent a car from starting, so a detailed account of the issue has to be stated in order to help you.
Please try again.
Aug 30, 2014 | 1998 Mazda 626
Chev prizm abnormal start. turn key CLICK SOUND,THIS HAPPENS SEVERAL TIMES AND THEN FINALLY CAR STARTS
Starter going out. Also check battery, Make sure it is still charger/holding charge.
Mar 28, 2013 | 2002 Chevrolet Prizm
2003 buick century won't start
sounds to be the starter going bad
Dec 21, 2012 | 2003 Buick Century
Sometimes I turn the ignition key to start my 2007 4.7 v-8 tundra pickup & I just here a click after trying several times the starter engages . Not several clicks just one . After checking battery...
The problem is the starter solenoid. It will steadily get worse until it just won't start anymore. The solenoid has corrosion between the contacts. When you turn the key the contacts are not making connection. The corrosion will get a little worse each time you crank it.
Oct 29, 2010 | 2007 Toyota Tundra
2006 Buick Terraza won't start. All power is there, but it clicks once and won't turn over. Has done this three times recently and dealer service can't find anything, stores no codes. Noticed that it did...
solenoid just clicks? put a new solenoid on it then if the connections are clean and tight on the old one. When the solenoid just clicks it is shorted out
Jan 24, 2010 | 2006 Buick Terraza
My lawn tractor has had a problem needing to choke it several times to start it and after trying it several times, it would only click. The battery is new. I am trying to do my thing and was told it could...
Try the easiest things first.
1) jump start with your automobile
2) check to see if starter is free
a) *with your hand, turn the flywheel screen on top of the engine
b) connect the jumper wire to the cable post (positive or red cable)
connect the negative to the battery
*NOTE: many times the starter gear can become locked into the flywheel, and the battery is not able to overcome, and you will hear a click from the solenoid.
3) If #2 works, then replace the solenoid
Nov 13, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Dead key all lights are ok carwont start no click click click
try starting it in neutral. sometimes the neutral safety switch thinks you are just outside of park (aka in reverse). this switch will not allow the car to start in any gear except park and neutral. also, try shifting firmly in and out of park several times. this may trip the switch. good luck
Oct 29, 2009 | 1998 Chevrolet Monte Carlo
2005 chrysler Town&Country clicks when attempting to start
If the click is one click then that points to the starter. Make sure the battery connections are tight. If it clicks like a machine gun then it is either the battery or a bad connection. Good battery voltage is 12.6 or more and 13.6 when running. I don't know tour skill level of electricity.
Sep 25, 2009 | 2005 Chrysler Town & Country
Prints have a green tinge when printed onto paper
hello. try cleaning the nozzle several times. heres how... 1. select start menu 2. select control panel 3. select printer 4. right click your printer model 5. select properties 6. select maintenance menu 7. select nozzle print thats it... if still the error is the same, try deep cleaning several times, it works to me Im sure yours too...
Dec 21, 2008 | HP PhotoSmart 7760 InkJet Printer
1999 toyota rav 4 will click when trying to start but won't start engine
if it clicks one loud time then its maybe the starter. if its several little fast clicks then the battery is just dead enough not to turn the car over
Oct 11, 2008 | 2006 Toyota Sienna
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
