Dell 1720dn Laser Printer Logo
Posted on Jul 28, 2009
It prints gibberish before the print job.
Before a print job, printer prints a page every single time with characters (heart, smiley, etc.) on top of the page. When I send a print job, it looks like it is going to print, it runs for a while than it stops and spits out a page with characters and then it prints the real job. It wastes a lot of paper and time. Any help would be great. Thanks,
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Aug 05, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
771
Points
I have had this happen before, this could be you need to change the drum kit on the printer itself, check the indicator light.
I print out 1 single document of bar code , but the printer wont stop
The print job is not formatting properly for your printer. It keeps corrupting and will cause the printer to spit out multiple pages with either gibberish or unusual fonts of varying size.You may need to recheck the software you've written the bar codes and make sure your using the correct code 39 font to create your barcodes.
How to stop printing
While your question is not quite clear, I will provide a couple of suggestions. Usually when you press the cancel button, it pauses the printer and then you must use the arrow keys to select cancel job and then press the checkmark. Also check any computers to make sure that they do not have a job in their print queue. If the printer does not send back a job complete command, sometimes the computer will keep resending the job. Failing all else, restart your computer and your printer. Are the pages that are printing gibberish or is it the correct print job? If gibberish, you might have a corrupted print driver or the file you are printing might be corrupted.
Separator Sheets with smiley faces
Attempt to restore printer to factory defaults to cure this issue.
2answers
Hello, I have problem with Printer Kyocera FS-1300.. when i connect it to pc, it starts to print some symbols, like smiley face on left corner of page, and i cant stop it, when i disconnnect my device...
Hi. I would suggest that you unplug the printer, reinstall software and check you computer for viruses. If i continues, try letting it print out. maybe someone set so that 30 pages with a smiley would be printed next time you plugged it in. I how this will fix you problem.
My HP D7160 inkjet printer prints 3 pages every time I reboot my system. It prints a few characters of gibberish at the top of each of the pages. This is extremely annoying, particularly when I am...
open its directory by click in the tray system ..(right where the programs are opened) ..just right click on the printer ..and choose to go in the printer folder..there it will be the issue you are talking ..the previous jobs and errors..just try to eliminate by click-right on them and delete ..
so ..make a habit to check this folder for remaining jobs that loops and may cause issues..if they remain there and are not deleted..
Printing gibberish
gibberish printing is normally a sign of outdated print drivers. Try going to HP's support site and download the latest PCL driver.
Crazy characters start to print when printing from pdf doc or certain websites
I understand that the printer is printing garbage when you are trying to print from internet.
Please follow the below given instructions to resolve the issue.
This issue can occur if the data send from the application from which you are printing, is using the PC-8 character set. This will produce a smiley face or garbage charters each time an unsupported escape code is sent by application. To know the character set, please contact the manufacturer of the application.
Also, you can follow these steps to disable the power managment in the comoputer.
1. Right-click My Computer, choose properties
2. Click Hardware tab, click Device Manager button.
3. Click the + next to Universal Serial Bus Controller.
4. Right-click USB Root Hub, choose properties.
5. Click Power Management tab.
5. Uncheck the option "Allow the computer to turn off this device
to save power.
6. Click Ok.
If the issue persists, follow the instructions from the below given weblink to resolve the issue.
Here is the web document:
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=bpu01105&cc=us&lc=en&dlc=en&dlc=en&lang=en
Just copy and paste the entire link into the Internet browser's address bar and press enter.
This should resolve the issue.
Regards,
Lawrence
The printer keeps printing pages of single line code even offline
hi i am having roughly the same problems i use cad and have not even managed to print that far yet what windows are using?
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
