Question about Car Audio Receivers
Panasonic VA70 rear view camera
We have a Panasonic VA70 rear view camera on our motor home. The monitor stopped working suddenly and will not turn on. We checked all the fuses and cannot find the problem.
0 characters
1 Points
How you make the camera work for front view on alpine INEw927hd? How do you connect the camera that came with the unit?
you must buy one of these camera and install one in the front of vehicle and one in the back to inew927hd. read the following (With front or rear camera installation, the screen on the INE-W927HD will automatically switch to your front or rear camera view. For the front of the vehicle connect the HCE-C212F or HCE-C200F and for the rear, an HCE-C210RD, HCE-C200R, HCE-C117D, HCE-C115, or HCE-C104. These camera systems will work directly with the INE-W927HD for a clean and easy install. For camera multi-view control directly from the INE-W927HD, the HCE-C210RD for the rear and HCE-C212F for the front can be used.) camera setuppage1 camera setup page 2 , camera setup page 3 depending on the camera installed certain cameras allow different displays on the video screen ... any more questions email me at
Oct 27, 2013 | Alpine Car Audio Receivers
Suddenly no sound from my radio/
You might want to try checking all of your fuses. In newer vehicles there are generally two fuse boxes, one in the engine compartment under the hood and one in the vehicle, usually under the dash or in a kick panel. There may also be a fuse inline on the wire harness or on the back of the deck.
Nov 25, 2011 | Sony CDX-CA600X CD Player
It turned off for no reason now it wont work
check your fuse panel, and if it is good, then check the inline fuse for the stereo
Apr 09, 2011 | Panasonic CQ-C5305U CD Player
My Kenwood DPX-4020 suddenly turns up to max vol
you probably have a bad switch. you need to use a multimeter and check the resistance of your volume up switch, if less than a few meg., the switch is bad.
Oct 05, 2009 | Kenwood DPX-4020 CD / Cassette Player
Head unit keeps blowing fuse for interior electronics of durango
go for a new fuse
if it is 10A go for 15A
add +5Amp fuse to your present fuse
and then try
reply by a Vote
Sep 21, 2009 | Alpine CDA-9827 CD Player
Panasonic R 805e with cd shuttle
I had a similar sounding problem with my stereo and got the following response here...
"It sounds like a bad ground wire connection-you want to check the rear of the head unit and make sure that your wire harness is very secure to the unit clip the ground wire and run your own ground wire to somewhere-anywhere where you can safely ground that wire to the chassis I actually attached my ground to the rear of the cigarette lighter because you KNOW that it has a dam good ground to manage all the current it takes to light them coils orange like that"
I took the advice and it worked out great! Give it a try and see what happens.
Apr 05, 2009 | Panasonic Car radio CD CQ-C1110GN CD...
You can check out the parts available from Panasonic at thier web site - here's the page with the parts list that are still available: If you don't want to do that - I'll buy the unit at a reasonable price. The unit in my motor home that I just bought doesn't work and the wiring harness is integral to the dash wiring harness since it was factory installed so I want to replace the unit with an identical unit. eMail:
Nov 05, 2008 | Panasonic CQ-DP102U CD Player
Clarion dxz545mp doesn't power, does not work.
Check the fuses in the fuse block under the hood. Your clock fuse and radio constant power fuse are combined in this vehicle.
Jun 11, 2007 | Clarion DXZ545MP CD Player
Car Audio Receivers Logo
557 people viewed this question
Top Car Audio Receivers Experts
xxxxxx xxx
Are you a Car Audio Receiver Expert? Answer questions, earn points and help others
