Question about Dell E153FP 15" LCD Monitor
I have a dell monitor E172FPb monitor and all it will do is the power button flashies green. I have read forums that refer to replacing the four transisters on the logic board but state that is no quarantee. It seems that the whole logic board is rather cheap (40.00 on Ebay) would that probally be the best route to go. I am a technician but I don't have the time to spend hours testing parts and trying to get off cheap like spending 2.00 at radio shach for transisters. Love advice Thanks
  • Dell Master
  • 1,684 Answers
We repair these all the time. Check our web site at: www.ccl-la.com/monitor_repair.htm The repair is very simple, just replace the 4 transistors and you should be back going.
If you need additional info just requhat.
Buddy
Corporate Computer
Posted on Jul 28, 2009
I have a Dell E172FPb LCD monitor with a black screen and blinking power light, no leaky or swollen capacitors inside, what can I do to repair it? Thanks.
Check out the four transistors (c5706/5707) Emitter to Collector (see picture of the transistor in my transistor album for pinout), it should read open circuit (should be checked out off the board). This is common problem. Make sure to inspect the solder joint in on the board, especially around the inverter transformer pins. Make sure the fuse read out less than one Ohm also.
http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Nov 06, 2010 | Dell E173FP 17" LCD Monitor
The DELL E172FPb LCD Monitor (switch light flicks green)scr black
hi, extremely common problem for dell 17 in monitors. the capacitors and transistors on the power board internally have gone bad. to get repaired, it may cost 40-50 at a shop. i have repaired these in the past and they always come out well for at least 3 more years. may want to find another monitor though. if you would like steps on how to repair, let me know and i will find my old repair threads to give to you.
May 12, 2010 | Dell E173FP 17" LCD Monitor
You need to open it up and inspect the componente inside, look at the fuse and the transistors in the inverter circuits first, also look for sign of over heating on the board, see pictures here for the guide: http://s807.photobucket.com/home/budm/allalbums
Mar 20, 2010 | Dell E173FP 17" LCD Monitor
I have a Dell E172FPb flat screen monitor. The
There are two possibilities, one is bad caps in the power supply, number two is shorted out transistors (P/N c5706/5707) in the inverter circuits. Please open it up and report back what you see so we can guide you further, see example fo failed monitors due to bad caps, lamps, etc: http://s807.photobucket.com/home/budm/allalbums
Jan 30, 2010 | Computers & Internet
E193FPC : Monitor power light on, Monitor starts up and displays image for 1 second or less, goes black and stays black, If turned off and back on it will again display image and revert to black. Results...
here is a similar dell monitor with the exact same problem....
http://www.motherboardpoint.com/dell-e172fpb-monitor-t55620.html
read all the way to the bottom of the thread and you will find:
volto user_offline.gif Junior Member Join Date: Oct 2007 Posts: 1
10-30-2007, 07:54 PM I have the same monitor and it had the same problem, I got it for $10 at a garage sale because they "didnt know if it worked or not" BS, they knew it was broke. But i accepted the challenge. There are four transistors on the power supply board detailed as Q759, Q760, Q739 and Q740. It is usually just two that go bad on these monitors, but instead of hassling with testing all four, I would recommend just replacing all four. Here are some replacement part numbers. I used NTE2524, same as NTE2525, and paid about $1.25 each.
and here are Sanyo parts (hard to obtain):
2sc5707 C5707
2sd1803
2sd1804
ECG2524
The transistors are rated at 60v 20w.
Just wanted to share my success story. Hope this info helps someone. I found my info on some other forums that i can't find right now.
Nov 06, 2009 | Dell E193FPC 19" TFT LCD Flat Panel...
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
My Dell E172FPb flickers & has straight, thin
#1 Connect monitor to another system, make sure the issue is the Monitor, not the video card.
#2 Try a different VGA or DVI cable
If the issue is isolated to the monitor, it is cheaper to replace it than to repair it (Refurb 17" LCDs are $69 on Dell's Outlet
Jul 02, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Dell E172FPb screen blinking
If you've tested turning the monitor on without the VGA cable and it's still blinking I'd say there's a problem with one of the capacitors on the power supply card on your screen, when you're able to check it would you mind telling me the brand / reference of it ?
Nov 04, 2008 | Dell E173FP 17" LCD Monitor
Dell flat screen
REPLACE 2SC5707 IN POWER INVERTER BOARD.
This parts is used to fix Some dell and hp lcd monitor.
DELL E172FPb, E173FPb. HP Pavilion F1703, Pavilion F1503. If you can't get this item to work let me know, I can help I have fixed a lot of these monitor with no problem.
May 01, 2008 | Dell E173FPb 17" TFT LCD Monitor
Dell E172FPb 17" LCD Monitor Problem
Your inverter power supply has gone bad. You will need to replace the whole board or replace the the 2sc5707 transistors in the inverter area. Check out this link for installation videos and how to for that model
http://www.lcdrepair.us/Installation.html
They also sell the whole board as well as repair kits
Oct 27, 2007 | Dell E153FP 15" LCD Monitor
Dell E153FP 15" LCD Monitor Logo
292 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
