Question about Dell Office Equipment & Supplies
Dell laser printer 3100cn problem: the back/rear panel or door will not shut to close. Can't print because message shows up ''must close duplex module''. When I physically hold the back panel (the largest door), and pull it to stay shut while printing, the printer reads that it is ready to print, but it's impractical for me to stay standing there holding this piece of machinery together.What can I do?
Vegggie Boy
  • 28 Answers
SOURCE: Dell 3100cn Duplex won't feed
I'd suggest it is a sensor issue. Since the error comes up, the printer stops responding - even if everything is okay.
Posted on Jul 28, 2007
  • 5 Answers
SOURCE: Paper Jam Error on Dell 3100cn Laser Printer
Push the side button and open the front cover
Pull out the jammed paper from the duplexer. If jammed paper cannot be found, go to the next step.
Pull up on the belt release levers and rotate the belt unit up
Remove the jammed paper and close the belt unit
Close the front cover
Posted on Jan 09, 2009
97F350diesel
  • 1326 Answers
SOURCE: PRINTER "OFFLINE" FROM PC CONTROL PANEL, PRINTER SCREEN READY
Make sure you have the ethernet cable plugged into the printer/network and is working properly. The toner replacement doesn't affect the network functions of the printer
Posted on Aug 06, 2009
  • 547 Answers
SOURCE: Dell 3100cn laser printer poor print quality
It sounds like you've got contamination on the drum cartridge or on one of the toner cartridges.
I'm actually going to be installing black toner in my 3100cn in about 8 hours, so I'll inspect and clean each of the carts, and write up the process for you tonight.
Posted on Jan 27, 2010
Testimonial: "Thanks! I have gone through all the instructions on Tech support for the printer. All cartridges have been cleaned and drum has been cleaned. Guess "
WonderTech
  • 268 Answers
SOURCE: 3100cn Laser Printer: dell 3100cn service manual...
This link will take you to a site where you can download the manual for your machine. You will the link on the right side of the page.
http://safemanuals.com/user-guide-instructions-owner-manual/DELL/3100CN-_E
Hope this helps.
Posted on Aug 04, 2010
Getting an error message 016-799
One reason this error message is displayed on Dell laser printers ... attempting to duplex print using the Single Sheet Feeder (SSF). Try printing document single sided if using the SSF.
Mar 15, 2014 | Dell 3100cn Laser Printer
Installed new yelloe cartridge but printer keeps stating to reseat cartridge
009-340 Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ...imaging drum cartridge. Turn the printer off using the power switch on the left side. Wait 10 seconds, turn the printer back on, and check if the error message...sensor solenoid nip. Turn the printer off using the power switch on the left... (English) 016-720 PCL Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ... Press Select ( ) to clear the error on the printer. Reset the printer NVRAM: Press Menu. Press the...and then press Select ( ). When Restart Printer appears, turn the printer off and then back on... (English)
KB Article How Do I Configure and Troubleshoot My Dell Color Laser Network Printer? - KB Article - 296059 ...Troubleshooting Guide for My Dell 3000cn-series / 3100cn Laser Printer ...available online for your Dell 3000cn/3100cn laser printer. The troubleshooting...printing, refer to the Dell Laser Printer 3000cn/3100cn Troubleshooting Guide... (English)
Dec 13, 2010 | Dell 3100cn Laser Printer
I have the Dell laser printer 3000cn. The printer powers on and everything but I can not do anything because it keeps asking me to close the reg cover. ther reg cover and all the other covers on the...
Dell 3000cn Color Laser has a duplex. If you face the printer on the top right of the duplex there is a button to release the duplex and it folds back. The reg cover is a door on the back of the printer that is covered by the duplex, try opening again, I know you have done this, maybe even wiggle it a little see if it registers as closed.
Also check to see if any dust or paper pieces maybe be jammed in there.
Nov 02, 2010 | Dell 3000cn Laser Printer
Dell 3100cn Laser Printer - Not capable of duplex printing? Or yes?
Hi. Duplex printing is optional. You need to purchase additional accessories to enable duplex printing.
Aug 19, 2010 | Dell 3100cn Laser Printer
Close front door message keep showing up every time I print and it will not print
I've had this issue at our office. You need to perform a factory reset on the printer following the directions in the owners manual, or contacting Dell telephone support. (1.800.WWW.DELL)
Jan 03, 2010 | Dell 3100cn Laser Printer
Loud Abnormal Sounds with each print job
It may be a paper feed issue. If using a duplexer, try removing the duplexing unit and try printing again. It's often attached to the back of a printer.
May 21, 2009 | Dell 3100cn Laser Printer
Our Dell 3100CN pcl6 still prints, but it makes a grinding noise.
I had the same problem, tried to use the MFP tray, got jam, couldnt't close the rear door and used appropriate force... terrible noise with every print thereafter.
I fiddled with the roller at the back of the MFP tray. It didn't want to move much but after rotating it ~ 45 degrees back and forth it was in a more loose position. That seems to have solved it, no more noise!
Jan 22, 2009 | Dell 3100cn Laser Printer
Jan 03, 2009 | Dell 3100cn Laser Printer
Jul 28, 2007 | Dell 3100cn Laser Printer
88 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
