Question about Cell Phones
SAMSUNG R210 will show the phone number when a call comes in. But if a call is missed, gives wrong info or no info at all
I forgot my phone lock code for a samsung s7220
For all:
*#06# Show IMEI
*#9999# Show mobile Software Version
*#0837# Show mobile Software Version (instructions)
*#0001# Show Serial Parameters
*#9125# Activates the smiley when charging
*#0523# LCD Contrast
samsung-mobiles2.jpg *#9998*228# Battery status (capacity, voltage, temperature)
*#9998*246# Program status
*#9998*289# Change Alarm Buzzer Frequency
*#9998*324# Debug Screens
*#9998*364# Watchdog
*#9998*377# EEPROM Error Stack - Use side keys to select values
*#9998*427# Trace Watchdog
*#9998*523# Change LCD contrast
*#9998*544# Jig detect
*#9998*636# Memory status
*#9998*746# SIM File Size
*#9998*778# SIM Service Table
*#9998*785# RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error
*#9998*786# Run, Last UP, Last DOWN
*#9998*837# Mobile Software Version
*#9998*842# Test ******** - Flash the screenlight during 10 sec and vibration activated
*#9998*862# Vocoder Reg - Normal, Earphone or Carkit
*#9998*872# Diag
*#9998*947# Reset On Fatal Error
*#9998*999# Last/Chk
*#9998*9266# Yann debug screen (Debug Screens?)
*#9998*9999# Software version
*0001*s*f*t# Changes serial parameters (s=?, f=0.1, t=0.1)
*0002*?# unknown Samsung's comand
*0003*?# unknown Samsung's comand
For Mobile phones SGH (R210, T100, A300...)
if Samsung code is in format *#9998*xxx#
try write in this *#0xxx#
SGH-600
SGH-2100
*2767*3855# Full EEPROM Reset (THIS CODE REMMOVES SP-LOCK! but also changes IMEI to 447967-89-400044-0
*2767*2878# Custom EEPROM Reset
Samsung mobile phone codes: Samsung E700
*2767*688# remove USER CODE and SIMLOCK
Samsung mobile phone codes: Samsung V200
Unlocking:
Power on the mobile phone without SIM card and type these codes:
*2767*63342# and press green button
*2767*3855# and press green button
*2767*2878# and press green button
*2767*927# and press green button
*2767*7822573738# press button
Phone will be unlocked, but all trims are reseted !!!
Mobile phone must be fully charged
Samsung mobile phone codes: Samsung S500
Unlocking
*2767*MVT# (*2767*688#) E2P MVT Reset
*#SIMLOCK# (*#7465625#)
Jan 15, 2011 | Samsung S7220 Cell Phone
Tip
Samsung cell phone's secret codes + tricks
*#06# Show IMEI
*#9998*872# Diag
SGH-600
SGH-2100
Unlocking:
Unlocking
on Aug 05, 2010 | Cell Phones
My samsung a766 in in phone lock
hi try these codes
*#06# Show IMEI *#9999# Show mobile Software Version *#0837# Show mobile Software Version (instructions) *#0001# Show Serial Parameters *#9125# Activates the smiley when charging *#0523# LCD Contrast
*#9998*228# Battery status (capacity, voltage, temperature) *#9998*246# Program status *#9998*289# Change Alarm Buzzer Frequency *#9998*324# Debug Screens *#9998*364# Watchdog *#9998*377# EEPROM Error Stack - Use side keys to select values *#9998*427# Trace Watchdog *#9998*523# Change LCD contrast *#9998*544# Jig detect *#9998*636# Memory status *#9998*746# SIM File Size *#9998*778# SIM Service Table *#9998*785# RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error *#9998*786# Run, Last UP, Last DOWN *#9998*837# Mobile Software Version *#9998*842# Test ******** - Flash the screenlight during 10 sec and vibration activated *#9998*862# Vocoder Reg - Normal, Earphone or Carkit *#9998*872# Diag *#9998*947# Reset On Fatal Error *#9998*999# Last/Chk *#9998*9266# Yann debug screen (Debug Screens?) *#9998*9999# Software version *0001*s*f*t# Changes serial parameters (s=?, f=0.1, t=0.1) *0002*?# unknown Samsung's comand *0003*?# unknown Samsung's comand For Mobile phones SGH (R210, T100, A300...) if Samsung code is in format *#9998*xxx# try write in this *#0xxx# SGH-600 SGH-2100 *2767*3855# Full EEPROM Reset (THIS CODE REMMOVES SP-LOCK! but also changes IMEI to 447967-89-400044-0 *2767*2878# Custom EEPROM Reset Samsung mobile phone codes: Samsung E700 *2767*688# remove USER CODE and SIMLOCK Samsung mobile phone codes: Samsung V200 Unlocking: Power on the mobile phone without SIM card and type these codes: *2767*63342# and press green button *2767*3855# and press green button *2767*2878# and press green button *2767*927# and press green button *2767*7822573738# press button Phone will be unlocked, but all trims are reseted !!! Mobile phone must be fully charged Samsung mobile phone codes: Samsung S500 Unlocking *2767*MVT# (*2767*688#) E2P MVT Reset *#SIMLOCK# (*#7465625#)
May 12, 2010 | Samsung SYNC SGH-A707 Cellular Phone
Need unlock code for samsung mobile phone model number SCH-R210 has cricket for service
If your phone is locked call the service provider tell them you now own the phone and you need the last 4 digits of the phone number used before you it is as simple as that. Thats what you are paying phone unlockers to do. duh!
Dec 18, 2009 | Cell Phones
Bluetooth passkey
how do i find out my passkey for my samsung R210 Spex
Mar 19, 2009 | Samsung OEM Car Charger R200 R210 SPEX...
Unlock code
To accomplish the unlocking of your Samsung R210 Spex due to forgotten or unknown user lock code I used the following method. First, you will need a data cable. I bought this one from eBay...
Data cable
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=260427509638
Create a folder on your desktop. I named mine Samsung R210.
When you plug your phone into the PC it may be recognized and work. If not you may need the USB drivers also.
Unplug the phone.
Open the Samsung R210 folder and create another folder. I called mine USB driver. Download this driver to the USB driver folder...
http://forums.mobiledia.com/cgi-bin/redirect.cgi?http://members.chello.nl/dondiegox/Samsung/Flashers/Z100_Downloader.zip
In the zip file there's a folder called Samsung_USB_install
Unzip it into the USB driver folder also and click on setup.
Reconnect the phone.
Check the control panel under USB and ports COM and LPT. My phone appeared on COM 10 under ports COM and LPT.
Next, create two more folders inside the Samsung R210 folder. I called them PST and Cricket DLL. Download Samsung PST lite and DLL installer files from the following two links into their respective folders.
Samsung PST lite...
http://www.mobile-files.com/forum/attachment.php?attachmentid=2274&d=1105395154
Cricket DLL file for the PST...
http://www.megaupload.com/?d=N3XTCO3W
Unzip them both into their same folders.
Run the install for PST.
Run the install for the Cricket DLL.
There should now be a shortcut on your desktop named Samsung PST lite. Double click it and you should see the PST Lite window.
Double click SCH-R210 on the right.
This should show you the unlock code in the next window.
If you don't see the info click the read general information button at the bottom. Write down the user lock code or be sure to remember it. Close the windows. Disconnect the phone. Enter the lock code into the phone and you should be free!
PS, I got my R210 Spex off eBay for $0.01 because it couldn't be unlocked! I have a feeling those prices will go up now that this info is on the web.
Mar 13, 2009 | Samsung Cell Phones
I have a samsung r210. my phone is locked and i bought it used and i dont have the code
a basic 4 digit code for unlocking your phone, usually the code is either 0000, 1234, or the last 4 digits of your cell number.
Jan 15, 2009 | Cell Phones
I have purchased a samsung spex r210 and have accidentally set my phone to nam 2
you need to call samsung at 1-888-987-4357
and they will give you a code number generated from your esn# its free so dont worry
Dec 25, 2008 | Samsung SCH-u520 Cellular Phone
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
