Question about Canon imageCLASS D860 All-In-One Laser Printer
Will print but copy function does not work - Canon imageCLASS D860 All-In-One Laser Printer
  • 56 Answers
Scanner motor or the ribbon cable to it is broken.
Posted on Oct 09, 2009
HP Officejet 5610 All-In-One. cartridge error: refer to device documentation to troubleshoot ... I was in the process of of printing a series of documents. does not print prpoperly
Will it color copy- stand alone? Try making a copy on the printer by itself. If the copy is still printing in blue, then go to the service section in the menus, and clean the print head, if that does not work then try the recalibrate function. -If the copy comes out fine when you try it stand alone, try deleting the printer and reinstalling the printer.
Mar 28, 2014 | HP Officejet 5610 All-In-One InkJet...
Printer does not print when I send from my computer, but does print when I place copy under screen for copying.
Copying and printing are two different functions. Your machine will process copies because the work is all done AT the copier. In order to print the PC and the copier need to be able to communicate properly.
Make sure that the printer drivers for your machine are set up properly on your PC and the two systems are communicating correctly.
Aug 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Unable to add a functioning (second) printer, for greyscale.
Clicked on Start/Control Panel/PrinterI. Clicked Add a printer. Obtained (Copy 1) of my HP Photosmart C7280 all-in-one printer. Right clicked on (Copy 1)/properties. Opened Ports tab. Saw comment "Print to the following Ports. Documents will print to the first free checked port." A listed USB Virtual printer port, showed three printers -- my first printer, my copy 1 (& my fax printer) -- was unchecked. I placed a checkmark in this Port box. Both the original printer, and my copy 1 printer are printing just fine. *I have not checked to verify that my fax is functional.
I did rename the original "color". I renamed Copy 1 as "grayscale", and --under printer preferences, checked, under "color options", to print in greyscale.
Mar 30, 2009 | HP Photosmart C3180 All-In-One InkJet...
IS IT POSSIBLE TO GET A TEST PRINT OR SCAN TEST WITHOUT THE X1180 BEING CONNECTED TO A PC?
No, if you print or scan, you need always to store the file on a computer, and if you use copy function, you still need the computer, as copy function allowed on this printer is only Colour Copying with PC .
This printer cannot print, scan or copy if it is not connected to a computer.
Oct 10, 2008 | Lexmark Office Equipment & Supplies
Will not make a copy
If it won't copy, it is unlikely to handle faxes either since those functions use the same scanner. If your received faxes are coming out blank, then it is a problem with the ink system; if you can get faxes printed but not copy a document, the scanner may be at fault.
Have someone send you a fax to check this function (printing) and then try sending one back to check the scanner.
If either one fails, then hyou know where the problem lays.
Jul 10, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Copying function
how much time it is taking to print a self-test page
Jun 30, 2008 | HP Photosmart 2610 All-In-One InkJet...
Printer want print
Hmmm i think i need a bit more info... have you tried using the copy function? Check the Lcd screen for error msgs? If the copy function works and there are no error msgs then i would suggest a uninstall and then reinstall of the driver:
Use this updated driver direct from lexmark. During the install it should print a test page.
http://search.lexmark.com/printer/US/en/17K0000
If the test print does not work then try a different usb port.
Hope this helps..Good Luck please rate my response..
Apr 26, 2008 | Lexmark X5150 All-In-One InkJet Printer
Print function stopped working. Brother MFC 5840CN
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
Jan 10, 2008 | Brother MFC-5840CN All-In-One InkJet...
Copy function
well you gotta provide the details in scanners configuration where you want the scanner to copy your Documents to .i.e. whether you want it to scan and store it as a image or open it with some Application or you want it to print just assign any one task with proper configuration it will definately work.
Thanks
Nov 17, 2007 | Canon CanoScan LiDE 30 Flatbed Scanner
Canon imageCLASS D860 All-In-One Laser Printer Logo
old marine
old marine
