Question about Pentair 3/4HP Pinnacle High Performance Inground Pool Pump
De filter pressure too high water is cloudy - Pentair 3/4HP Pinnacle High Performance Inground Pool Pump
  • 366 Answers
Don't forget to recharge filter with D.E. after backwashing.
Posted on Oct 30, 2009
    Problem Solver:
  • 16 Answers
Backwash the filter from main drain until sight glass is clear-this will reduce filter pressure. After backwashing return gate valve to filter position, then filter from main drain only. check water chemistry. add a clarifier to water
Posted on Aug 23, 2009
2 Suggested Answers
  • 106 Answers
SOURCE: Pressure on the EC65 is always high
Certainly sounds like a filter problem. Here's a couple of things to try.#1. i don't know how you cleaned the filters but clean them again with a good filter cleaner/degreaser.#2. After a good cleaning, get a bucket large enough to hold the filter fingers in and give them an acid bath. They recommend a 20 to 1 ratio of water to acid (muriatic) but I personally don' think thats strong enough. Use a good amount of acid and let the fingers soak for a good ten or fifteen minutes. (always add acid to water, not water to acid) Rinse and reassemble filter. If that does'nt solve problem, I think it's time to replace filter.
Posted on Jun 17, 2010
Hayward pro series 220 not working. On filter mode continuously and pressure never goes up. Return pressure stays strong. water stays cloudy. I have changed sand, down pipe and now the multiport. Basi
This is not an uncommon situation for sand filters(persistent or slow to clear cloudiness). Mostly, these days , pumps are oversized for filter flow rates resulting in water being ramrodded through sand bed. The first thing to do is balance the water. If chlorine not present, double the suggested dosage. We are also assuming that the m.port valve has not been disassembled. the best sand to use is a #20 or #2 white quartzite. If problems persist , then consider filter aiding media to help the sand bed trap finer particles.
Oct 01, 2014 | Pool & Spa
Hi, I have a question
Hello Kiran - Often cloudy water is caused because the water was not purged. Try purging the water lines by running water through the filter for a total of 3 minutes. This can be done either in one big bucket or in various cups. If the water remains cloudy, then I highly suggest verifying that the filter is in good conditions with no cracks or damages. If the filter is working, then I recommend checking your tap water. If these troubleshooting steps prove ineffective, you may wish to contact a professional as the unit may possibly have an issue within the refrigerator lines.
Jun 16, 2013 | Frigidaire PureSource2 Water Filter WF2CB
Pump is blowing cloudy water back into pool
Cloudy water is the bane of sand filters!. I suggest letting filter run day and night. Do not backwash until the pressure rises 8 - 10 pounds above clean starting pressure. Do not try to vacuum or stir up the sediment. when water clears, vacuum to waste. Keep the hose running while vacuuming. A dirty filter is a better filter (up to a point). At a higher pressure the filter will trap more of the fine particles that are clouding your water.
May 28, 2013 | Pentair Meteor Above-ground 22" Sand...
What can cause Hot/Cold spikes on an RTG74-XN
Crossover, low hot water flow, low water pressure, sediment in water lines or heater, heat exchanger needs to be de-limed, water filter needs to be cleaned, water heater temperature set too high, incoming water temperature too high or too low depending on model, MUD or PUD districts with pressure spikes, dirty faucet aerators, loose wires, bad sensor, faulty PD-board, bad venting, dirty burner and combustion parts, etc.
Crossover
http://waterheatertimer.org/Crossover.html
Clean water filter monthly, de-lime tankless yearly
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
http://waterheatertimer.org/pdf/Rheem-De-lime-tankless.pdf
No error code:
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Overcoming fluctuating temperatures:
http://waterheatertimer.org/pdf/Bosch_Overcoming_fluctuating_temps.pdf
Resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Sep 20, 2011 | Rheem Paloma PTG-74XN / RTG-74XN Natural...
Have a pentair ccp320 filter.brand new last year.pool water has been cloudy for two weeks.water is balancedexcept akalinity is high at 200.suspect filter problems.water was clear for a month.cleaned...
Total alkalinity can be lowered by adding muriatic acid or sodium bisulfate. Acid may be added in doses of up to 1 quart per 10,000 gallons. Total alkalinity tests and further required additions of acid can be made every 2 hours.
Jun 28, 2011 | Pentair Clean & Clear Plus Ccp320 Pool...
Pressure increase over the red line on pressure gauge while we were away for a weekend. Now pool is cloudy white. I am assuming this is DE. Back washed and cleaned filter twice. However, after running...
When the pressure goes up, try this. Pour some muriatic acid in the skimmer. (about 1/2 bottle) Let pump run for a little bit,(long enough for acid to get into filter)then shut off pump for 5 minutes or so. If pressure goes down to where it should be when it's turned back on, it needs to be disassembled and cleaned and then acid washed.
Jul 28, 2010 | Hayward EC65 Extended Cycle DE In Ground...
Jun 17, 2010 | Hayward EC65 Extended Cycle DE In Ground...
Cloudy water
need to clean fingers with TSP degreaser then muriatic acid then they will take on the DE
Sep 14, 2017 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
Pressure doesn't last & seems to blow out cloudy, dingy water
if you are on city treated water, sand will last aprox. 7 years, if on well water typically 3 - 5 years. so yes, could be a sand issue. also, double check that the there is no water trickling out the backwash / drain outlet of the filter, this could indicate that the diverter valve gasket (spider gasket) could be worn and cause sand from the filter to flow to the pool. this is a common problem if you move the position selector often with the pump still running - the pump should always be off when moving the handle. good luck!
Jun 01, 2010 | Hayward SAND FILTER, PRO SERIES
Pentair 3/4HP Pinnacle High Performance Inground Pool Pump Logo
268 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
